Question about Olevia Televison & Video
I get intermittent reception on the analog and the lower digital channels on my OLEVIA 247FHD TV (blue scree with aduio only or a very fuzzy picture). I get good reception on the 1080 HD channels. I had the cable company come out and check the signal coming into the house and it checked out very good. This just started after 9 months of working fine and 3 weeks after the digital switch over.
    President:
  • 1,284 Answers
Sounds like a bad tuner in the TV or possibly the RF connector on the back is coming loose. Is it still under the manufacture warranty?
Posted on Jul 23, 2009
On TV1 screen stays blue and no sound go to AV1 DVDplayer have pic and sound The tv was given to told it worked is it a code
Did you scan for channels after hooking up the antenna?
Have the tv scan for available channels in your area.
Should be on the tv menu to scan for digital or analog channels.
Feb 05, 2016 | Olevia LT27HVX 27 in. LCD Television
19" Element HD Digital LED TV Model ELEFW195 Does not scan Digital Channels just Analog Channels.
Auto-channel search can't find digital channels - Community ...
community.insigniaproducts.com/...channel...can...digital-channels/.../13...
Aug 6, 2010 - When I ran the auto-channel search it could only find 4 analog ... Notgetting Digital Channels on NS-26L450A11 ... I've plugged the cable from the wall into the TV, and preformed the auto channel scan, with "cable" selected.
Troubleshooting Guide for Digital-to-Analog Converter Boxes
https://www.fcc.gov/.../troubleshoo...
Federal Communications CommissionIf you aren't receiving digital signals on your analog TV, you can purchase a ...antennas are designed only for reception of either VHF or UHF signals (but not both). ...The channel scan will automatically search for digital broadcast channels ...
Antennas and Digital Television ' Federal Communication
Jan 13, 2016 | Televison & Video
The color turns predominately green intermittently
Please try to play any DVD movies to determine if the problem is on the TV or on the cable/aerial connection and reception..
If you play DVD and works fine?
The TV is good but the problem is on the aerial antenna if you are using analog..and if you are using digital cable please double check the connection and cable box..or try to contact your cable provider..
Dec 19, 2011 | Olevia LT32HVE 32 in. LCD Television
We want to hook our small Magnavox tv to a rabbit ear antennae to get only local stations. How to do this?
Unless this a new TV with ATSC (digital) tuning built in, you will need a digital adapter for off-the-air reception. Older TV sets have analog tuners, and analog broadcasting ended in June 2009. Wal-Mart and Radio Shack carry the adapters, as do other retailers. Your antenna connects to the adapter, and the adapter sends the converted signal to the TV on channel 3 or 4.
With digital broadcasting, a strong signal is necessary. Unlike the analog days, when a weak signal just meant a fuzzy picture, a weak digital signal will cause pixellation (blockiness) or freezing of the picture, or may not even be detected by the tuner. Depending on how far you are from the station's transmitter, you may find that rabbit-ears may not work too well. You may need an amplified antenna or even one outside to get best performance.
Aug 07, 2011 | Televison & Video
Digital Visio 42" LCD TV stopped receiving digital TV
Check all your connections in the back, if they're all good replace the main board in the tv.
Aug 22, 2009 | Televison & Video
I get no stations on my tv
Use an Antenna that Provides Good Reception of All Channels
  • Most existing antennas used by consumers will provide good reception of DTV signals. (Before making any changes, try your existing antenna first to see of it allows you to receive all the stations you normally watch.)
  • For watching DTV signals, you will need an antenna that provides good reception of both VHF signals (channels 2-13) and UHF signals (channels 14-51) to reliably receive all of the digital signals broadcast in your area.
  • Many antennas are designed only for reception of either VHF or UHF signals (but not both). For example, the commonly used “rabbit ears” indoor antenna is only suitable for receiving VHF signals. To receive UHF signals, an indoor antenna should also include a wire loop or other feature for reception in that band.
  • The reception capabilities of TV antennas also vary considerably, so be sure to talk to retail consultants and look at information on the packaging and/or the Internet to make sure that any new antenna you may choose provides good reception of both VHF and UHF channels. In addition, if you use an indoor antenna and receive signals on VHF channels, you may need to use an antenna with amplification.
  • Many antennas currently being sold as “HDTV Antennas,” perform best at receiving UHF signals; some of these models state that they provide reception of signals on channels 7-13 but actually perform less well receiving those channels. If you obtain one of these antennas, be sure it provides good reception of all the VHF channels as well as the UHF channels.
  • To check for the DTV signals that are available at your location, use the DTV Reception Maps available at www.fcc.gov/mb/engineering/maps.
Check Your Connections
  • Check that your digital-to-analog converter box or digital television is connected properly. Make sure your antenna is connected to the antenna input of your digital-to-analog converter box or digital television. If using a digital-to-analog converter box, also ensure that the antenna output of your converter box is connected to the antenna input of your analog TV. Refer to the owner’s manuals of your components if you are unsure of the proper connections.
  • Ensure that your components are plugged in and have their power turned on.
  • If you have a digital-to-analog converter box, tune your analog TV to channel 3. You should see a set-up menu or picture displayed on your TV screen. If you do not see a set-up menu or picture, tune your TV to channel 4. If you still do not see a set-up menu or picture, recheck your connections.
