Question about Acer Aspire One PC Notebook
Aser aspire 1 won't boot
Message comes up need to reinsert vista cd and the is no cd or dvd disc player in this model, what to do????
I have benq combo cb523b my problem is combo not writ dvd
Hi Dear,
First Install the burning software and then try to write the DVD, may you have try to burn without burning software.
Click hear and get the Burning software, see the instruction of mention below.
Data Compilations
  • Burn, backup or copy your files to CD, DVD or Blu-ray Discs.
    Supports recording from command-line and BAT scripts for automating routine actions.
    Supports CD-R/RW, DVD-R/RW, DVD+R/RW, BD-R/RE and DVD-RAM media, including high-capacity double-layer media.
    Supports UDF (Universal Disc Format 1.02-2.60), Bridge and ISO9660 (Level 1-3, Romeo), including Joliet Unicode extensions.
  • Create Bootable CD or DVD. Use it as a very big floppy boot disc for recovery purposes.
    El Torito creation support with advanced options: emulation type, sectors, platform, load segment and boot message.
  • Append or update Multisession discs.
Multimedia Compilations
  • Create Audio CDs. Play a CD on your traditional CD player or car stereo.
    Supports MP3, WAV, WMA, OGG, M4A, AAC and FLAC audio formats and M3U playlists.
    Supports title and track CD-Text, including Unicode.
  • Create DVD-Video discs and MP3 CDs/DVDs.
Disc images
  • Make and burn standard or boot disc images.
    Supports ISO and CUE/BIN image files.
  • Copy disc to ISO image. This feature can be used for disc backup, as well as for disc copying.
Utilities
  • Erase re-writable CD, DVD or Blu-ray discs.
Thanks
Mar 31, 2012 | Computers & Internet
Error Oxc00000e9 when i turn on aspire 5741, no external devices plugged in.
try this below
First please refer to the following thread to see whether it helps.
http://forums.microsoft.com/TechNet/ShowPost.aspx?PostID=796452&SiteID=17
I know that you are unable to start the current vista operation system and getting the error 0xc00000e9; the issue can be caused by the damaged system files or hardware device. You might first follow the steps below to exclude the possibility of system corruption.
Method 1: Use the Windows Recovery Environment (WinRE) to run System Restore
1. Insert the Windows Vista installation disc into the disc drive, and then start the computer.
2. Press a key when the message indicating "Press any key to boot from CD or DVD ...". appears.
3. Select a language, a time and currency, and a keyboard or input method, and then click Next.
4. Click Repair your computer.
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next
6. At the System Recovery Options Dialog Box, click on System Restore.
7. Follow the System Restore Wizard instruction as usual and choose the appropriate restore point.
8. Click Finish to restore the system.
Method 2: Startup Repair from the Windows Recovery Environment (WinRE)
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next.
6. At the System Recovery Options Dialog Box, click on Repair your computer.
7. (Click the operating system that you want to repair), and then click Next.
8. In the System Recovery Options dialog box, click Startup Repair.
Feb 14, 2011 | Acer Aspire 5050-3371 Notebook
Acer Aspire 5315 Vista Windows boot problem
have you checked if your pc is compatible with win7? use this to check it: http://www.microsoft.com/windows/compatibility/en-us/default.aspx
and if it is, try to do a clean install. boot from the cd. insert the disc. restart pc, as soon as it has power, press F12 several times and highlight cd/dvd drive or ODD using your arrow keys then press enter. it will load the cd from there. And that should work fine.
Apr 03, 2010 | Acer Aspire 5315 Notebook
I have an acer aspire 5920 laptop and it wont boot up. displays message BOOTMGR COMPRESSED.
First before doing this you need to make sure you have your windows vista CD.
If you do not you need to obtain a copy of this,
the following site should have all the details you need to make the CD and also to fix the problem :)
To make the recovery cd/dvd you need
http://www.vistax64.com/tutorials/141820-create-recovery-disc.html
to fix the bootmgr problem
http://www.vistax64.com/tutorials/202609-bootmgr-compressed-message-boot-fix.html
Please let me know if you have any other questions
Mar 20, 2010 | Acer Aspire 5920-6335 Laptop
DVD Player stops reading disc Error message :
usually this happens when lens cannot read the the disc. Due to few reason 1 Your disk is scratched 2 Your DVD lens is covered with dust 3 You need to replace DVD lens
Try another few CD/DVD to rectify whether there is any problem with dvd you are trying to play
if this error occurs on all the dvd you played then the most likely proble is with your DVD lens either its coverd with dust use Disk cleaner if not you got to replace a new DVD lense as per model
Feb 18, 2010 | Samsung DVD-V9800 DVD Player/VCR
Can i change the operating system from windows vista basic to windows xp?
I would advise you not to do so. Most manufactureres did not release proper drivers for windows XP, as MS didn't encourage them to do so.
I can advise you to install windows 7 instead. I've installed it on all of my computers and I'm more than pleased. You can even run different programs as if the windows was XP... (and no, I don't work for Microsoft...)
Jan 12, 2010 | Acer Aspire 5335-2257 Notebook
I want to do a clean install on my acer to create 1 partition
What system are you running? xp? vista? Do you have the original systems disc?
Sep 14, 2009 | Acer Aspire 3610 Notebook
Bootmgr
Try this:
2. Press a key when the message indicating "Press any key to boot from CD or DVD …". appears.
7. Click the operating system that you want to repair, and then click Next.
OR :
try this
Boot from DVD -> setup recov. -> command prompt
<bootdrive>\windows\setup\scripts\bootinst.exe /nt60 all
should fix the bootmng
Feb 20, 2009 | Acer Aspire 5500 5570-2609 Laptop
"no disc" message
you should be cautious of what you do. every time you put a cd/dvd make sure your disc is clean, no scratches, no damage, no dirt, and no STICKERS sticking at the disc.
well if the problem just occurred inside your cd/dvd player, all you can do is to clean the optical eye with cloth and water and rub it at the eye(don't put to much water, just soak the cloth a little bit and don't put too much pressure against the optical eye)
if does it again adjusting the sensitivity of the optical eye would help, if still, you have to order a new optical eye though or buy a new cd/dvd player.
just be carefull of what you put inside your thing.ok?
have a good day and take care.
Mar 29, 2008 | Sony DVP-NS575P DVD Player
Acer Aspire One  PC Notebook Logo
130 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
