1996 volvo 960 air conditioner keeps blowing fuse. replace fuse and it works for about 30 - 45 seconds, then blows the fuse. what is the commong cause? where would it be located?
    President:
  • 1,922 Answers
Your compressor-clutch coil is starting to short-out and drawing too much current,repl should alleviate your symptom
Posted on Jul 27, 2009
S40, volvo, keep blowing a turn signal fuse
When a fuse keeps blowing everytime you replace it that means there is a short circuit along its cable. Check the flasher cables or call a car electrician to do it.
May 27, 2014 | 2004 Volvo S40
Why won't the air conditioner blow air?
The very first thing you need to do is to check for fuses or say faulty fuse. Secondly check fan which starts along with air conditioner, it might be manually switched off or the fan may have been clogged. Also reason can be lack of refrigerant - charge your air conditioner with refrigerant. Last thing you need to check is cooling coil - the cooling coil may freeze if there is no refrigerant in the system.
Jun 11, 2013 | Ford Explorer Cars & Trucks
My turn signals do not work on my 1996 Volvo 960
have you replaced the flasher unit
Mar 26, 2013 | 1996 Volvo 960
Volvo 960 AC problem
TX valve freezing?
Jun 22, 2012 | 1997 Volvo 960
Engine fan fuse blows every few days2001 volvo s40
Fuses are there for a reason, if they keep blowing it stands a chance your fan motor is on the fritz and overloading the fuse so it pops. Make sure the tempreture sensor is working ok and not keeping the fan running when it should be turning off.
Jul 23, 2010 | 1996 Volvo 850
The air conditioner compressor cuts off temporarily
it need regassing on the proper machine that weighs the amount of gas being charged into the circuit ,also while the machine has emptied the the existing gas you can check the restrictor valve isnt partially blocked
Apr 30, 2010 | 1996 Volvo 960
My 96 Volvo 850 GLT's heater does not work.
my heater or air conditioner does not work. i have to take out the fuse becausee it is stuck on the fan blowing position. I came home one night when it was cold i had the heat on with the defroster blowing shut off my car next morning went to work it stll was stuck on blowing and i could not shut it off so i have to pull the fuse.
Feb 11, 2010 | 1996 Volvo 850
Weather King blows fuse in Criterion II furnace
You probably have a shorted wire between the heater and the a/c. There are two wires that conncet the control power to the outdoor a/c from the heater they should be on terminal c & y in the heater. disconect those two wires and try it again if the fuse doesnt blow you have a short in the wire between the a/c & heater
Jun 01, 2009 | Weather King 10AJA2501AH Air Conditioner
A/C only blows cold for 20 minutes
Check the followings:
1. Pressure Switch connection - under front right hand side near lips.
2. Thermostat Switch connection - at the dryer under the hood
3. Retrun Valve maybe blocked - in the cooling pipe from the compressor
4. Cooling Thermostat in the compressor itself.
Jun 01, 2009 | 1997 Volvo 960
Headlights don't work, fuses keep blowing out
check the wiring too the tailgate it very common for it to break up and tuch other wires, also check trailer socket wiring,if it has one it will be a black wire and a brown one for the side lights.Good luck Davelee
Mar 08, 2009 | 1996 Volvo 960
Heating & Cooling Logo
240 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
