SOURCE: I have an Amana Air Comand Gas furnace/AC, it's 4
Hi, If you are talking about an led light at the furnace, and it is blank, it should have a 3 to 5 amp fuse that plugs into the board. Pull it and check to see if the metal element is blown or burnt. If so, replace it. If you are talking about some other red light, please let me know. It sounds as though you have lost the 24 volt control voltage, so see if it has a fuse on the board. Keep me posted.
Shastalaker7
SOURCE: amana gas furnace,air command 80 sv. does not ignite blows cold
Hi check out the pressure switch jump it out and see if it lights also check the igntion coil is glowing
