Question about D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B)
Telkom Mega 100WR Router which doesn't show DSL light
This router doesn't appear to find a DSL connection on my line,but my old usb modem works fine.The Telkom modem worked fine until a few days ago.Modem definately not faulty as it works fine on somebody else's line.Today i was advised by a Telkom technician to change the modulation on my router to ADSL_ANSI_T1.413 leaving all the other options that were ticked, now unticked and now the modem works again.Does leaving the other options unticked affect your DSL performance and does it mean that there is still a problem with the line @ the exchange ?
NO_MODE ADSL_G.dmt ADSL_G.lite ADSL_G.dmt.bis ADSL_G.dmt.bis_DELT ADSL_2plus ADSL_2plus_DELT ADSL_re-adsl ADSL_re-adsl_DELT ADSL_ANSI_T1.413 MULTI_MODE ADSL_G.dmt.bis_AnxM ADSL_2plus_AnxM
rahul26485
  • 611 Answers
SOURCE: how to connect ADSL 2 modem to Wireless Router
just change the ip address in the router and give the proper settings in the router
Posted on Apr 04, 2009
Gort007
  • 1187 Answers
SOURCE: I have an ADSL D-Link modem (DSL-300G)that works
First: Connect your computer directly to the ADSL modem. It has an Ethernet port.
If you can't get to the Internet while your computer is connected directly to the modem, then ytour router never will either. Call ISP if you can't connect to the Internet when directly conencted to the modem.
Next: Check your router wires again, The modem must be connected to the "special" port on the router. Look at the router. There is one port separated from the rest. Connect the modem to that port. Conenct to the Internet.
Still no Internet?
Reset your router by pushing a stylus (straightened-out paperclip) into the reset "hole" on the router (with router powered ON).
Push & hold for 30 seconds or until the lights do their reset dance. Connect to the INternet.
Posted on Oct 07, 2009
ryuho
  • 75 Answers
SOURCE: how to forward port on telkom mega 100wr router
You have two options:
1. You can open port using router's web interface. Check what ports used your software, what protocol TCP/UDP/BOTH then go to web interface's virtual server and add new user's rule. Then you have to save and reboot router. Every time your PC IP changed (static IP recommended) or program you using changed port number you have to do web interface operation again.
2. Download and install Router Commander (fully compatible with your router) and that's all. The software will forward ports automatically
Posted on Dec 29, 2010
DHINCE10
  • 169 Answers
SOURCE: i have the telkom mega
The link provided below will help you downloading the software/driver that you need.
http://www.softitem.com/driver-telkom-mega-100wr-software
Posted on Mar 22, 2011
JaxPlanet
  • 922 Answers
SOURCE: I installed my D-Link DI-784
It is possible that a neighbor purchased a wireless access point that it on the same channel and they are competing. Change your wireless channel. You could also try a hard reset. Instructions at D-Link's website. Good luck!
Posted on Apr 08, 2011
How to forward port on telkom mega 100wr router
Nov 05, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Conect the router?
1. Unplug your DSL modem’s power supply.
Find the cable connecting your modem and computer.
Unplug it from the modem and plug it into the gray port
on the Belkin Router.
If you are replacing an existing router, find the cable
connecting the computer and old router. Disconnect it from
the old router and plug it into the gray port on the new router.
2. Connect the new cable (provided in the box) to the yellow
port on the Router.
Plug the other end into the modem.
3. Plug in your modem’s power supply. Wait 60 seconds for the
modem to start up.
Plug the Router’s power supply into a wall outlet, and the
other end into the black port on the Belkin Router.
As the Router wakes up, lights will come on; recheck your
connections if the “power” and one of the “wired” lights
are not lit up in green after 20 seconds.
4. Locate the CD in this guide and insert it into your computer.
The Setup Assistant should appear automatically.
If it doesn’t, open the CD in My Computer and double-click on the
“Setup Assistant” icon.It will guide you through he rest of the setup.
If you need more help please post back,If this help please rate as a fixya.
May 17, 2009 | Belkin (F5D72304F5D7000) Router
Connecting a wireless router to Tiscalli broadband connection
  1. USB modem is connecting a PC USB port with a DSL phone line: CANNOT be connected to a ROUTER LAN (ethernet NOT USB port).
  2. Wireless ROUTER is NOT a modem and it CANNOT connect the Internet (or WAN) LAN port to any "phone line"
  3. Connect the Router Internet (WAN) port to Modem (you need a LAN MODEM = a modem with a LAN/ETHERNET port)
  4. Be sure your internet is running before strting ROUTER configuration with Router Company CD
Jan 05, 2009 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
Trying to hook up a Linksys Wireless -G 2.4ghz Broadband Router. Want to link my dsl and my xbox and then later down the road a lap top. Dont know where to begin. Do I take the phone line thats inthe wall...
first you connect the wire from the wall into the wan port in the back of your dsl modem. next you connect the outsource wire from your dsl modem into the wan port on your router. next put another rj45 wire into the number one port in the back of your router and the other to your computer. put another wire into number 2 and then to your xbox. everything need to be unplugged while you are hooking it up. once done power cycle...meaning plug up the dsl and wait for the lights to stay lit. then the router. the start your computer. if you want to go wireless just get a usb wireless network adaptor and there you are
Oct 19, 2008 | Computers & Internet
X6 won't pick up DSL
hopefully you haev installed the software first on yoy computer>
turn off the computer. connect the phone line one end to the ethernet port on your computer and the other end to one of the LAN port on the x6.
power up the (power cube shipped with the X6), the Pwr and the WLAN should come on and become steady, the LINK light should blink,
turn on you computer, connect a new phone line between ADSL port and the wall jack, the LINK light should become steady.
please rate the answer if it solved your porblem.
thank you
Sep 09, 2008 | Zoom X6 (5590) DSL Modem (55900003)
D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B) Logo
478 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
