My system tell me that my serial port is running at 9600 bad. My motherboard is new enough to be running at top speed. What is the problem and is there anything I can do to fix this?
  • 453 Answers
The mother board can be new enough to run at 19200 Baud rate or even more but most of the devices run at a baud rate of 9600. If the baud rate of the motherboard is increased then the communication between the device and the motherboard can become an issue.
If you still want to change the baud rate then the option will be available with the software you get with the device you are using with the serial port.
If I can know the device attached to the serial port then I can help you further.
Kindly Comment.
Posted on Jul 23, 2009
Why do i get an error window when i press read on the program for the radio????
If the interface cable has a serial port connector, and you need to use a USB --> Serial Port adapter to connect to your computer; it may be the source of the problem. The cheaper USB --> Serial adapters have issues with timings that the serial port protocols rely on. You may have luck by reducing the speed of the serial port to something like 19200, 14400, 9600, 4800 or even as low as 2400 baud. Make sure that the adapter name (COM1, AUX1, COM2, AUX2 , etc.) is the SAME one you're telling the program to use to access the radio's memory and the port's parity, number of stop bits and error checking type match the program.
Additionally, different radio manufacturers use different methods to set the radio's memory up to be read and / or written. Make sure the radio is ready to be read and the program is trying to read - not write (and vice versa).
If you're still having issues, please reply and provide the radio brand and model, interface cables and adapters, and program software and computer Operating System.
Jan 21, 2012 | Radio Communications
I had an alarm on 9390 which read : "Battery Test Fail". What would possibly cause it and how would I best prevent it from reoccuring.
This error indicates that the battery packs are no longer able to supply the expected run time or load capacity that the UPS needs. The batteries will need to be replaced.
May 11, 2011 | Powerware 9390 UPS System
Casio QT-600 Printer connection
You have to use serial communication cable If you have purchased this cable from market,it will not work.I tell you how you can make it yourself.
QT side 9pin femateConn.......Receipt Printer side 25 pin mate con
Pin 1-----------------------------------NC
Pin 2-------------------------------- 3
Pin 3-------------------------------- 4
Pin 4------------------------------- 7
Pin 5------------------------------ 8
Pin 6------------------------------ 20
Pins 7,8,9------------------- NC
After connecting with com.Port 4 initilize the QT.It should
deduct the printer. If no change the printer
Apr 17, 2010 | Casio QT 6000 Point of Sale Terminal
I need to connect cisco 2800 router to my pc through hyperlink
I think you mean hyperterminal? you need a cisco serial cable (blue) and a serial port on your PC, maybe a USB to serial adapter if there isn't one. Set hyperterminal to use the COM port you have plugged in to, speed 9600 8 bit no parity. (8N1).
Without the serial cable you need to know the router IP and password.
Oct 31, 2009 | Cisco (UBR904) Router
Running two Zebra's through Easylabel Platinum
When connecting Easylabel to a Zebra through the RS232 port, it's very important that the serial settings match between Easylabel and the printer. Easylabel defaults to 9600 baud, 8 data bits, none parity. The Zebra defaults to 9600 baud, 7 data bits, and even parity. This mismatch causes the data light to flash but no print.
Change the printer setting to 8 data bits and none for parity and the baud rate can be whatever but make sure they match from Easylabel to the printer.
Hope that helps !
Sep 18, 2009 | Zebra 140XiIII Plus Thermal Label Printer
How i can connect brocade silk worm3900 to serial port onlinux
You can use the COM ports to connect the serial connection to the Linux. And also use the minicom in the teerminals to open the serial console. the baud rate needs to be fixed in 9600
Jan 26, 2009 | Brocade Communications Systems SilkWorm...
Fail to configure metrologic usb barcode scanner to use virtual RS232 port interface
First check the com port speed of computer port which you connected scanner .Com port speed should be 9600.
To change com port speed in computer go to computer/properties/device manager.
Select the ports eg com1 .Right click communication port go to properties and select port settings Bits per second should be 9600.
Serial scanner can not be test in word or note pad.you can download the RS232 software from below link and test the scanner
http://www.lookrs232.com/
Oct 30, 2008 | Metrologic Instruments MK9540...
Printronix5003H+ table mismatch
I'm sure you have fixed your printer by now... but reflash the printer.
Flash memory is contained in SIMMs (single in-line memory modules) located
on the controller board. Printer emulation and operating system software are
loaded into flash memory at the factory, but you will install software in some
situations:
• The customer buys the PGL or VGL graphics, Expansion-CT, or IPDS
option after the printer is installed
• The customer needs to upgrade printer software
• The customer needs different emulation software
• You have replaced the controller board
• You have added or replaced the flash memory SIMM
Emulation and operating system software are stored as a compressed file on
a 3.5 inch floppy diskette. This file is “executable.” You will expand it and copy
it into printer flash memory.
You can load software through the serial, parallel, or Ethernet port of the
printer.
