Question about Crosley CAWC529JQ Top Load Washer
Crosley CAWC529JQ1 top load washer sounds like a cement mixer!
I have Crosley CAWC529JQ1 top load washer. It washes fine, but when it spins it makes a brief but loud scraping noise once for each revolution. When it gets going fast, it is louder than a cement mixer!!!
At the end of the spin cycle, when the brake operates, the same-sounding noise is continuous until the spin stops.
That seems to narrow the noise source to the brake mechanism.
I don't know what damping pads do, but I think the brake band area might be misaligned somehow, and the brake band padding has worn out, thus is now scraping metal-to-metal once per revolution. I'll take a look, and post what I find ...
Anybody else had that problem? What was your solution?
  • 105 Answers
Sounds lik the main bearings are faulty and needs a strip down to replace parts otherwise another machine may be in order
Posted on Mar 16, 2008
Spin light is blinking on my crosley washer
check belt is not Brocken filter is cleaned also can be the motor not turning check brushes or that the motor is not burned
Aug 13, 2014 | Crosley caw9244xq 3.4 cubic foot white...
Hi my washer moter works but spin cycle is not working Every thing else is O. K Thanks
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
Mar 29, 2011 | Crosley CAWC529JQ Top Load Washer
My washing machine will not rinse or spin in any mode
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
Nov 13, 2009 | Crosley CAWC529JQ Top Load Washer
Crosley CW6000 Washing Machine. When my washing machine is in the spin cycle, it shakes severely and the machine on the floor
My Crosley Cw6000 wash will not spin the water out, I lift the lid to watch the spin cycle, it spins but the water does not drain..
Sep 02, 2009 | Crosley CW6000 Front Load Washer
Hotpoint WF250-Loud banching when spinning
possible broken "spider"support on rear of basket best call serviceif unit is out of warranty be sure to ask for estimate first
May 21, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Crosley CAWC529JQ1 top load washer LEAVES LINT ON CLOTHING
try washing on a shorter time as this washer may have too good of wash action and the lint is fabric coming off your clothing
add more soap powder and do not buy the cheapest soap as the soap is important in the washing cycle of your machine
towels that are not too soiled brobably need 6 minutes at most on wash
if this machine has a delicate wash cycle use that for tee shirts etc
water pressure is important in rinse cycles
do you have high pressure and water only trickles in check water inlets on back of machine where the hoses screw on
good luck
Nov 27, 2007 | Crosley CAWC529JQ Top Load Washer
Crosley caw5923mqd Top Load washer spins but leaves A LOT of water in the clothes
have you checked the pump out of the maachine
the pump may be blocked restricting water flow
if that is ok maybe you need to give the n
machine a hot wash the seals may be draging the spin down
Oct 12, 2007 | Crosley CAWC529JQ Top Load Washer
Highspeed spin is not stable...
Is this a brand new machine? If so make sure the shipping pins have been removed. They are attached to a yellow strap coming through rear of machine. Pull the strap straight out and there will be 3 pins that are attached to it. You should be able to move the basket and tub around by hand freely. If this is not the problem you may have a base pad broken or missing.
Oct 03, 2007 | Whirlpool LSQ9610L Top Load Washer
Spin Cycle/Machine makes noise and moves
You can't tight up the tub. You should replace the damper pads that located beneath main support housing on base's machine. Goog luck !
Jan 15, 2007 | Crosley CAWC529JQ Top Load Washer
Crosley CAWC529JQ Top Load Washer Logo
388 people viewed this question
Top Crosley Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
