Computers & Internet Logo
Amy Kanning Posted on Mar 14, 2017
How to make enter key drop down to next line rather than send message
Austin Parsons
Level 1:
New Friend:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Mar 14, 2017
Austin Parsons
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
8
Questions
0
Helped
2882
Points
22
Hold the Shift key and press the Enter key simultaneously
1helpful
I have a zagg keyboard with my iPad. I want to know how to write paragraphs when writing an iMessage. The up and down keys do not work. When I press enter the message is sent.
Try holding down the SHIFT button and enter at the same time, that should put you down to the next line or add as many spaces as you need from your last line of texts.
6answers
How do I get my messages from the answering machine ? What do I need to key in ?
If you are using the handset, press Menu and scroll down to the line Answer Machine with the up/down arrows. Then press the left soft key twice (Select answering machine and then play new messages). The left soft key is above the Talk button. Press End to stop the play back of messages. When there are no new messages, the above will play all messages.
If you want to access the messages from another phone, you first need to change the Master PIN from the one it shipped with and set up remote access. You do this from the handset.
To change the Master PIN, press Menu, scroll to Advanced Set and press the left soft key. Then scroll to change PIN and press the left soft key. Enter the original PIN (or the current PIN) and press the left soft key. Then enter the new PIN followed by pressing the left soft key twice. You will hear a tone and see New PIN Stored on the screen. If you do not enter the correct PIN above, the screen will return to the previous menu. The PIN from the manufacturer is 0000.
For remote access, press Menu, go to Answer Machine and press the left soft key. Then scroll to Ans. Settings and press the left soft key. Scroll to Remote access and press the left soft key. Use the up and down arrows to select Activated then press the left soft key again.
Once these are set, call your phone number and when the machine picks up press #. Within 8 seconds, enter the PIN. An error tone will play if you do not enter the correct code; try again. The unit will hang up if the PIN isn't entered in 8 seconds. All new messages will play. Press 1 to replay a message (or go to the previous message), 2 to play all messages, 3 to advance to the next message, 4 to delete a message.
The manual is available here: http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=ID9371B/37&scy=us&slg=en .
I hope this helps.
7helpful
2answers
I have a T7316E Nortel phone and we have had a lot of employees chance. I need to change the display name for each phone. How do I do that?
Programming is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.
When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change the name on.
Press the show key (top right arrow)
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
The display say Name.
press the Chng soft key.
use the dial pad to enter the name. advance using the arrow soft key to go to the next letter
ex. Bill = 2,2 -> 4,4,4 -> 5,5,5 -> 5,5,5
Press the next key (bottom right arrow) to enter the name.
Press the release key when finished
1helpful
2answers
Nortel T7316. We use auto assistant. Message picks up immediately. I want the receptionist to answer live and if she does not answer after a couple of rings for auto assistant message to kick in. How can I...
To change the number of rings enter Feature 983, if your system has 2 digit intercom #s your password is 120000 if your system has 3 digit intercom #s your password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant).
The 3 soft key selections GRTG, TABLE, and LINES
Press the LINES soft key
Enter the line number on the line you want to change ringing on (probably Line 1) and press OK
Press the TABLE soft key then the RINGS soft key
Press the CHNG soft key and enter in the amount of rings you wantand press OK
Press the NEXT key to go to the next line
Repeat the procedure for the remaining lines
Press Rls when finished
How can i enter in manufacturers configuration menu on Lifefitness treadmill 97ti
To enter the Manager's Configuration, press and hold down the PAUSE key and press the
CLEAR key twice. Continue to hold down the PAUSE key until the MESSAGE CENTER displays
the words “SERVICE MENU”. Then, release the PAUSE key, press the QUICK START
key, and press ENTER. The MESSAGE CENTER then displays, in turn, each of the configuration
settings.
Steps to forward inbox texts to email with white screen problem?
First open your phone. Press upper right (-) key to get menu. Press joystick up 1 time to get Messaging. Press joystick center select button 1 time, then down 1 time for "Inbox" (or down 3 times for email). Press center select 1 time, joystick down 1time for Inbox, center select for first message. Press upper right (-) key for "More", then joystick down 2 times to get "Forward", press center select. Press upper left (-) key to "Continue", press joystick up 1 time to get "enter email addr." Press joystick center select button, and enter the email address you want to forward the message to. After you have typed in the email address, press upper left (-) key "OK" 2 times to "Send", if you normally enter a password, type it now, press upper left (-) key for "OK" and your message will be sent. Hope this helps. -Mike
1helpful
How to send picture msg
Here's how send a picture in a message.
1. Press the Center Select Key
2. Press the Navigation Key to scroll to Messaging, and press the Center Select Key
3. Press the Navigation Key and scroll down to Create Message, and press the Center Select Key
4. Press the Navigation Key and scroll down to New MMS Message, and press the Center Select Key
5. Press the keypad to enter desired text
6. Press Options, by pressing the left soft key
7. Highlight Insert, and press the Center Select Key
8. Highlight Picture, and press the Center Select Key
9. Press the Navigation Key and scroll up or down to the desired picture
10. Press Insert, by pressing the left soft key
11. Press Send To, by pressing the right soft key
12. Press the Navigation Key, and scroll down to desired contact, and Press the Center Select Key
13. Press Send, by pressing the right soft key
You can find this, and other helpful stuff at
this page on the Motorola Support site
Don't forget to rate this solution once you've tried it !
12helpful
2answers
Enter centre?
To enter the message centre number on your mobile:
1. Press 'Menu' (Navi key).
2. Highlight 'Messages' and 'Select' (left softkey).
3. Highlight 'Settings' and 'Select' (left softkey).
4. Highlight 'Text messages' and 'Select' (left softkey).
5. Highlight 'Sending options' and 'Select' (left softkey).
6. Highlight 'Service centre' and enter either;
Pay as you go: +447802092035
Pay Monthly: +447802000332
7. Press 'Save'
display_flip('id2387', 'divId2387');
Grand Canyon Tech
Grand Canyon Tech
