Question about Panasonic DMR-EX75EB-S DVD Recorder/HDD Recorder
Panasonic dmr ex75
When switched on the machine after making several attempts to start, opens the turntable though no disk is present. HDD ERR is displayed and am unable to access any other functions except to close the turntable after which DL ERR and FM LIST are flashed on the display panel.
Help if you can please.
  • 13 Answers
Re: panasonic dmr ex75
HDD ERR is quite a serious error, as it means there is a hardware problem with the internal disk drive. You could try switching off the unit and disconnecting the mains cable overnight, and trying again, but really this will need to be a call to an engineer.
If your unit is still in warranty call them now to arrange a fix. To find your local warranty centre, go to your regional Panasonic website, and look under Customer Support
Posted on Dec 30, 2007
0 characters
3 Points
What does U81 mean
It could mean there is a fault on one of the circuit boards. See
Aug 25, 2014 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
The DVD player on my Panasonic DVD DMR-EX75 is not working. It no longer is able to read the DVD disk. Is it worth repairing or replacing the DVD drive? The system also has a large Hard Drive which still...
It is up to you, if you are able to obtain a replacement DVD drive for this model series, and it isn't too expensive, go ahead. There may be tips on installing the DVD deck on other forums - or it might be really simple (a DIY job) - or for extra labour costs, a qualified technician can fit it for you in a service centre.
So the short answer is YES it is worth repairing since the HDD is still functioning - if you are concerned about that as well as the DVD drive, get the whole unit assessed by a workshop; they can advise you further.
A second opinion always helps in a case like this, but I would recommend trying to obtain a replacement DVD drive for this model, either locally or by ordering online. This one IS fixable.
May 28, 2011 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Panasonic DMR-EX75 has stopped receiving digital signal
Panasonic DMR-EX75 has stoped receiving digital signa
Aug 01, 2009 | Panasonic DVD & Blu-Ray Players
Read failure o DVDs on Panasonic DMR-EX75
You need a lens cleaner to clean the lens of ur DVD recorder..
Dec 09, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Blu-ray remote keeps triggering DVD recorder (and vice-versa)
You can "re-tune" your EX75 and its remote control by following the instructions on page 52 of the manual. This explains how to change the mode of the remote control. In short, you press the FUNCTIONS button on your remote control, get into the setup menu and select "others". The remote control entry is at the top of the list. You can change the setting from here.
May 22, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Recording and viewing different channels
The EX75 has only one tuner circuit, so you can't watch a different channel from the one you're recording. To do this you will either need a set-top box for Freeview or a Freeview compatible TV.
Apr 10, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Time change
I pressed all the buttons on the remote control untill I found the right ones. It was trial and error.
Apr 01, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Remote interacting with TV
According to my manual the codes for Samsung TVs are 31, 32 or 43.
Press and hold the TV on and off switch button.
Enter the two-digit code for your television set (while holding the TV power on the remote)
Nov 11, 2007 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Panasonic DMR-EX75EB-S DVD Recorder/HDD Recorder Logo
685 people viewed this question
Top Panasonic DVD & Blu-Ray Players Experts
Are you a Panasonic DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
