Question about Welding Tools
Torch is used for jewelry work and is a acetylene air torch. the torch keeps going out when lite. also would like to know how to adjust the air flow on the tips and what it should be. thanks
    Brigadier General:
  • 4,088 Answers
Usually, the blow-out problem is caused by excessive fuel flow at first--too much pressure or valve is opened too far. Once you have a bushy acetylene flame, turn up the air source to bring the flame down to a fuzzy point near the tip end. Brazing and silver soldering work better with just a little less air. My experience is with an oxy-acetylene torch, but results are similar.
Posted on Jul 23, 2009
Map flame is good, when oxygen is increased, there is hesitation and constant in out flow of oxygen , then POP , flame goes out. i changed both oxygen & map canister. I placed tips in boiling...
Hi:
Probably you are doing everything right but are you sure you are using the right tip for acetylene? Because it sounds like you have a defective tip or a clogged one.
Sep 07, 2011 | Smith 23-1001C OXY/ACETYLENE LITTLE TORCH...
Hi there, despite brand new torch, brand new regulators and gas tanks, I cannot get a decent hot flame on my oxyacetylene torch, and what flame I can get, goes out within seconds of heating a...
Hi:
If your flame goes out check the following:a) check your acetylene and oxygen pressure, for this kind of job acetylene should be at 4 psi and oxygen at 10.b) Check you're using the right type of nozzle for the job and this nozzle is clean.
Apr 04, 2011 | Smith 23-1001C OXY/ACETYLENE LITTLE TORCH...
What do i have to do to convert a n acetylene torch to use propane?
usually I have just changed to the appropriate brand of propane tip for that style torch IE: if you use a victor torch take out the acetylene tip and replace it with a propane one making certaing the seats are correct.
Mar 27, 2011 | Victor ® 000TE Replaceable Tip End ®...
It will lite and run for about 30 seconds and go off. If I take the top off it will lite and keep on running. but if i put the top back on it will go off.
Check the fuel nozzle for a partial blockage. I use torch tip cleaners to make sure they are clear. Don't use one that will make the hole bigger, you want one slightly smaller than the hole. Also check the fuel filter. Check both air filters also. After that you need to check the air pressure going to the fuel nozzle. Install an air pressure guage in the port with the plug that doesn't have a small hole in the center in the filter cover behind the motor. The plug that has a small hole is the one you use to adjust the air pressure. The pressure you need will be listed on the label of the heater.
Jan 17, 2011 | Reddy Heater-170,000 BTU Kerosene Deluxe
Vacuum leak
I don,t know where your vacuum leak is but if you have access to an acetylene torch then you can use it to find the leak.Simply turn on the acetylene only and then run the torch tip around all of the fittings and lines until the engine revs up,that will be your source of leak.Let me know how you make out.
Aug 25, 2010 | 2004 Chevrolet TrailBlazer
I have a Miller Synchrowave 180 sd and have been having difficulty welding aluminum. Can you please help.
I'm not sure what it's doing to know why it's not working but if I was trying to weld aluminum I use 100% argon in ac with high frequency continuous and a 9 second post flow with 5356 crown weldind rod.
Jun 05, 2010 | Miller Welding Tools
Repair a leak
Let me cut to the chase. You may have saved yourslf $50 by finding the leak. But by law(Sec 608) federal, you can't go further unless you are EPA Certified. And then you would need Air conditioning grade Brazing material,(way stronger than plumbing solder), Oxy\Acetylene torch, a reclaiming unit, and a vacuum pump, R22 refrigerant that you need to be certified to buy, Gauges, the list goes on and on. Unfortunately you'll have to bite the bullett and spend probably a couple hundred dollars. Sorry, but I'm shooting straight here. Good luck
Jul 13, 2009 | Whirlwind FH-778 Air Conditioner
Welding Tools Logo
144 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
