Question about Crosley CAWC529JQ Top Load Washer
What is the funnel-like hole for, in top of agitator?
Hi -
What is the funnel-like hole for, in top of agitator? Crosley CAWC529JQ Top Load washer. There is a tray for bleach at the back left, so it's not for that ... Thanks
  • 213 Answers
Its for fabric softener
Posted on Nov 21, 2007
Washer makes grinding noise when it agitates
check back of unit as the concrete on the back may of been dislodged check not over loaded also the belt maybe loose or streached
Jan 02, 2014 | Crosley CAWC529JQ Top Load Washer
Spins but won't agitate
Clutch is only used locking into spinout. Is drive coupling is loose or torn, if not you are most likely talking about a bad transmission
Nov 21, 2013 | Crosley CAWC529JQ Top Load Washer
Crosley CAW9244XQ top load washer
need a replacement plug where can I find one
May 05, 2012 | Crosley CAWC529JQ Top Load Washer
Hi my washer moter works but spin cycle is not working Every thing else is O. K Thanks
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
Mar 29, 2011 | Crosley CAWC529JQ Top Load Washer
Washer will not fill but immediately goes to the agitation cycles. I figure the water level sensor?
yes! check and reset or change the water level switch that sounds like a good place to start
Jan 19, 2010 | Crosley CAWC529JQ Top Load Washer
Wont spin does everything else but spin
Your spin cycle control seems to be bad. This is also called your timer. Check for power supply by pulling off your top panel and checking for power everywhere.
Apr 17, 2009 | Crosley CAWC529JQ Top Load Washer
Crosley caw5923mqd Top Load washer spins but leaves A LOT of water in the clothes
have you checked the pump out of the maachine
the pump may be blocked restricting water flow
if that is ok maybe you need to give the n
machine a hot wash the seals may be draging the spin down
Oct 12, 2007 | Crosley CAWC529JQ Top Load Washer
Crosley CAWC529JQ Top Load Washer Logo
98 people viewed this question
Top Crosley Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
