Rooftop unit will not start and the stopped working also looks like the fuses are ok breakers are fine
  • 98 Answers
Have the freon checked some units have low pressure switches on them
Posted on Jul 23, 2009
Running unit on generator and it just stopped after 5 minutes will not start again
was your generator grounded??,did you check fuses and circuit breaker?
Jul 03, 2015 | Dometic Rooftop RV Air Conditioner
I have duo therm rooftop Ac unit, was working fine and just went out. Seems like it is not getting power, I checked breaker and fuses. Still not working. What do i do next ?
First of all are you plugged in at a rv park or home? Had ours do that as well, found the electrical source in rv park was defective. Caused our AC unit to cut in and out then wouldn't run at all. Moved to a new location and the ac was fine.
Jul 24, 2014 | Dometic Rooftop RV Air Conditioner
Air conditioner
There is a fuse inside the control panel of the AC itself. You have to take the cover off (from inside on the ceiling) and look up in there with a flashlight to find it. It is usually a very small amperage fuse - I think a 1 or maybe a 5 amp.
hope this helps
good luck
Jul 28, 2010 | Dometic Rooftop RV Air Conditioner
Circuit breaker overheating on rooftop ac after
Possible overcharge or bad breaker. You need to check the amp draw for the unit. If you draw under full load amps and trips breaker breaker is bad.Rus
Jul 13, 2009 | Dometic Rooftop RV Air Conditioner
Stopped working smells like something burned?
If this is a ducted unit with a wall mount thermostat, remove the inside cover from the AC unit. There is a silver box with the electronics inside. Remove this box and remove the cover. Visually inspect the connections where the 120VAC connects. If that looks ok, then check the relays on the printed circuit board. If these look burnt, replace the control box. If they look ok, check to see if there is power coming in to the unit. If not, check the breakers and make sure they are ok.
Thanks,
Jeff
Jul 05, 2009 | Dometic Rooftop RV Air Conditioner
Circuit Breaker and Dometic Rooftop RV Air
Its the watts you plug in too like ither 30 watts vs 50 watts. 30 watts will cause your wires to get hot in the unit. just pull down your breaker box and look at those white ground wires.
Jul 20, 2008 | Dometic Rooftop RV Air Conditioner
Possible bad capasitor, or seized motor
Jun 22, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
19 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
