Question about Hampton Bay 73554 Antigua Ceiling Fan
The black transformer in the lower portion burns up
I have now replaced 4 Antigua fans due to the black transformer burning up. Some of the fans have worked for months and other 1 day.
My fan has a light kit and is controled by two regular switches on the wall (not a dimer). In the housing I attach the fan to the light fixture is where the black transformer box is located that keeps burning up. It melts wires into the box or buldges out to the side.
I have had other types of fans in the same location in previous years but never had this problem. Any idea why.
  • 2 more comments
  • Anonymous Dec 16, 2007
    I have the same problem. Got to one and now none. The black transformer refered to is actually the capacitors in a black case. It is marked PQC-1. This is wired to the motor speed switch. My fan is mod.# AC 5540 D / Ser. 003777 0G. I can easily replace it if I can find where to get another one. Please advise.
    Jobe103@aol.com Thank You.
  • Anonymous Jun 16, 2008
    where can I find a black transformer for my ceiling fan? Mine burned up
  • Anonymous Jul 09, 2008
    Black transformer is burned up.
  • Dan Todd May 11, 2010
    So, one wall switch controls the fan, and one controls the lights? Please tell me how many wires and what colors come out of the ceiling box; then tell me how you have them hooked to the fan.
Cerfer39
  • 709 Answers
SOURCE: wiring ceiling fans to wall switch
Hi Bigelow,
You need two switches.  It sounds like the Electrician set up the junction box for two circuits(Lights and Fans).  i say this because your supply has 4 wires, Red , Black, White and Bare. We may be able to oversome this with one Lutron Switch. Allow me to investigate, and I will be back.
Posted on Oct 29, 2007
aborcass
  • 2651 Answers
SOURCE: Need Wiring instructions
no problem just wire the black to black and white to white. connect the ground and cap off the blue wire, its used only for ooptional light assy
Posted on Apr 03, 2008
  • 25 Answers
SOURCE: trying to find light kit for Model 56-ANTm Flemish Brass
check the kit at home depot, get name and phone number of manufacturer and call them to see if they can supply the glass that you want.
Posted on Jan 15, 2009
  • 37 Answers
SOURCE: How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
Posted on Jan 27, 2009
  • 234 Answers
SOURCE: Wiring/Replacing pull chain ceiling fan switch
Sounds like it to me that the netual is not there.
Posted on Mar 13, 2009
How do I fix the fan?
The fan's power comes from a multi output transformer.
Either the fan is burned out or the transformer is burned out or the fans moles plug is not plugged in properly.A simple voltage spike or brownout can take out the transformers.
Feb 27, 2015 | Rinnai Toyostove Direct Vent Heater:...
CS Code
cheak door hindge mechnizem
Oct 08, 2008 | Amana RC17 Microwave Oven
CS Code
Inspect foil side of HV board for burned tracks toward lower side of board. If burned, check HV capacitors (High Voltage Capacitor Test Procedure) and HV transformers (High Voltage Transformer Test) for a short. Otherwise test other components as outlined above.
Solution: Replace defective components as necessary. If applicable, repair foil trace on HV board.
Hope that helps.........
Aug 29, 2008 | Amana RC17 Microwave Oven
Radiator cooling fan stop working, wires burned is green wire or black wire hot and if you ran it straight to battery with a toggle switch can it work?
Theoretically yes, but it won't last long. Try the relay on the frame rail under the lower portion of the air cleaner.
Jul 21, 2011 | 2000 Plymouth Grand Voyager
My tv smelled like plastic was burning and then the screen all of a sudden went black but i could still hear the audio.
Your backlight inverter board has failed. This may be due to a bad capacitor which is easy to repair, or the inverter transformer may have burned out, in which case it may be replaceable or the complete inverter board will need to be replaced.
Feb 14, 2011 | Westinghouse SK-32H540S 32 in. LCD TV
Where can i order a new motor for this model
Check this response from 2008 for same model fan.
By resorrowsr on Oct 26, 2008
Fan stopped Turning - Removed fan to check all the connections. All the connections were good. When you turn the fan on, you can hear a humming sound. If you take off the blades you can spin the motor and it will work, but will not turn on it's own.
    • resorrowsr
    • 2 years ago
    I called Home Depot customer service. I had my receipt, so they gave me store credit for the full purchase. Since I have two fans, they wanted to know if I wanted to replace both fans. I told them one was still working fine, so I only replaced one. My problem was the transformer. You could see where it had overheated and melted.
http://www.homedepot.com/webapp/wcs/stores/servlet/Search?keyword=Hampton+Bay+73554+Antigua+Ceiling+Fan&langId=-1&storeId=10051&catalogId=10053
Jan 30, 2011 | Hampton Bay 73554 Antigua Ceiling Fan
Problem with my AC unit
Hi Phillip,
Check your thermostat wires to see if you have any of them which are bare and touching. If any are touching separate them and tape em up and try unit again. You have a direst short in your cooling portion of the unit.
Feb 12, 2009 | Ruud UAMB Air Conditioner
Ceiling fan power
It sounds like the fan motor has blown out. Is this an old fan? The motors do burn out every 5-10 years, depending on the brand and quality of motor.
Apr 14, 2008 | Hampton Bay 73554 Antigua Ceiling Fan
I see only horizontal line on TV Samsung CK-5339ZB
h/line is due to vertical section failure. 1 reduce brightness as you will get h/line due to vertical failure. 2 check v/section for loose contact or yoke connection. 3 check supply to vertical section. 4 check associated parts in v.section 5 at last check for vertical ic. resistor R410 CONNECTED TO high voltage transformator T444 is low value resistor. .5ohm to 10 ohm. it burnt again due to short cht in vertical mainly due to ic. hope this will help. as per schematic diagram go to www.serviceinfo.com
Oct 04, 2007 | Samsung TXN3271HF 32" TV
Tv burn out
it might be due to high voltage in tv. you must have smell like burning. do not worry it happens so many times due to failure of transistor or fly back transformer.or some capacitor gets shorted. call skilled tech to fix it it is not a major problem. you may see fuse blown or has become black but do not try to replace it as it has blown due to something is short.unless you are a tech person as tv is chrged thiogh it is off. hope this will help. good luck.
Sep 29, 2007 | Philips Magnavox TP3285C 32" TV
Hampton Bay 73554 Antigua Ceiling Fan Logo
167 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
