Question about LG KU990 Viewty
I need a lgapp with the firmewire v.10b - LG KU990 Viewty
    President:
  • 1,871 Answers
Just look here : www.lge.com
good luck
Posted on Jan 29, 2010
How to fix fatal error
In order to fix your phone, you need to be calm and patient. Make a wrong move and no one will be able to help you.
Method A) First thing to do is determine if you can connect your phone to your computericon1.png and open its file-system up. If you can, just replace the files that you messed up with the original files (If you didn't back-up get the files above) and then restart your phone.
Method B) If you cannot access your file-system because your phone is constantly rebooting, the first thing you need to do is turn your phone off. If the on/off button doesn't work, pull the battery out to turn it off (DON'T TURN IT ON). Then connect your phone to your computer (While its off, and it should turn on by itself and go into a charging screen) and see if you can access your phone's file-system, again if you can replace the messed up filesicon1.png, and restart your phone.
Method C) If you STILL can't access your phone file-system, don't fear there's still hope. Some users have reported success using this method, but it may or may not work for you. Try holding all 4 buttons (camera, lock/unlock, and volume rocker) on the side when the phone is starting, see if you can get it to a white screen with information stating "This phone has the IMEI. If you want to make the gang image erase the IMEI," if you see that, connecticon1.png your phone to your computer and replace the files, then restart.
Method D) If you find that you cannot stay in the gang image screen above, meaning it turns blue/black with error fatal when you connect to the phone, then do this: Remove the SIM card out and turn on the phone. Hopefully you will get the emergency call screen to display (where you can only make 911 calls). Connect to your phone now and replace the files.
__________________________________________________ _________________________________________________
I also got the fatal error screen and another way to get it to the gang image screen is to remove your sim card and leave the battery in then plug it into a wall charger and then use the four button thing to take it to the gang screen, after it gets there unplug it from the wall charger and plug it into the data cable and the screen will remain at the same position..
This is Basically a Factory Reset for your phone. Try the other solutionsicon1.png above, then go for this one. Kind of a..Last Resort i guess you could say.. This is also known as the "GrCobb Method"
I had the same type of problem and had trouble resolving it by putting back the files I thought I had changed. I was getting LG's 'blue screen of *****' with a message like Fatal Error: Dog: 1 or something like that. Here is what I did:
1. Downloadicon1.png the LG Vu firmware files from this site (http://www.lg-vu.com/index.php?topic=3902.0). Unzip it. These files contain the entire LGAPP firmware folder. Then unzip it. It should create a LGAPP directoryicon1.png with every file that was on your phone when you got it. I know DH said to not replace the entire LGAPP folder because it may brick your phone but, hey, it's already bricked so not a problem.
2. Get into EFS and connect with your phone. Get to the gang screen on your phone using the steps if you have to.
3. Rename the LGAPP folder to something else (LGAPP_bad). Do not delete it. There are some files that are read only and you get an error message replacing them when you copy the new GAPP on top of an existing LGAPP directory. This doesn't happen if you rename the old LGAPP to LGAPP_bad before you do the copy.
4. Copy the LGAPP directory you unzipped above to the phone and restart it.
That is what I did and it came back to a clean state as if you did a factory reset.
Hope that helps.
Jul 20, 2014 | LG Vu CU920 Cellular Phone
Need manual for a 10B hand held business calculator
Assuming you mean either the HP 10b or the HP 10bII, select the desired manual:
10b
10bII
Sep 28, 2011 | Office Equipment & Supplies
I wonder what is the model of the battery using on HP 10b
HP 10b Calculator requires two CR2032 Lithium batteries. The battery is 3 Volts, 3/4" in diameter and has an estimated life of three years. Replace the battery with CR2032 or an equivalent one.The following brands are used interchangeably for this item: Energizer (ECR2032), Duracell, Panasonic, Eveready, and 3M etc, which can be purchased from any local electronics store.
