Question about Frigidaire FRT17G4B Top Freezer Refrigerator
Same issue ... cubes wont release from the fingers.
They rotate to the top and then get stuck
    Scholar:
  • 117 Answers
Try setting the ice cube size .This is an adjustment you can make by taking the front of the ice maker off and adjusting set screw.
Posted on Jul 24, 2009
Only the light comes on. The transformer hums
cus it don't know the words !! sorry couldn't resist , anyways if the engines head light gets to full brightness and the engine wont go ,and the transformer does not trip out . then your problem is the motor drive is stuck , this may require one to un screw the top off engine and manually rotate the motor over with your finger , if it wont turn with one finger then you have a foreign object stuck in gear reduction box you'll need to find that and clean it out (wd40) great stuff 4 me its always pine needles as mine runs under the tree each year and those little things get in mine all the time
Feb 20, 2016 | Crafts & Hobbies
Ice maker not getting water on new refrigerator
Check if the unit has a cold water dispenser that it will fill a cup. If so than problem is with Ice Maker. If not than problem is with water supply to unit.
If water to machine works make sure that the arm on the ice maker is in the down position. If it is up it will disable the ice making unit. Cycle the am a few times to insure that the switch connected to the arm has not gotten stuck in the off position.
On some ice makers there is a separate switch to disable the Ice maker usually right on the ice-maker not easily missed.
It is possible that the water feed tube into the Ice Maker has become frozen where it enters into the back of the freezer at the top. You can look through to see where the water fills into the cube tray. If ice is present it would be an indication that the feed tube has become frozen If suspected the safest way to fix would be to turn off the unit and allow for a manual defrost.
Next check the operation of the ice maker. Locate the arm in the up position prohibiting the ice maker from cycling. Wait three hours or more. Open freezer door and return the arm into the down position. After a few minutes you should observe the ice fingers rotating to release the cubes into the tray. If the fingers do not rotate I would suspect the ice maker or the connecting electrical circuit. Remember after dropping the arm the Ice Maker has to warm up to melt the ice cubes from the tray before the fingers are told to rotate,
If the fingers rotate then I would expect that the water supply solenoid has failed inside of the unit near to the location the the water supply is made. Replacing this part needs to be done by a qualified experienced technician.
Nov 15, 2015 | Refrigerators
Kitchenaid ice maker full of ice but won't release it
What is the model number of your unit?
Nov 29, 2012 | Refrigerators
Ice maker makes ice but will not rotate and dump the ice.
You have a thermostatically controlled heat release ice maker. Any number of issues can cause a failure to "dump" the ice. The harvest is started when the thermostat closes. A motor rotates the ejector fingers which are at rest in the 2 o'clock position. The ice maker operation will stall until the heater releases the ice from the mold. After the cubes are ejected into the ice bucket, the water valve will refill the mold with water to begin the next cycle. Lack of ice dispensing could be a failed thermostat, heater, motor or switch contact withing the ice maker module. You could simply replace the ice maker and save the expense of the service call.
Dec 29, 2009 | Maytag MSD2756G Side by Side Refrigerator
GE side by side CAN17 ice maker...white ''finger assembly'' that pivots has broken two fingers, and the ice cubes are stuck in the cube dispenser. Any ideas why this happens, and how to fix it without...
You will need to replace the icemaker. The sensor that activates the heat coil in the icemaker is bad. The heat sensor allows the cubes to be released from being frozen to the ice tray. Check ebay for a new icemaker. About one third the price of manufacturer for new factory unit.
Oct 27, 2009 | GE Refrigerators
Ice maker fingers got jammed by a small cube, iremoved jam but fingers remain stuck halfway
Hi.
Press on the half-moon cube dividers, just watch your fingers in case it starts to move. It's jammed, and you can usually get it going again like this.
Best regards, --W/D--
Aug 18, 2009 | Whirlpool Refrigerators
Mod. GS6NBEXRS01 not dumping ice. there is ice in the ice-maker. the dispenser for the water working ok.
take the bin out and check for a jammed ice cube in the ice cube making mechanism. Many times they have a rotating finger that gets stuck on a cube that does not drop entirely. Hope this helps
Jul 13, 2009 | Kenmore 74252 / 74254 / 74259 Top Freezer...
Wii wont play disk
When the Wii takes in a disk two metal fingers rise up to block the opening. These probably got bent when your two year old tried inserting the second disk. If they are bent they will rub the edge of the disk and prevent it from rotating. If a smaller game cube disk will work then bent fingers is the most likely problem. They can be bent back out.
Feb 28, 2009 | Nintendo Wii Console
Crush to cube
I have this problem aswell. I correct it by reaching up and removing the 1-2 cubes with my finger that were stuck in the area where the cubes drop into the glass. Seems the sensor is blocked and cannot switch back.
Aug 19, 2008 | Frigidaire FRS3R5EMB Side by Side...
Ice cube tray not releasing cubes
The ice maker system is pretty simple.. A motor rotates with a gear reduction system and as it rotates... a switch is tripped when the motor reaches a certain point on its rotation... that switch lets water in for a prescribed period of time ( normally that is adjustable) and then as the motor rotates some more.. the ice tray has had adequate time for that ice to freeze and is positioned for it to be released,..at that time.. a small heating element is energized to release those ice cubes and the cubes fall from the tray into the bucket.. Chances are your heater is not working, unplugged or defective.. I would start by thawing everything out and getting the system free of any and all ice.. If after you've cleaned it all up.. and it still fails to release ice..you could be over-filling your tray and that freezes .. which in turn causes the system to fail too..You may need to adjust the fill level by throttle back on the water or if your system has a fill level control.. adjust that.. but first things first.. get the system back to a known good state.. ( meaning free from all ice ) so that you can monitor its performance,. Hope that helps...
Aug 16, 2008 | Samsung RS2578BB Side by Side Refrigerator
Frigidaire FRT17G4B Top Freezer Refrigerator Logo
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