1. If the printer has an Ethernet interface, refer to the PrintNet User’s Manual
for the download instructions. You are finished with this procedure. If you
are going to load memory through the serial or parallel port, continue with
this procedure.
2. Make a printout of all saved configurations. (Refer to the User’s Manual.)
(Installing new software erases all saved configurations. You will use the
printouts to restore printer configuration.)
3. Set the printer power switch to O (off).
4. If the printer is already connected to the serial or parallel port of a
computer capable of running an MS-DOS® based PKZIP® self-extracting
file, go to step 11. If not, go to step 5.
5. Unplug the AC power cord from the printer.
6. Disconnect all data input cables from the printer interfaces.
7. Connect a parallel data cable to the LPT1 port or a serial data cable to the
COM1 port of an IBM-compatible computer that is using the PC-DOS™ or
MS-DOS operating system.
NOTE: You can connect the cable to the LPT2 port if the LPT1 port is alreadyin use. The load commands are different if you use this port, as
described in the note after step 18.
8. Connect the data cable to the appropriate I/O port of the printer.
9. Plug the AC power cord into the printer.
10. Power on the computer.
11. Insert the emulation or upgrade diskette into diskette drive A (or B) of the
computer.
12. Make the diskette drive the active drive by typing the following at the DOS
prompt:
A:<return> (If the diskette is in drive B, type B:<return>)
13. Get the name of the compressed file on the diskette by listing the
contents of the diskette; at the DOS prompt type:
DIR<return>
The compressed file on the diskette takes the form FILENAME.EXE
Now write down the complete name of the file with the .EXE extension.
14. On the printer control panel, press and hold down the ON LINE + PAPER
ADVANCE keys. Without releasing the keys, power the printer on.
Continue holding the ON LINE and PAPER ADVANCE keys down for five
seconds, then release them.
NOTE: The port default is CENTRONICS; this is the standard load through
the parallel port. If you want to use the default, continue at step 18.
15. When you see “WAITING FOR PROGRAM DOWNLOAD” on the LCD,
press the < (NEXT) key. “SELECT DOWNLOAD PORT =
DATAPRODUCT” appears on the LCD.
16. Press < (NEXT) again to cycle through the download ports available in
the printer:
DATAPRODUCT (parallel)
CENTRONICS* (parallel) (default port)
RS232-9600 (RS-232 serial, 9600 baud)
RS232-19.2K (RS-232 serial, 19200 baud)
RS232-38.4K (RS-232 serial, 38400 baud)
RS232-115K (RS-232 serial, 115000 baud)
RS422-9600 (RS-422 serial, 9600 baud)
RS422-19.2 (RS-422 serial, 19200 baud)
RS422-38.4K (RS-422 serial, 38400 baud)
RS422-115K (RS-422 serial, 115000 baud)
17. When the printer download port you want to use is displayed on the LCD,
press ENTER. “WAITING DOWNLOAD / PORT = <your selection>
appears on the display.
18. At the DOS prompt on the computer type:
FILENAME.EXE -pb<return>
where FILENAME.EXE is the compressed file you noted in step 13. This
command decompresses the file on the diskette and copies it as a binary
file into the flash memory on the printer controller board.
NOTE: If you are loading the file using the LPT2 port on the computer, enter
the following DOS command:
FILENAME.EXE -pb 2 <Return>
The 9600 baud rate is the only selection older versions of DOS can
use. The baud rate information entered in the following DOS
commands must match the selection you made in step 16.
the load process and status. (LCD messages are listed in Table 2,
page 37.)
CAUTION Do not interrupt the downloading process once it has started.
Interrupting a download will damage the flash memory on the controller
board and PrintNet card ( if installed).
19. When the new program has successfully loaded into memory and the
printer has reset itself, set the printer power switch to O (off).
20. Unplug the AC power cord from the printer.
21. Remove the diskette from the computer and store it with the printer.
LineMatrix
www.sinca.biz
Toby
Jul 07, 2008 | Printronix Line Matrix P5215 Printer
Cajun P333T doesn't accept input from serial
All info from juliankov appears good.. but thought I'd add a bit of stuff I found on a web site..
http://www.tek-tips.com/viewthread.cfm?qid=300461&page=2
Use a console cable with following minimum pinout (the flat gray one with the RJ45- D9 type converter currently shipping with new P33xx switches will suffice): DB9 Console Port
1 ----------- 6
2 ----------- 3
3 ----------- 2
4 ----------- 4
5 ----------- 5
6
7 ----------- 8
8 ----------- 7
9
Obviously the speed is set to 9600
maybe stop all sessions & try to re-establish a new one. The instruction manual warns u can only run one..
Mar 10, 2008 | Lucent Cajun P333T Networking Switch
??????????? printer doesn't stop printing, help!
Turn off the printer. Hold down the power on button for 20 secounds. Did that clear it up Pete ??
Jul 01, 2007 | Epson TM-L90
201 people viewed this question
jasbo
jasbo
