Question about Samsung CLP-510 Laser Printer
Samsung Printer won't come on at all
I have a clp-510, and it's been working very well for the past couple of years. But lately when I turn the switch on, absolutely nothing happens, no screen, no error message, no lights. Just like it's not plugged in (it is, and the outlet is working). Then I try awhile later, and it works fine for a couple of days, then dies all over again. Any thoughts?
  • severunio Mar 07, 2009
    The screen takes about 90 seconds to to say initilazing system, then
    after a few seconds there is a click from the corner where the psu
    input is & then the printer shuts down compleatly.after another 90
    seconds it will repeat this process (3 or 4 times) then i just dies. If
    i uplug it for about 10 minutes it will just do the same again
I have the same problem. It has come back on after disconnecting the power, opening up the right panel (while facing the manual feed tray) removing the 2 screws and pushing slightly on the larger chips and all the connections aroung the edges of the card. Not sure where the loose connection is but just blindly pushing on them seems to work.
Posted on Jun 12, 2009
  • 217 Answers
There are two possibly very different problems here.
Darkhorse892 probably has a power supply board with a 'dry joint' or faulty component - hence the 'leave it for a while and it works - for a short while.
Solution would be a replacement board - but there are two. A good used printer of the same type (so you can continue to use any consumables you have) might be the sensible and most economical way forward.
natrat Your problem should be fixed under warranty if it is only 2 months old !! Probably a faulty display/switch panel, or it has become partialy unplugged. Replacement display panels available on Ebay (where else!!) for a reasonable £15 GBP.
Posted on Jan 18, 2008
I went in to use my printer yester day (it is only 2 months old) and it would not print after checking the power and all of the other normal items I found that none of the lights were coming on and the screen on the front only had one black solid line across the top nothing else. I have plugged and unplugges, reset pulled everything apart and nothing helps can you give me any idea.
Nat Piercy
MObile AL
Posted on Dec 09, 2007
Samsung CLP-510 manual
Apr 22, 2014 | Samsung CLP-510 Laser Printer
I have a CPL-510 , one of the top orange rollers has started to disintegrate and has a couple of chunks missing. can I get spares or a repair
Contact this company, I have had good results from them:
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 21, 2011 | Samsung CLP-510 Laser Printer
Installation driver required
HI There,
Please folow the below link to download the latest installation software and the drivers for Samsung CLP-510 Laser Printer. ( You can even download the user manuals and installation manual from here )
Link :
Enjoy Installing the printer software and drivers and happy printing !!!!
Oct 23, 2010 | Samsung CLP-510 Laser Printer
Samsung printer problems clp-510 I've had this printer for just over two years - good printer. However recently it is producing very dirty print outs, there are repeated patterns of smudges. What can I...
Too many things for just one solution, If transfer belt is worn out, you'll get that, color drums can cause that, when the fuser wears out toner sticks and transfers to new prints. You have to unplug machine in the middle of a print cycle before print goes into fuser and determine if the problem is fuser or before
Aug 10, 2009 | Samsung CLP-510 Laser Printer
"invalid toner cartridge" message remains
Try this
Turn the printer off hold down the menu button turn the printer back on while continuing to hold down the the menu, when you get a green light your ready to print
Feb 18, 2009 | Samsung CLP-510 Laser Printer
Paper jam in tray 1
Hi glenpcr,
I had the same problem and solved it.
At my printer it was a problem of the MP-tray (multi purpose tray).
There are two hinges which keep the open MP-tray in a horizontal position. One of this hinges was broken and I just received it.
Just try it.
Feb 10, 2009 | Samsung CLP-510 Laser Printer
Wrong clp 510 toner
samsung clp 500 toner cartridge can not use samsung clp 510
bcase clp 500 is without chip and clp 510 chip base cartridge so never u can user.
Dec 27, 2008 | Samsung CLP-510 Laser Printer
Samsung CLP-510 Engine Fuser Low Heat error
I would purchase a new colour printer, Brother make some good stuff now and put your toner on fleabay.
1 747results for colour laser printer
Apr 21, 2017 | Samsung CLP-600N Laser Printer
Samsung CLP-510 not printing?
Most probably you are using an USB cable that is either too thin (cheap cable) or too long (beyond 6ft.).
Oct 22, 2007 | Samsung CLP-510 Laser Printer
Fuser is too hot....
Samsung fuser units are very suceptible to voltage variations and get damaged easily. The fuser's thermofuse probably got damaged and became unable to read temperature. The only way to get it fis is to replace the fuser in an Authorized Service Center (ASC). Your unit has a 1 year complete warranty coverage by Samsung and any real ASC without charging you.
After the unit is fixed, get a good transient surge suppresor to help protect the unit. Good luck.
Oct 19, 2007 | Samsung CLP-510 Laser Printer
Samsung CLP-510 Laser Printer Logo
145 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
