Question about HP Compaq Presario CQ50-211NR Notebook
CQ5O LEFT TOUCHPAD BUTTON STOPPED WORKING - HP Compaq Presario CQ50-211NR Notebook
Touchpad button no longer works
Try googling the model name and number plus disable touchpad.
There is probably a key combination that you hit by accident
Sep 22, 2015 | Computers & Internet
Touchpad doesn't work
Step 1:
The touchpad of any laptop is always subject to heavy use.
Most touchpads are designed for their durability to sustain the daily wear and tear for the lifespan of the laptop.
However, there may be instances or accidents that cause the touchpads to malfunction or stop working entirely.
There are ways to troubleshoot such problems and there are also remedies to salvage the touchpad's functionality without heavy repair or replacement cost.
Determine What's Wrong
A laptop's touchpad basically provides the functionality of a mouse for a desktop PC, typically with two buttons located just below it acting as the left and right click buttons on a desktop computer. A touchpad may be damaged by excessive use or foreign substances such as water, dirt or food items. Hit the "Windows" button on the keyboard and then use the right-left keys (or hit 'C') to open "Control Panel." From there, again use the right-left keys to get to "Mouse" and then hit "Return." Use the right-left keys to toggle between the tabs and open each to investigate whether any boxes had been improperly clicked by accident that cause the touchpad to become unresponsive. But if any of these steps fail to remedy the problem, then the touchpad may need to be repaired or replaced. b> Repairing/Replacing Touchpad b> A touchpad assembly cost $100 or more and that's not including replacement installation. Hiring a specialist to replace a damaged touchpad, including parts and labor, may easily cost $200. Unless the laptop in question is worth well over $1,000 and the touchpad is deemed a necessity, such repairs are rarely worth the cost. Attempting to replace the touchpad without certain expertise in laptop assembly may be dangerous and/or destructive. Also, getting a replacement part that's not compatible with the laptop may have catastrophic results, including irreversible damage to the laptop. Long-Term and Better Solution b> The simplest, and best, solution to a malfunctioning touchpad is to replace its functionalities with an external mouse. Most PCs sold after 2000 come with USB ports and getting a USB mouse either a corded or a cordless one--will remedy the problem. A cordless USB mouse may be bought for as little as $10 and some of the better-designed ones allow the user to tuck the USB stick inside the mouse's belly when not in use. Even when a touchpad is working properly, a laptop user should be advised to plug in a mouse anyway whenever possible as touchpads are notoriously difficult to use and also leaves the user in an ergonomically incorrect position.
http://www.microsoft.com/ b> http://www.streetdirectory.com/travel_guide/116002/hardware/touchpad_keyboard_for_personal_computers__pc.html
Feb 19, 2013 | Computers & Internet
Aspire as3810TZ touchpad stopped working.
Press the mouse lock button. Most times you toggle the touchpad by a button at the top in the middle of the touchpad.
Some systems will have you to tap twice in the upper left hand corner of the touchpad to toggle the touchpad.
I've also seen some systems where you would have to Press and Hold the ALT or the FN key located at the lower left portion of the keyboard then hit the key that toggles the touchpad. The key that toggles the touchpad will have the icon of a finger pointing at a square which represents the touchpad.
if all fails Click Start/Control Panel and look for mouse or touchpad. Go in and set the settings back to default.
You could try reinstalling the touchpad drivers.
Get onlineand got to www.google.com In the google search box type: "AcerSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Touchpad rivers.
May 03, 2012 | Acer Timeline AS3810TZ Notebook
Acer laptop Aspire 5732Z touchpad not working...have been using mouse all along and touchpad was working now it isnt...did the fn f7 no help...checked the device manager all seems fine...tried to update...
I have the solution...
u see where the switch on button is ? next to it there are two buttons ...ones for stopping internet connection ...thats the one on the right. the one on the left is the one for locking the touchpad
if that button has a orange light blinking on it it means its locked ..
so just push the button and see if it works :) .
Jul 19, 2010 | Acer Aspire 5500 5570-2609 Laptop
Emachines e725 Touchpad Not Working
The eMachines E725 has a built in switch to toggle the touchpad on or off by the touch of a button. Look at the button to the left of the main power switch. You'll notice the icon looks like a hand touching a rectangle - or touchpad. if this button is lit up, the touchpad is turned off. simply press the button to toggle the touchpad back on. The light on the button should now be off.
It's that simple.
May 02, 2010 | Acer Aspire 3000 Notebook
Emachine E725 touchpad does not work
It's that simple. I hope this helps.
Apr 14, 2010 | Acer Aspire 3000 Notebook
Touchpad has stopped working, can you help?
Hi there don't worry. Its disable that's why not working. Please press FN+F7 and try. The symbol on your keyboard is below. Just press FN+ below mention symbol. Thanks.
Apr 07, 2010 | Acer Computers & Internet
I have Dell laptop and the buttons on the touchpad sopped working
I would just install a usb mouse through one of you usb ports
Option 2 is to spend a lot of money to have both switches cleand/repaired
Nov 21, 2009 | Dell F3534 Touchpad
My touchpad right and left click button stopped working
is there a touch pad lock button, that locks the pad? if there isn't then there is most likely excess debris or dust or something under there that needs to be blown out with airisol can. If both of those solutions don't work then i would check to make sure the driver is installed for the touch pad. Good Luck. and i hope it works out.
RATE THIS SOLUTION
Aug 24, 2009 | ASUS Eee PC 900 Notebook
HP Compaq Presario CQ50-211NR Notebook Logo
108 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
