Question about Canon ImageRUNNER 330s Copier
400/300s printer I have a 400/300s i need to know if I can set my computer to this machine.
    Scholar:
  • 136 Answers
Well do you see a Network card installed
if not would you like to buy one and have someone install it for you. ? You need a Network card Now look behind you machine do you see either a USB Connector ? or R-J 45 Jack ?
if you do chances are you have a network card installed if not we have those for sale
Posted on Jul 24, 2009
Trying to use adf but tells me to put original on platen
You need to check the settings for scanning. The machine wants to use the platen because that is what it has been set up to do, or you are using a sheet size the machine doesn't know about. Again go through the scanner settings both on the machine and any attached computers.
Sep 04, 2016 | Canon Pixma Mx459 All-in-one Inkjet...
Instructions for fax 2820
for drivers click here
let me know if you need anything else.
Jul 24, 2008 | Brother IntelliFax-2820 Laser Fax
I cant hook my Lexmark X3550 to a wireless network. How do I do this?
You will need a print server to do this. Many stand-alone USB print servers do not support the bi-directional communication needed for the scanner of an all-in-one. (Check the specs if you are using one of these.)
A better option would be to connect the printer via USB to one computer and then share it across the network. A Windows 7 Home Group for example would be a simple way to set the feature. You may need to set the firewall to Trust the other machines in the network.
Set up the printer on the first computer as you normally would. Get the software from http://www1.lexmark.com/products/view/All-in-Ones/Lexmark-X3550/catId=cat10004-category&prodId=3924-product;jsessionid=51301F9D038596164B244112F2F14143.node4 if needed; click on Download Drivers. Then install the software on the first computer and then connect the USB cable. Set the printer to be shared (Start > Devices and Printers and right click on the printer. Find Printer Properties and the Sharing Tab.)
Make sure that the Home Group is set up and all the computers have joined the Home Group if using that feature. For other Windows computers on the network, get the software and then add the printer as a network printer from the Devices and Printers Add a Printer Wizard. If the printer doesn't show up, check the firewall and sharing.
I hope this helps.
(I have never connected an all-in-one over a Home Group. I do not know if the scanner works in that case.)
Nov 11, 2010 | Office Equipment & Supplies
I keep losing my ability to print from my vista PC. Vista pc has Pcillin software for security. Main computer is XP pro running with Norton. I know it's settings but I can't seem to find the combo I need...
So the printer is plugged in to the XP machine? If so then that's where we need to start. If the Vista machine can't find the printer then it's usually a permission or firewall problem. Easiest thing to start with is disabling the firewall in Norton then try and find the printer. If it pops up then we need to turn back on the firewall and configure it properly.
Dec 13, 2009 | Microsoft Windows XP Professional
I just installed my designer software onto a new computer that doesn't have a 25 pin printer cable, however, I bought a usb/25 pin cable and have the dongle attached...but the software says the dongle...
Your software still is looking for the 25 printer pin connection from the motherboard. I don't know computer set up from an engineering concept, but I do know that the usb connection you purchased doesn't work with that software. You'll need to either get the new software or a used computer with the printer port hook up.
Nov 01, 2009 | Husqvarna Designer I
I have an canon pixma mp480 connected to a windows xp home computer. It work fine. I shared the pinter to the network. I got the windows xp connected to that shared printer, but the windows vista computers...
Is the printer connected via USB to the XP computer?
How did you map the shared printer (ie; what port)
When you're on a Vista machine, go to Network, find thw XP computer, explore, can you access the printer through this method? I need to know if Vista machines were set up with this printer on Local Port or Connected to this machine.
Jun 19, 2009 | Canon Pixma MP480 All-In-One InkJet...
Machine on FAX, will copy, but won't print from computer
you need the sey up cd that came with the machine, it will automaticly set up the machine or you can manualy do this from my computer printe set up
Jan 08, 2009 | Brother MFC 7420 All-In-One Laser Printer
I don't know alot about computers and printers i bough a printer/copier/fax machine and i already set it up but i dont understand how to put it to the computer so i can print papers from the computer
dear,
the simplest way is this,
check the model and brand of this machine and download its user detailed manual from its site or any searching websites.
regards,
dont forget to rate it
Aug 08, 2008 | Computers & Internet
Fax problem
my computer is connect thru the cable and my fax i don't know how to set it up thru the computer
Aug 04, 2008 | Brother MFC 210C All-In-One InkJet Printer
56 people viewed this question
old marine
old marine
