Question about Konica Minolta bizhub 180 All-In-One Printer
My bizhub has an error code of C0501
It starts up and then shuts down stating 'machine trouble'. Any ideas?
  • Anonymous Mar 20, 2014
    service call c0501
  • 210 Answers
C0501 it is a trouble related with the Fusing Unit. Try to power it up with the STOP button pressed. If not, you may need to change your fusing unit.
Posted on Aug 26, 2009
HOW TO SOLVE ERROR CODE C0500 FOR KONICA MINOLTA 211
Error code C0500 and C0501 means Fixing unit's temperature abnormality.
How to reset these codes?
To reset Error codes C0500 and C0501, perform the following steps.
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
http://servicekonicaminolta.blogspot.com/2012/03/error-code-c0500-and-c0501.html
Jun 14, 2017 | Konica Minolta Office Equipment & Supplies
C0500
May 01, 2014 | Minolta Di3510f Bizhub Copier
Will not run
MAINTANANCE CALL (M2)
Jan 24, 2014 | Minolta Bizhub Di1811p Copier
C0501
The 501 code is not for bizhub 350 is for dialta 250/350/2510 and refer to fusing unit error.
Dec 16, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Maintainance call display of konica minolta copier bizhub 211
Maintenance call? from your question it is not clear what is the error code.Please see if there is any code appearing besides maintenance call.Note the error code and tell me again so that i can help you.If it is C0500 or C0501 then press the stop button on the panel and restart the machine do not release the button until the code removes.
Dec 13, 2012 | Konica Minolta KONICA BRAND TN-211 BLACK...
I have a Konica Minolta bizhub D2510F it gives me this error C0501. after searching around I found out that this error is a Fuser error. I replaced the Fuser and the PhotoConductor but I still get the same...
The error has to be manually reset. Here is what I found from the official procedure. Hope it works. How to clear a fuser error code (C0500, C0501, C0510, C0511, C0520, C0521). Solution To clear the fuser error code, perform the following after correcting the cause:
1. With power ON, open the front door and locate the small, rectangular hole below the imaging unit removal tool.
Note: It is not in the same location as the models 7915/7920.
2. Insert a suitable object into the hole to actuate the reset switch .3. The code should clear and a message to close the front door should appear.
Feb 03, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
C0501
turn off the machine, press the stop button, turn the machine ON, and keep the "STOP" button pressed, C0501 error code will reset in few moments...............
Aug 03, 2010 | Konica Minolta bizhub 180 All-In-One...
Minolta bizhub c 351 code c 3451
this error code means the fuser rollers failed to heat up you can reset the code by turning the machine off and hold down the utility\counter key while you turn the machine onwhen the trouble reset button shows on the touchscreen touch it and when it says ok turn the machine off then back on if the machine gives this erro again you will have to have the fuser replaced
Nov 19, 2009 | Konica Minolta bizhub C351 All-In-One...
After a power surge it comes up with a C0501 malfunction code and shuts itself down
The C501 code is to do with the fuser section not heating up in a given period of time.
Best guess would be that the surge blew the thermal fuse in the fuser and the lamp in not coming on.
This will nivolve taking the fuser apart, if you are not so inclined, it might be time to Call your local Tech.
May 14, 2009 | Office Equipment & Supplies
Error Code C-2152
if you interested for complete service manual downolad at www.eserviceinfo.com
Feb 29, 2008 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub 180 All-In-One Printer Logo
1,202 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
