Question about Philips Audio Players & Recorders
Philips AF-829 won't pick up at the end of an album
When the tone arm reaches the ''end of the side'' position, the arm won't return to its normal resting position. I can hit the Stop button on the faceplate, and the tone arm will return so I know that mechanism works correctly. Some guy on another site said to check this as well, so the solutions posted here line up with other solutions as well.
I've never done anything like this and don't know whether I need to buy any special kind of LED and/or LDR. I'm hoping it's just something that will fit right in and plug in... any ideas on what sort of replacement parts I might need?
4 Suggested Answers
djproaudio
  • 515 Answers
SOURCE: Kenwood KD 3070 turntable
There should be a set screw that you can tighten in order to adjust the height return. If you do not have anything like this, perhaps your record is raised too much. How thick is your rubber mat? Do you have any other mats sitting on top of this?
- OPTiC
DJ Pro Audio
www.1200s.com
www.repairnyc.com
Posted on Sep 13, 2008
STYLUSCITY
  • 271 Answers
SOURCE: Tone arm keeps returning to rest on Crosley CR249
Hi, Try this. with it turned off. Lift tone arm across a record to the run out groove and set it down. Now power up and hopefully it will reset itself. In all honesty I would sell it and get a decent old school player. John. Styluscity.com
Posted on Nov 11, 2011
  • 13 Answers
SOURCE: Need a manual for a Realistic Lab-2100 Turntable
look on ebay
Posted on Feb 24, 2012
How can I stop the tone arm from returning too early on smaller records?
The adjustment for auto return position is normally at the tone arm base on the left side under a rubber grommet. Use a flat blade screw driver to move adjustment screw, then test. Keep fine tuning until arm lifts at desired position. Cheers John. Stylus City NZ
Jun 14, 2014 | Crosley 0187SST Turntable
Tone arm on technics Sl-BD22 lifts before the end of an album
the anti-skate is set wrong, this stops the arm skatting on to the label in the middle of the record & destroying your stylus tip.
Mar 03, 2013 | Technics SL-BD22 Turntable
The cartridge arm does not go back to the off position.
it's a "manual" turntable so this is normal. You would need to buy an "automatic" turntable to have the arm return back when done.
Apr 22, 2010 | Technics SL-1210 Turntable
The tone arm will not drop on our Technics sl-dd33 turntable.
Have you left the tone arm lift in the up position?
If not: At the end of a record the mechanism lifts the tone arm, returns it to the rest, lowers it and switches off the motor.
It the motor has stopped too early, the tone arm will remain raised.
You can try gently rotating the platter clockwise by hand. This may allow the return cycle to finish.
Jan 16, 2009 | Technics SL-BD22 Turntable
Tone Arm skips past first song
Hello, A. Do not try to close the case when there is a record inside!! The fact that the turntable cannot do this is not a design flaw--you'll be hard pressed to find a portable turntable that can close with a record inside because if you were to pick up the player with one inside, it could easily slip off of the spindle and scratch against the sides of the player.
B. Are you using the cueing lever to lift the tone arm before you place it on the record? Read the instructions to see where the cuing lever is (it's a little switch on the right side of the tone arm). When you lift it, the tone arm will lift up and allow you to position it wherever you want on a record, then you depress the lever to make the tone arm touch the record and being playing.
I hope that helps!
Jan 04, 2009 | Crosley CR249TA Turntable
- OPTiC
DJ Pro Audio
www.1200s.com
www.repairnyc.com
Aug 16, 2008 | Audio Players & Recorders
I've got a Pioneer PL-300 turntable bought around the mid-80's. It hasn't been used much in years, especially due to a problem with the tone arm lifting up before the end of a record (45 rpm) has finished...
Hi Mikey. I shure hope you have solved your problem by now, but for everyone else, I woud like to shead some light on this matter. What you need to do is to adjust the auto-return lever that is located between the center of the platter and the tonearm, underneath the plastic cover. To do so, you first need to remove the platter so that can reach the adjustment-screw.
This is how the lever looks like in my PL-300X and it should look the same for you. I've marked the adjustment-screw that can be reached through a hole under the platter.
and this is what it looks like with the cover on:
Hope this can solve your or anyone elses problem.  Ciao / Albin
May 31, 2008 | Audio Players & Recorders
Philips turntable af 829
Specifically the turntable AF-829:
I had exactly the same problem, and fixed this succesfully.
The problem is in one of the opto-coupler combinations (LED + LDR).
There are two, both located in the mechanical part of the turntable:
1. The first is for the detection when the arm reaches the end of the record, so that it will return to base. This is a red LED with an optocoupler in a little black case. This is OK.
2. The second one is for detection that the arm has reached the beginning of the record area. You can test this by manually pulling the arm from base and moving it towards the record. Then the turntable should start to rotate. You will see it does not.
The problem is that either the LED has not got enough light-emission any more, or the LDR has become more insensitive. It's a transparent LED that radiates RED light.
I replaced the LED by a new (red) one with higher light output, and now it's working fine again.
Marcel.
Apr 14, 2008 | Philips Audio Players & Recorders
Problem playing 45 Records to their entirety.
There is an adjustment on the tone arm that you use to set where the tone arm picks up at the end of the record. This adjustment is normaly at the back (pivot point) of the tone arm and will be on the side probably. By the way, the tone arm is the part that the stylus is mounted to that swings back and forth to reach all the surface of the record. Make your adjustment and then test and continue doing this until you get it just where you want it. It is a process of trial and error. Good luck.
May 20, 2007 | Emerson NR303TT CD Shelf System
284 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
