Question about Jensen VM9510 Car DVD Player
Jensen hey i want to know where the yellow wire goes because i can not see a dvd on it.
    Problem Solver:
  • 5 Answers
Re: jensen
Is it the solid yellow wire if so that is the memory wire and it should be hooked up. if you are talking about the parking brake wire you either need to hook it up the the parking brake spring or bypass it
Posted on Dec 02, 2007
0 characters
3 Points
How to set volume on jensen vm9311ts when i turn it off and turn it back on it goes to zero.
check to see if the const. (its usally the yellow wire) wire is going to power at all times and make sure that you have both ground wires at different places
Sep 21, 2011 | Jensen VM9510 Car DVD Player
Whenever I turn on my Jensen DVD player for my car it says enter code, and I don't know what the code is.
code is either 543210 or 012345 make sure the yellow wire is on a constant power source and the red is connected to ignition on and of course black is ground
Jul 25, 2011 | Jensen VM9410 Car DVD Player
I connect my alpine cva 1003 to valor dv-169T dvd player. sounds come out but the screen is not getting connected to dvd player. i connect red, white and yellow wires.
if evrything is ok with the dvd (make sure the dvd is working fine), you need to hook up the yellow/ blue wires and yellow / black wires one for parking breack and the other for the breack chek the diagram on top of the alpine radio .
Jun 15, 2010 | Alpine CVA-1003 Car Video Player
Phase linear UV 10 Multimedia player.
Apr 03, 2010 | Jensen VM9510 Car DVD Player
There should be a label with all the wiring on the player/radio itself.
Yellow goes directly to battery to hold memory
Red is for ignition switch to power on
Black is ground
Blue is not used unless you are power an amp or other accessory.
All other wires are for speaker wires.
You can get a quick connect harness so you don't have to cut your factor vehicle wiring. If you did do this already, you can go to to find out which wire is for what.
Sep 23, 2009 | Jensen VM9510 Car DVD Player
Yellow wire unpluged from radio
Sure. The wire u are looking 4 is located in the bottom right side of the plug. Under the Bat (Red) and Ground (Black). On the last hole on the harness. Had same problem. Hope this helps you.
Jul 18, 2009 | Jensen VM9410 Car DVD Player
Jensen VM9311TS
plow boy442- I'm guessing you want your dvd to work while your driving. The unit has to be hooked to up to the e brake ,if you know which wire it is ground it out the unit will think your in park. Let me know , I can help you with this. cooltek Mar,3/08
Mar 04, 2008 | Jensen VM9510 Car DVD Player
you need to put a code and its
Dec 02, 2007 | Jensen VM9510 Car DVD Player
No memory on VM9311TS
This is almost always related to an installation error. The yellow wire at the back of the unit needs to be connected to a constant voltage source that doesn't switch off with the key. It's possible that the connections to your red and yellow wires are reversed.
Jul 14, 2007 | Jensen VM9510 Car DVD Player
Jensen VM9510 Car DVD Player Logo
69 people viewed this question
Top Jensen Car Video Players Experts
Mike McWhinney
Are you a Jensen Car Video Player Expert? Answer questions, earn points and help others
