Question about Dirt Devil Kurv Bagless Cordless Hand Vac - Spice
My Dirt Devil kurv no longer recharges. I think I need to replace the battery. Called the manufacturer and they can't help me.
  • 328 Answers
Obtaining a battery will be difficult; I had a similar problem with my Kone model. Check that the plug you have has a fresh new fuse though as it may be the connection lead.
Sadly because the batteries are built into the machine its difficult to find a replacement - ALL cordless hand dust busters suffer from difficult to find batteries because at cost they are reasonably cheap and not really designed to have batteries that can be found easily.
Well not until someone brings out a model that has batteries that are available...
Posted on Jul 25, 2009
    Problem Solver:
  • 10 Answers
This rechargeable vacuum, like most ni-cd based rechargeable items, uses what is called a "sub-c" ni-cd battery. If you manage to ge the item open with minimal damage, you can replcaes these re-chargeable batteries. You will most likely need to solder the new batteries in, since that is the way they install them. SO, if you are comfortable soldering, then buy some sub-c nicd batteries and get out the solder iron. This particular Curve uses 8 of these batteries for a total of 9.6V - each battery is 1.2v. Most likely all are not bad, but you will need a meter to find the bad ones. You can find these batteries for about $1.5 each on ebay. Good luck.
Posted on Oct 23, 2011
I have a dirt devil easy lite for 6 mths maybe.. it charges all day and loses power after 30 seconds.. what is wrong with it.. I cant return it cause I dont have receipt or box
I don't know that vac specifically but it seems to be a low end hand held vac. There is no spec for the battery that I found. That usually means they use a cheap rechargeable and I think the problem is the battery. I would contact the mfr since it is less than a year old. They can verify that from the serial number. If you buy another one, look for a NiMH or a Li Ion battery pack. It will cost you more but it will last a lot longer. Hope that helps.
Nov 02, 2016 | Dirt Devil Vacuums
How to open dirt devil kurv
Hi! To access the dirt cup and filter first remove the dirt cup from charger stand. Then twist the dirt cup to remove. Grab filter tab and lift up to remove from dirt cup. Twist filter to remove from adaptor. Any disassembly beyond this point is not recommended. Hope this helps!
Jun 24, 2014 | Dirt Devil KURV Hand Vacuum Champagne...
How to replace batteries for dirt devil kurv
Need to buy new sub-c 1.2 V Ni-Cd battery and solder them in. I did it and it was moderately difficult - especially since the unit was not designed for this repair - you will most likely crack the housing try to dis-assemble. I have lots of experience in electrical repair, and I would not recommend the effort unless you like this kind of stuff.
Nov 06, 2013 | Dirt Devil Kurv Bagless Cordless Hand Vac...
My dirt devil model bd10025w won;t recharge when plugged in and won'yt woek when plugged in
Assuming that you've tried a different electrical outlet, it may have a defective charger or a totally dead rechargeable battery.
Try Dirt Devil's customer help line:
1-800-321-1134.
Good luck from Detroit, MI.
Jul 18, 2011 | Vacuums
How do you open the vacuum
Wish I knew! We've tried everything and can't get it open.
Dec 11, 2010 | Dirt Devil KURV Hand Vacuum Champagne...
Can't get it open to empty it! Help
1. Remove the unit from the base.
2. Twist the top clockwise to separate the two halves.
3. Grasp the filter tab to lift it up.
4. Empty filter, replace, reassemble.
May 22, 2010 | Dirt Devil KURV Hand Vacuum Champagne...
How to clean the fan
best way with any vac.is to blow it out.
Oct 24, 2009 | Dirt Devil KURV Hand Vacuum Champagne...
Change filter kurv dirtdevil
remove unit off base. twist handle from suction nozzle, it will separate.
Jan 25, 2009 | Dirt Devil KURV Hand Vacuum Champagne...
I can't seem to empty my Dirt Devil Kurv
If it is the same as mine you have to remove the dust filter and then remove or empty the bin. Hope this helps.
Jan 18, 2009 | Vacuums
I have a Dirt Devil Broom Vac that won't hold a charge. I need to replace the rechargable battery. Is there a dealer near Bartlett, TN that can do that or would I be able to do it myself if I bought a...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=730257
Generic problem for all Vacuums
I have a Dirt Devil
Posted by maryk813 on Jul 02, 2008
I have a Dirt Devil Broom Vac that won't hold a charge. I need to replace the rechargeable battery. Is there a dealer near Bartlett, TN that can do that or would I be able to do it myself if I bought a new battery?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The only place that I know if to contact the Royal factory cust serv line listed below or to check the website and they may direct you to a local dealer in your area. All you would need is a new rechargeable battery and you can do it yourself. The problem that I see is that the new rechargeable battery may cost as much as a new vacuum if you consider the part plus shipping and handling. So, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://royalvacuums.com/ Customer Service 1-800-321-1134
Hours are: 8:00 AM to 7:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 02, 2008 | Vacuums
Dirt Devil Kurv Bagless Cordless Hand Vac - Spice Logo
1,233 people viewed this question
Top Dirt Devil Vacuums Experts
Jim Parker
Jim Parker
Tim Venetis
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
