SOURCE: Daylight Saving Time will not set correctly
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
SOURCE: how set time, daylight saving vs standard, etc.
Try this website.
Enter the 3 or 4 digit number from the back of your watch in the module box. The number will probablly be in a box and next to the model number of your watch.
The manual is .pdf format so if you do not have Adobe Acrobat reader or another .pdf reader installed on your machine, click on the link at the top of the called "Get Adobe Reader" and install it. Once it is install search for and download the manual. The manuals are all that obvious so you may have to read through several of the sections to find the information you need.
SOURCE: casio watch problem
Appreciate the direct "Ask Me".
Offhand, I would say yes to the battery replacement. Though watches are not within my immediate field. This would be based on your post "2-5 minutes behind". As to the "lost signal" after a reset, may I request that you post back the specific model number pls.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
SOURCE: how do i set the
browse through my tips and you will find link for all Casio watch manual downloads.
SOURCE: I have a Casio 4304
It can be signal issue.Or you can try setting it manually, if its set on auto mode. Click this link directly,this is direct link for casio 4304 watch manual.:--- http://www.biro.ro/data_files/product_documents/file_83.pdf ------------ On page number 3 of the manual, there is procedure given to set the watch . --------------- this will help.Thanks.Helpmech.
