Question about Frigidaire Washing Machines
My Frigidaire washer, fws645rbs4 does not agitate. It will spin when it is suppose to during the cycle.
gwshaw71
  • 83 Answers
SOURCE: Agitator Not Working
check your motor coupler, lid switch
Posted on Dec 07, 2007
  • 196 Answers
SOURCE: Frigidaire front load washer won't drain or spin
This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
Posted on Nov 12, 2008
  • 5 Answers
SOURCE: My model #gltr1670aso makes loud noises during spin cycle
Usually this is due to either the drum support breaking or the back bearing being bad-neither easy to fix- or worth it. Try lifting the drum up and down, if it moves up and down they are bad. I see this a lot, and the price of repair isn't worth it. Craig
Posted on Aug 02, 2009
  • 64 Answers
SOURCE: Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
THIS IS A TYPICLE PROBLEM . BETWEEN THE MOTOR & THE TRANSMISSION THERE IS A COLLECTOR ASSEMBY (THREE PIECE
SET) REAL EASY TO GET TOO EASY TO FIX . ALSO COST EFFICENT
Posted on Sep 21, 2009
aasc
  • 1606 Answers
SOURCE: Is the upper part of the agitator supposed to spin
You have bad agitator dogs . Easily replaceable and inexpensive . Remove the center bolt holding the agitator on and seperate the 2 agitator pieces . You will see 4 teardrop looking pieces ( dogs ) . Replace and your done .
Posted on Jun 29, 2010
Frigidaire topload washer inner drum not rotates during wash cycle
inner drum is not supposed to rotate . just the agitator .spin cycle is when that will rotate
Sep 28, 2016 | Frigidaire Washing Machines
Washer squeaks during agitation, both wash and rinse. also makes thumping sound for few seconds after spin cycle stops.
Hello Chris, thank you for your post!
I see that the washer on your Frigidaire laundry center is squealing during agitation. This noise could be coming from the motor or transmission and you may need to have the washer disassembled to locate which component may be causing the issue. For proper disassembly you may need to seek assistance from a professional technician. A technician will have the appropriate tools needed for complete disassembly of the washer without causing personal injury or harm to the laundry center. Hopefully this information is helpful towards your repair. -Matt
Apr 20, 2016 | Frigidaire fex831cs stacked washer&dryer...
ATF6000ES frigidaire will not spin all the time only sometimes
Mine would only spin on the fast final cycle. Wouldn't spin during any of the agitate cycles. I replaced the motor, the speed controller and the main control unit. Nothing fixed the problem. Btw, the door lock worked properly. Had to replace the washer. Sorry, I know this doesn't help.
May 28, 2014 | Frigidaire ATF6000ES Front Load Washer
417.39022890 Frigidaire Gallery Frontloader won't spin
Does it move at all in the spin cycle? If it does, try to open the door during the spin cycle and tell me if the door opens or stays locked.
Nov 20, 2013 | Frigidaire ATF6000ES Front Load Washer
Is the upper part of the agitator supposed to spin with the lower part? It spins freely when I turn it, but doesn't spin when spin cycle is activated during a cycle.
Jun 29, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Water pumps in timer cycles but machine will not agitate or spin
Hii!! yo check your washer belt.if on the you have a tranny problem.good luck
Jan 16, 2009 | Frigidaire FWS833A Top Load Washer
Agitater does not spin
the transmission needs to be replaced
Jan 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Won't Agitate
If you can hear the motor during the agitate cycle, the the transmission has stripped gears.
Dec 17, 2007 | Frigidaire FWS833A Top Load Washer
Washing Machines Logo
47 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
