Question about Bosch 1600H-LP Liquid Propane AquaStar AquaStar Liquid Propane Tankless Water Heater
I've misplace my owner's manual and we're plumbing up the unit. Where can I find an online version of the Bosch 1600H-LP owner's manual? Among other things I'm not sure which side is the supply etc.
  • 123 Answers
Go to http://www.boschhotwater.com/HelpfulResources/BrochuresManuals/tabid/354/Default.aspx and you can find your manual there. If you have any problems let me know and I will try to get the manual for you. Thx
Posted on Aug 04, 2009
Bosch 1600 h not lighting pilot light
If your getting a spark the generator should be ok I would clean the pilot injector and re try
Nov 16, 2014 | Bosch 1600H-LP Liquid Propane AquaStar...
I have a 16h Bosh hydropower hot water heater . The unit suddenly has no spark .I have taken off the little generater cap and thouroughly cleaned it and the internal turbine . With no improvement . All...
sounds like the generator has packed up. check water flow and clean any filters on the water line. you will need a service agent to check milli volts on generator and power pack
Dec 15, 2010 | Bosch 1600H-LP Liquid Propane AquaStar...
Recently installed a Bosch 2700ES. I am getting
unplug power or turn off power,reboot, and try again
Jul 04, 2009 | Bosch 1600H-LP Liquid Propane AquaStar...
Raypac HL 2 error code. How do I reset
unplug the unit for 1 to 2 minutes you can usally hear it click off when it is reset,
Jun 15, 2009 | Bosch 1600H-LP Liquid Propane AquaStar...
The burner lights up when it shouldn't
your thermostat is bad and needs to be changed but I am not sure if it is tied in with the circuit board or not, on the rinnai units it is and you would have to change the circuit board
Jun 07, 2009 | Bosch 1600H-LP Liquid Propane AquaStar...
Tubing size
Absolutely not. Unless it is installed exactly as instructed you will have a problem. Too small of a line = reduced flow rate.
Please rate if this helps-
Mar 23, 2009 | Bosch 1600H-LP Liquid Propane AquaStar...
Bosch 1600h NG not heating water hot enough
it sounds to me like the dip tube has failed. this is a plastic tube that is inside the water heater on the cold side. It is designed to put the incoming cold water at the bottem of the tank allowing heated water out at the top. when this tube deteriorates the cold water mixes at the top of the tank instead of the bottom. a new dip tube is about 5 bucks but must be inserted on the cold side by someone with plumbing experience.
Jan 08, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Bosch 1600H-LP Overheating Problem
did you check to see if your temp regulater is working properly? also you have a thermocoupler that senses the heat of the water and works in conjunction with the regulator. have either one or both replaced and the problem will be solved. please rate this thanks
Aug 27, 2008 | Bosch 1600H-LP Liquid Propane AquaStar...
Bosch 1600H-LP Liquid Propane AquaStar AquaStar Liquid Propane Tankless Water Heater Logo
206 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
