Question about LG RU-44SZ61 44" Rear Projection HDTV-Ready Television
How Do I Reset the lamp Timer?
I was told by LG that if the timer is not reset when replacing the bulb, the new bulb will net get the proper voltage and will prematurely burn out.
MY LG RT 44SZ23RB is loosing it's colour
I had a New lamp put in 2 years ago and never looked as good as it was, I complained but was told that it is right , could it be that the repair people used a inferior lamp if so what is the right lamp to put in
Posted on Dec 13, 2009
    President:
  • 1,284 Answers
I have replaced many lamps in LG TV's and have NEVER heard that. The lamp is meant to be replaced by the consumer but the timer on LG's is ONLY resettable by a special service remote that technicians usually have. The timer has no effect on the voltage to the lamp.
Posted on Jul 23, 2009
Replaced main bulb in front but lamp button on front of tv is still blinking and tv won't show picture
The lamp timer on the Hitachi projector must be reset whenever the lamp has been replaced. The "Lamp" indicator on the display will light red or the "Change the Lamp" message will display when the lamp timer needs to be reset. Hitachi recommends that the lamp timer never be reset without replacing the lamp and to always reset the timer when the lamp is replaced. The message functions of the projector will not function properly if the lamp timer is not correctly reset.
  • Turn the power on. Press the "Reset" button for three seconds until the "Lamp xxxx hr" message appears on the lamp timer on the bottom of the screen.
  • 2
    Press the "Menu" button on the remote control while the lamp timer is displayed.
  • 3
    Press the left arrow button. Select "0" and wait until the timer display clears.
  • If this was helpful a vote on the thumbs up for the free advoce would be greatly appreciated. Thanks
    Apr 04, 2011 | Hitachi 60V500 60" Rear Projection...
    Cannot reset lamp timer as will not project. Replaced the lamp in my 3m X50, bulb came right on. I had to shut it down before reseting the lamp timer. Now will not light up so that I can navigate the...
    It does not sound like resetting the lamp timer is what is keeping the projector from throwing an image. Try walking through the steps of the installation backwards to remove the bulb completely. Then reinstall the bulb again from scratch making sure everything is seated properly. If it powers up again just remember to set the clock back on the bulb.
    Mar 03, 2011 | 3M X50 Multimedia Projector
    I had a bulb burn replaced both bulbs worked for a couple of days but now it wont power up only lamp1 light blinking. I have tried taking bulbs out and putting them back in still nothing, also the lamp...
    the lamp units should be properly aligned with the 2 very tiny switches
    between them. If not lamp led will blink.
    If lamp led is continuously on, lamp timer has to be reset, according instructions that come with new units.
    Original lamp modules are AH-45001 and AH-45002, two different
    units needen for 1 projector, reset procedure is different for each lamp !!
    Dec 21, 2010 | Eiki EIP-4500 DLP Projector Multimedia...
    Lost the manual - I am replacing the bulb
    remove the lamp door, remove the lamp (2 or 3 screws), replace with new lamp, replace door, reset lamp timer (menu-settings-reset lamp timer-yes).
    Oct 08, 2009 | Sanyo PLC XU35 Multimedia Projector
    How to reset the lamp timer count on a LG rear projection TV
    1. Press the OK or enter button on the front panel and MUTE
    button on the remote control simultaneously (About 5 seconds).
    2. Press the VOLUME (>) button.
    3. Press the OK or enter button.
    Lamp time will be reset.
    Jun 15, 2009 | LG Televison & Video
    How to reset the bulb timer for TOSHIBA TLP-XD2000
    The booklet that comes with a new lamp specifies the following for the TLP XD2000. While holding down
    Mar 12, 2009 | Toshiba Office Equipment & Supplies
    Replacing lamp in rear projection tv
    To do this, press the ENTER button on the TV and the MUTE button on the remote at the same time. After 5 seconds the screen should come up and it will read "Lamp use time...Total lamp use time ....lamp reset" Press the center button on your remote (the circle button right in the middle of the four directional buttons) and you will be reset to -0- again. Your orange light should now be off.
    May 09, 2008 | LG RU-52SZ30 52" Rear Projection...
    Best but repleace bulb but red light still on
    So far I have entered the service menu (both menus together) then selected Lamp Replace (option 14) and then pres ok to reset. Version and Lamp (option 11) now reads Lamp life (Khr) = 8 and Lamp use (Hr) = 0.
    Jan 19, 2008 | LG RU-44SZ51D 44" Rear Projection...
    Do i need a new lamp
    i have this kind of tv1.gif model ru-52sz30 and same problem which i fixed by replacing the bulb. there is an access door at the back of tv that you can replace the bulb. if you need more help just post reply again.
    Sep 23, 2007 | LG RU-52SZ30 52" Rear Projection...
    POST Replaced Bulb Problem, Error code = 32
    This unit will not go into shut down because the lamp timer is not reset. The error you are getting means the lamp you put in is defective or it is not seated proplerly. Make sure the lamp door is on properly because there is a lamp door safety switch that must be depressed properly or the unit will shut down. When the timer needs to be reset you simply get a message on the screen that tells you so, it does not shut down. There are other things that will cause this problems such as the ballast or even problems in the light engine.
    Apr 01, 2007 | Sharp 56DR650 56" Rear Projection HDTV
    LG RU-44SZ61 44" Rear Projection HDTV-Ready Television Logo
    736 people viewed this question
    Computer Repairing
    Computer Repairing
