Question about Kenmore Oasis HE 27082 Top Load Washer
Beeping and continuous washing
Kenmore Oasis Canyon Capacity Top Loader Mod: 110 27072600, Serial CT 1371068One error code we are getting is F80. The washer comes on automatically and blinks all the lights, when I try a normal wash, it remains in the wash mode- forever... I stop the cycle, let the water drain and then run the Rinse, Drain cycle to try and get all the soap out of the clothes. Had the motherboard replaced under a recall last Thursday. It completed two wash cycles and now is back to this mess. A tech came out today to tell me that it was because a touchpad is stuck and the whole thing has to be replaced.
It also from time to time does some kind of c1, c2, c3 counting and tosses water around.
A mere $293 to do the job of replacing the touchpad. At least the service guys are nice, he seemed to feel really bad, yet not surprised...hmmm. This is exactly why I was hesitant to buy a computer based washer... Any suggestions would be appreciated on something I can do myself. In the mean time I will be doing the manual normal wash to the drain/rinse/spin until that no longer becomes an option. I keep the washer unplugged to keep it from beeping at me and turning on by itself when I am not attempting to wash.
  • 15,935 Answers
This symptom indicates a stuck key on the user interface control board.
Replacing this control board would most likely fix this type of problem.
The part number for the user interface for this model is 8564374.
You can order this part from SearsPartsDirect.com, RepairClinic.com, PartSelect.com etc.
The procedure for replacing this control board is shown in the images below.
Before buying any parts I suggest you access the interface ribbon and disconnect it and then connect it back and see if there is any improvement.
You might also remove the interface from the console and check the console for any stuck buttons.
Remember to unplug the washer first.
http://media.fotki.com/1_p,wkgbsdrbswtkdqwxgtqsskgwtqkq,vi/ksgtwdgrtxkrrffsdss/1/1303472/5961857/image29464img-or.jpg
http://media.fotki.com/1_p,sqrbbsbrrbwrbdtxgtqsskgwtqkq,vi/kbqtdwdswxkbswddwbg/1/1303472/5961857/image23056img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Posted on Sep 16, 2010
How do we get rid of the UL code on our Kenmore Oasis Canyon Capacity Top Load Washer? It stops on the final rinse and spin cycle with nine minutes left.
Thwere is a switch under the lid that will not spin the tub, if the lid is up. This may be bent or broken. Lift lid and shine a flashlight down the slot underneath the protrusion on the lid. you should e a'plank' across the hole. No plank the swithch or the ;Plank" is broken. Most likely the plank, or actuator.needs replaced.
To replace , and or check the actuator, you have to remove the top of the machine. On a Kenmore here are 2 screws at the top back of the washer thaqt hold down 2 metal plates that go up to the back of the control panel. When the screws and plates are removed you can pry up the top of the washer with a stout screwdriver. after removing the top you can un screw the safety inlerlock, that's what I call it, and check for the bent/broken actuator or broken switch. If all looks okay then you need to take an ohm meter and check for continuity through the switch. Place one test lead at each end of the switch, removing and marking the wires on the switch. Press the actuator and you should see less than 5 ohms on the meter, if that is okay, then it gets more involved.
Let me know
Jan 17, 2011 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Kenmore Oasis Canyon Capacity electric dryer has AF problem. Husband has removed back of dryer and can't find reason for lack of air flow. Dryer spins but no AF. Please help!
If you haven't checked the exhaust running through your home to the outside do so. Be sure that it is clear of lint and debris and if it is over fifteen feet then you may need a fan to help the flow through that venting. If none of that helps then it sounds like a defect in the machine.
Mar 14, 2010 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Kenmore Oasis top loader giving us continual LF error code... how to fix?
long fill error code. might wanna clean ur screens. take the hoses off ur washer and clean the screens
Jan 31, 2010 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
My kenmore elite oasis washer will not turn on. I
its the power button its a common prob use a soldering iron and switch it with the load sinal button this happpens as the washer alallows moisture to get on the board as its not protected it will save u a ton of money and anyone can do it
Apr 26, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis HE Top Loader washing machine
That would the user interface board (touch panel)behind the dash. Sorry, but not a cheap fix at all. Maybe search Ebay for the part, sometimes you can find it cheaper. Very expensive part and repair. Good Luck to you. Jim
Sep 07, 2007 | Kenmore Oasis HE 27082 Top Load Washer
I get a F error message when the cycle is one minute into the start....
I DON'T KNOW BUT IT SEEMS I HAVE HAD NOTHING BUT PROBLEMS WITH THIS WASHING MACHINE. MINE IS NOW STUCK CLOSED WITH ALL MY SONS JEANS IN THERE, AND NOW I HAVE THE F CODE TOO!.
Aug 25, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
205 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