For further information you may refe to HP 10b Manual
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Feb 27, 2011 | HP 10b Calculator
KU990 .pxo file problem
hay there ..it will help you...i just made that same mistake but i overcome from it..connect ur mobile to usb..and open it through efs media..then.select the port if it shows..if not try refresing and reconnecting...after connect u will see a new lg app create by system..rename it to toto again and disconnect ..then reconect and rename..toto to lgapp..this return back my viewty..and am so glad..
Nov 26, 2009 | LG KU990 Viewty
My lg view is stuck on a blue screen with a code showing....error fatal file dog ui. what do i do can it be fixed?
that is called the "LG blue screen of death"
you will have to restore it to factory settings.
follow the steps below:
1. Download the LG Vu firmware files from this site (http://www.lg-vu.com/index.php?topic=3902.0). Unzip it. These files contain the entire LGAPP firmware folder. Then unzip it. It should create a LGAPP directory with every file that was on your phone when you got it. I know DH said to not replace the entire LGAPP folder because it may brick your phone but, hey, it's already bricked so not a problem.
Oct 08, 2009 | LG Cell Phones
Lg viewty screen smashed would like to connect it to a computer to get the data off but cant see what im doin My LG Viewty was in my pocket and all of a sudden when I took it out i was suprised to see a...
Now if only your screen is damaged then you can make an connection via USB.
conect your phone with the usb port.
start in windows the program EFS MEDIA BUILDER by AKOM1976
you have to see that the folder already exist on your phone
LGAPP now make a swich. Rename LGAPP >>> TOTO.
Now the hidden files will apear in the EFS exporer.
Now you can backup the folder TOTO to your pc. Choose a
folder where you want to place TOTO. Stay on TOTO click right
and choose read. When its finished. The folder written to your pc.
So this you can do vice versa to Fix the backup of the files.
after that reset automatic by the EFS explorer the phone start up
normaly. A new screen you have to find it at google I am sure there
will be a loal dealer where you can buy new parts for LG KU990.
The files you need to see on your phone with EFS explorer looks like this:
LGAPP
LGAPPCommon
LGAPPDRM
LGAPPDRMCERT
LGAPPDRMCERTCERT
LGAPPDRMCERTCERTdevelopcert.cer
LGAPPDRMCERTCERTdevicecacert.cer
LGAPPDRMCERTCERTdevicecert.cer
LGAPPDRMCERTCERTdevicepkey.cer
LGAPPDRMCERTCERT ootcert.cer
LGAPPDRMCERTcmla
LGAPPDRMCERTcmladevicecacert.cer
LGAPPDRMCERTcmladevicecert.cer
LGAPPDRMCERTcmladevicepkey.cer
LGAPPDRMCERTcmla ootcert.cer
LGAPPDRMDPRO
LGAPPDRMDRMCERTTYPE.TXT
LGAPPDRMID
LGAPPDRMIDSYS
LGAPPDRMISAMDB
LGAPPDRMISAMDBCertDB.bin
LGAPPDRMISAMDBCertDBKey_CTYPE.bin
Etc.
[ File Renamed ] LGAPP->TOTO
These files are on the pc:
TOTO
TOTOCommon
TOTODRM
TOTODRMCERT
TOTODRMCERTCERT
TOTODRMCERTCERTdevelopcert.cer
TOTODRMCERTCERTdevicecacert.cer
TOTODRMCERTCERTdevicecert.cer
TOTODRMCERTCERTdevicepkey.cer
TOTODRMCERTCERT ootcert.cer
TOTODRMCERTcmla
TOTODRMCERTcmladevicecacert.cer
TOTODRMCERTcmladevicecert.cer
TOTODRMCERTcmladevicepkey.cer
TOTODRMCERTcmla ootcert.cer
TOTODRMDPRO
TOTODRMDRMCERTTYPE.TXT
TOTODRMID
TOTODRMIDSYS
TOTODRMISAMDB
TOTODRMISAMDBCertDB.bin
TOTODRMISAMDBCertDBKey_CTYPE.bin
TOTODRMISAMDBDCtxDB.bin
TOTODRMISAMDBDCtxDBKey_DID.bin
Etc.
and its fine to have these as my back up.
