Question about Malber WD1000 Front Load Washer/Dryer
Unable to level washing machine and dryer - Malber WD1000 Front Load Washer/Dryer
    President:
  • 2,976 Answers
Level the front of the machine. Tilt it front until the back legs are about 2" off the floor and drop it. The rear legs are on a pivot that sometimes sticks.
Posted on Jul 23, 2009
My DAEWOO washing machine shows E9 error . How can I fix it.
Following is a summary of your problem:
Daewoo Washing Machine Error Fault Code = E9
Fault Detected: Pressure Sensor Error
Washer Has Detected: Error with the pressure switch or level sensor
Check / Repair / Fix = Wiring to level sensor - Level sensor
You can check Daewoo Washing Machines' all Error Codes on the following link:
https://removeandreplace.com/2015/11/02/daewoo-washing-machine-error-fault-codes/ Daewoo Washing Machine Error Fault Codes
Check the following link also:
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3369-generic-daewoo-washing-machine-and-washer-dryer-fault-codes
Feb 05, 2018 | Daewoo Washing Machines
My washer dryer was on baby cycle wash and although the green light has come on to indicate it has finished, red lock key is also on and I am unable to open the door.
Martha, Try running another cycle, for some reason I think machine is sensing it still has water in it. If after running another cycle dose'nt do it, check links below to see (2nd link) how to open door manually with out damaging machine. press the helpful button
How to fix washing machine door lock in Hotpoint washing machine
Opening locked washing machine door
Feb 10, 2016 | Hotpoint Aquarius WD640 Front Load...
New washer draining out while washing or rinshing
If this is a brand new unit, make sure that the drain hose is hooked up at a level at or above the level of the tub. If it is too low, it can siphon the tub of water.
Apr 30, 2010 | GE WSM2480DWW Unitized Spacemaker Washer...
Do not buy an LG Tromm front loader unless you want stinky, moldy clothes! The first few months, I LOVED this washer, but now I think the machine is possessed by smell demons! I've tried everything, but...
Stinky clothes are usually the result of washing in cold water. Cold water will NOT kill bacteria.
Add one cup of vinegar to the wash before you start the machine - try it.
The vinegar will kill the bacteria during the wash. Your wash will NOT smell of vinegar.
The dryer level of dryness on most auto dryers needs to be set three clicks toward + on most machines. LG is no different.
Apr 02, 2010 | LG WM1812C Front Load Washer
During washing cycles machine moves around on floor,what could cause this?
One of two issues: The most common is that the feet on the bottom of the unit are not level. Take a level to the top of your dryer and level it out. If your dryer is level then the drum is out of alignment and there are screws in the back of the machine that will let you align the drum to make it level
Jan 02, 2010 | Samsung WF337AA Front Load Washer
WATER LEVEL UNABLE TO MAINTAIN
to maintain the water level there will be a level controler called like presostat in the IFB washing machine.and it function is after the water reaches the level this makes the solenoids (which will be called as electric water controler) to close the water line and to open the water line for refiling.so please check these both the parts are working.
May 28, 2009 | LG WFT1071TP Top Load Washer
Levelling washing machine indesit iwme
washing machine dances allover the floor when on spin cycle
Mar 13, 2009 | Washing Machines
Foot,frount of washing mechine,both sides will not go down, to level mechine
The dryer is causing thiner material clothes to get brown marks on them. Severe sqeeking when dryer is on.
Sep 30, 2008 | Kenmore 98702 Stacked Washer/Dryer
Indesit evolution de73 dishwasher
01 = Acquastop operated due to leak / overfill - machine drains until empty + lmin.
A02 = Heater Relay open circuit/short circuit or Thermistor or Safety T/Stat o/c or s/c or Element machine fills to Level Switch & Wash Pump runs.
A03 = Thermistor open circuit /short circuit - machine drains until Level Switch resets +1minute
A04 = Unable to sense/reach temperature in 70mins. - machine drains until Level Switch resets + lminute
A05 = Level Switch not resetting in within 3' 20" of drain commencing - machine drains until Level Switch resets +1 minute
A06 = Not used see also H20 at end
A07 = Wash pump Triac closed/open circuit - check that Drain Pump is not disconnected or Aquastop operated
A08 = Auxiliary Wash Pump Triac closedlopen circuit - check Wash Motor operation- machine drains until Level switch resets+30"
A09 = Main Wash Pump Triac closed/open circuit - cheek Wash Motor operation- machine drains until Level Switch resets+30"
A10 = Fill Solenoid valve Triac closedlopen circuit - check valve/operation - machine drains until Level Switch resets+30"
A11 = 1/2 load Solenoid Valve Triac or alternating Wash Motor action - check Solenoid Valve operation & alternating Motor action, replace Module if required - machine drains until Level Switch resets +30"
A12 = Relay with open circuit - check Heater, replace Module if required - machine drains until Level Switch resets+30"
A 13 = Dispenser Triac incorrect operation closed/open circuit - Wash Cycle completes but with Dispenser Lid notfunctioning correctly
H20 = Static 'Fill Time exceeding 6 minutes - cheek for blockages/low pressure
Apr 07, 2008 | Indesit 24 in. DE73 Evolution...
Washe machine problem
The sound become beet? We need a little more detail. Look in the owner's manual and tell us what is error e9.
Feb 26, 2007 | Daewoo DW500M Top Load Washer
Open Questions:
See all Malber WD1000 Front Load Washer/Dryer Questions
Malber WD1000 Front Load Washer/Dryer Logo
79 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
ashburton
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
