Question about Garden
Need a new part for my ryobi air filter box is cracked and broken need to replace the hole air filter box not just the front cover can not find the part anywere
  • 132 Answers
Yeah a repair shop can sell you one
Posted on Jul 23, 2009
I am missing the air filter for my ryobi s430 trimmer and cannot find a replacement on their website-any suggestions?
Uninstall old filter replace the filter with a custom fit piece of like pillow foam
Jul 24, 2014 | Ryobi Garden
I have a Ryobi 1079r that will not stay running. I found several cracked plastic gas line so I replaced all of them. I used a spray carburator cleaner as well. The unit will start if I spray a starter...
The carburetor may have inhaled some trash, debris or parts of fuel line. Remove the cover on it that does not have the vent-hole in it. Inside on the carb body you will see a very small fine-mesh filter screen. Make sure it is not covered with debris. If so, clean it up and replace cover. This commonly gets dirty and needs to be cleaned after lines deteriorate.
Dec 04, 2010 | Ryobi Garden
Ryobi 31cc 18'' 790r ez has no power
You have done just about all you can do with this machine give up and buy a new one
Jul 08, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
My ryobi grass trimmer will only run on 1/2 choke model RY 30524
Check for fuel supply problems (clogged cap vent, dirty tank fuel filter, clogged or faulty fuel intake lines, leaky or cracked primer bulb, air leak in rear crankcase cover...check 4 screws above gas tank, air leak in carb gasket...check carb nuts, trashed up carburetor...needs cleaning or rebuild, mixture screws need adjusting)....a myriad of possibilities here but I would guess it's a dirty carb....hope it helps
Jun 27, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
My ryobi trimmer want hit a lick. The spark plug is firing. But will not hit. I tried a small spray of starter fluid in the carb and still nothing. Could this be the fly wheel is out of time ?
Try removing the air filter...hold throttle open and either squirt or pour about a teaspoon of FRESH fuel mixture into the carb throat...be sure that the fuel enters the cylinder through the throat....hold the throttle open and pull start handle and if you have spark it should start and run for a few seconds...if not you may have an electrical problem (weak magneto = weak spark ) ... if it starts and runs your problem may be in the carb (clean or rebuild) DO NOT use starter fluid to do this test...it is too volatile and you may blow the head right off your machine...also check the four screws on the rear cover (the four screws above the gas tank) they may have loosened and are allowing an air leak at the rear of the crankcase. these covers are plastic and have a tendency to warp under the heat generated by the engine. There is a gasket between the cover and the metal crankcase, and if the cover is warped it may be letting air through into the case....can cause a no start situation. do a cursory inspection of your fuel lines , fuel filter, and the primer bulb and check tightness of the carb bolts as cracks here also allow air leaks in the fuel system. If you've been using starting fluid to try and start your engine you might also want to check the head gasket and front crank seal to make sure you haven't blown a hole in them...good luck...;-D
May 15, 2010 | Garden
Replacing broken gaslines... were do they go?
the primer bulb draws gas through the carb 'C' and back to the tank'T' leaving a small amount of fresh gas in the carb.to replace the lines from filter to carb & bulb to tank,you may have to remove handle & split the housing halves to find where lines enter tank.look in tank W/ a flashlight.to replace lines cut new line on an angle,feed a piece of # 14 copper wire through hole from inside tank.slide new line over wire,the wire will help align fuel line with hole.use needle-nose pliers to push line into tank,& to pull it through once you can see it.cut off end of hose you beat up with pliers.push filter on hose to carb.drop it back in tank."T' line is the return.dosn't matter which line is through top or bottom hole.
Sep 21, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Gas line cracked and nipple fell back into tank ..how do I remove gas tank to replace gas line and nipple????..ryobi 725r trimmer
Empty the tank by dumping into a can or something. Shake the trimmer around until the "nipple" falls out. Get a replacement fuel line and follow their instructions. When yoou put the tube back into the tank, have something that you can guide the line through the hole with. I used a small hex wrench. If you cut the tip of the tube at a sharp taper, it will be much easier to start through the hole. You might think of replacing the return line as well. You should not have to remove the tank if you expose the carb and remove the air filter...Good luck...Lee
Aug 02, 2009 | Ryobi Garden
2009 TOYOTA COROLLA SE
it is located behind the glove box. remove the screw holding the strut on the glove box. Squeeze sides of glovebox together to remove from dash. look into hole where the glove box was There is a removable panel for the air filter. take it out and pull out the filter. make sure you note which way the filter is oriented. push in new filter and replace cover and glove box.
May 11, 2009 | 2003 Toyota Corolla
Ryobi line cutter - petrol lines all broken
Petrol lines disintegrate when fuel is stored in the trimmer for long periods of time. These can be obtained from any small tool repair store. Just remove them and install new ones. They just slip through the holes in the tank, re-attach the fuel filter on the supply line. Make sure that the line is long enough so that the filter rests on the back/bottom corner of the tank. Be sure that the lines are attached to the proper ports on the carb>
Dec 22, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 2 cycle gas trimmer 705r/725r
The gas nipple that come out I have...whats goes in the other hole?
Aug 28, 2008 | Ryobi Garden
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