If your folder LGAPP on the fone is emty don't worry write the files from your pc to the phone Make a folder named TOTO.
and write all the files include the foleders in to TOTO at your phone.
When you fineshed. Rename LGAPP >> XLGAPP
Rename TOTO >> LGAPP.
Delete the folder XLGAPP.
Refresh and disconnect and you will see the phone startsup in
a normal mode. As you can see I delete th folder LGAPP that was empty.4f0b046.png
Now I read the folder that is back it up on my pc to the phone.
Now when its finished I renane that folder to LGAPP.
When yo finished diconnect the phone by clicking disconnect.
So the phone start automatical again and now its running in norma
mode asual. I hope this will work for you.
May 06, 2009 | LG KU990 Viewty
HOW TO FIX YELLOW REFRESHING SCREEN AS MY LOCAL MOBILE PHONE SHOP HAS FAILED TO BE ABLE TO RE FLASH THE FIRM WARE PLEASE HELP
a2ee4a7.gif LG_Authority
start in windows the program EFS MEDIA BUILDER by AKOM1976.
select connecton and after that you choose efs explorer select connection.
Now you see the files on your phone
maye there is a folder named as TOTO
be sure that this folder is on your phone!!!
If it does delete the folder named as LGAPP
after that rename the folder named TOTO to LGAPP
richt click and choose refresh.
now exit the efs program.
Turn your phone off and then after a few seconds on
the phone will startup normaly as always and its normal asual.
I hope this will work or you have to back up with the LGMDP euro
an after that choose restore and choose the image file *.nv2
This will work!
you can try a software update at http://nl.lgmobile.com/web/web.product.manualSoftwareRF.laf
This software update is at your own risk.
Choose your model of your mobile phone and download it.
Fallow the instructions by the software update be patience
if you don't see anything it take a few moments.
Comment posted on May 04, 2009 No you have to see that the folder already exist on your phone
LGAPP and a nother folder TOTO if the phone starts up and you didn't switch the folder it make a new folder LGAPP without the programs so all the folders in the folder LGAPP are emty.
So thats why you have to be sure that the folder TOTO is already exist on your phone.
And if you have a backup of the folder TOTO you can check if the maps are empty or not.
These files have to be in the map toto on your pc.
These are the file names that is logged by EFS explorer, you can see the folder names and the files that are in the folder map exist
Check if these file are located in the folders of your phone if not
delete the emty folder LGAPP and make a new folder named TOTO open that folder.
Now read the files that is on your pc in the map TOTO.
This folder have to be the files in it and doesn't suppose to be empty.
LGAPP
LGAPPCommon
LGAPPDRM
LGAPPDRMCERT
LGAPPDRMCERTCERT
LGAPPDRMCERTcmla
LGAPPDRMDPRO
LGAPPDRMID
LGAPPDRMIDSYS
LGAPPDRMISAMDB
Etc.
TOTO
TOTOCommon
TOTODRM
TOTODRMCERT
TOTODRMCERTCERT
TOTODRMCERTcmla
TOTODRMDPRO
TOTODRMID
TOTODRMIDSYS
TOTODRMISAMDB
Etc.
My LG KU990 Viewty doesn't appears LGAPP files in the efs program
to view lgapp file you nedd file explorer or EFS TOOL FOR KU990 KE990 KF700 By Yoshihiro Beta RC2 you can find it in web site
Feb 06, 2009 | LG KU990 Viewty
Lg viewty problem
my email is ryantheyob@hotmail.com contact me if you still need help
Oct 14, 2008 | LG KU990 Viewty
LG KU990 Viewty Logo
148 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