Perform a Channel Scan
  • Digital-to-analog converter boxes and digital televisions have a button, usually on the remote control, that is labeled “set-up” or “menu” or some similar term. Press that button to access the set-up menu. Using the directional arrow buttons on your remote, scroll to the option that allows you to perform a “channel scan.” The channel scan will automatically search for digital broadcast channels that are available in your area. Consult the owner’s manual of your digital-to-analog converter box or digital television for detailed instructions on how to perform a channel scan for your device.
  • Once the channel scan is complete, you will be able to tune to the digital channels received by your antenna. You should perform a channel scan periodically to check whether additional digital channels have become available.
Adjust Your Antenna
  • Small adjustments to your antenna can make a big difference in the number of digital channels you can receive. If you have an indoor antenna, try elevating it and moving it closer to an exterior wall of your home. After adjusting your antenna, perform another channel scan to see if your reception is improved.
  • While adjusting your antenna, it may be helpful to access the “signal strength meter” on your digital-to-analog converter box or digital television to determine whether your adjustments are improving the signals’ strength. The signal strength meter is usually accessed through the menu feature on your remote control. Refer to the owner’s manual of your device for detailed instructions on how to access its signal strength meter. Remember to do another channel scan after you have adjusted your antenna.
  • Television stations broadcasting in digital use both the VHF band (channels 2-13) and UHF band (channels 14-51). Many indoor antennas use “rabbit ears” for the VHF band and a “loop” or “bow-tie” antenna for the UHF band. Make sure you are using an antenna that covers both the VHF and UHF bands and have connected it properly.
If You are Still Having Difficulty:
  • Until June 12, 2009, some stations will be operating at reduced power levels. If you are not receiving certain digital TV stations, this does not necessarily mean there is a problem with your antenna or digital-to-analog converter box or digital television. Check with the TV station to find out whether they are planning changes that will improve reception.
  • When an analog TV signal is weak or receives interference, static, snow, and distortion will often appear on the screen. Digital broadcasting will provide a clear picture; however, if the signal falls below a certain minimum strength, the picture can disappear. This “cliff effect” means that if you watch analog TV stations that have static and distortion, you may have to adjust or upgrade your antenna system.
  • Simple indoor antennas provide minimal performance that may not be suitable for your location. If you are unable to obtain satisfactory DTV reception with your current indoor antenna, you may wish to obtain an indoor antenna that includes features for better reception of UHF signals, as well as VHF, and/or an amplifier to boost the received signal (often referred to as an active indoor antenna).
  • Generally, an outdoor antenna will get better reception than an indoor antenna. However, the performance of outdoor antennas can degrade over time due to exposure to the weather. If you are having problems, check for loose or corroded wiring, broken antenna elements and that the antenna is pointed in the right direction.
  • Try to keep the length of wire between your antenna and digital-to-analog converter box or digital television as short as possible for best reception.
  • “Splitters” that are used to connect a single antenna to multiple digital-to-analog converter boxes or digital televisions reduce the amount of signal available to each device. If you are having problems, check whether reception is improved without the splitter. In some cases an “active” splitter that includes an amplifier can solve the problem.
  • If you are near a station’s broadcast tower, reception of that station, as well as other stations, can be impeded by strong signal “overload.” Consider using an “attenuator” or removing amplifiers to improve your reception.
  • If you decide to replace or upgrade your indoor or outdoor antenna, many types are available from electronics retail stores at a variety of prices. Websites such as www.antennaweb.org provide information on the locations of broadcast towers and the types of outdoor antennas appropriate for the stations you wish to receive. If you need assistance with upgrading your antenna system, check with a local antenna retailer or antenna installer.
Hope it may helps:
Regards:
VOTIT
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
How do i cahange my reception From analog to digital?
The Dynex LCD-19-09 19in LCD Tv has a digitial tuner in it already. I would recommend doing a channel scan and make sure it is on the "Antenna" setting instead of "Cable" and let it scan for channels. You will see all the analog channels like "7", "12" if they are still broadcasting, however, if you can pick up the digital channels, it will look more like "7-1" or 12-1; 12-2 etc.". To get to this, push the "Menu" button on the Dynex remote, then arrow down twice to TV, then push the right arrow and make sure it is set at Antenna and do a channel scan. Should get you whatever digital channels are available. If the digital antenna is not strong enough, you will need to get the digital one at Wal-Mart as previously suggested and hope that will convert the analog channels in your area.
Jun 12, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
We bought a 20" analog/digital tv the analog channels come on fine but we it scans for the digital channels it says no siginal will we be able to watch it when the change takes place even though we can't...
This could be caused by two different issues.
  • Digital signal reception is bad. The digital signal must be locked in, digital signal reception is either on or off (not like analog signal reception where you can receive a low signal and a fuzzy picture). You may need to adjust you antenna direction and height or obstructions around your antenna, reference the web site for your specific location (address) for antenna compass headings. http://www.antennaweb.org/aw/Address.aspx
  • Television is faulty, digital receiver is bad. Your new television has two receivers, an analog receiver and a digital receiver. A simple power surge will knock out your digital receiver. Make sure you have a quality surge suppressor connected to the television power and the antenna is properly grounded. Return the television for a replacement and purchase a quality surge suppressor.
You must add a quality surge suppressor to your digital television! http://ezinearticles.com/?Power-Protection-in-the-Home-Theater---Use-of-Surge-Suppressors-to-Guard-Expensive-Electronic-Gear&id=41318
Good luck.
Jan 03, 2009 | RCA 20F420T 20" TV
Wish to record on analog VCR and not affect digital TV reception
I don't think it will affect the digital TV reception, but if you try to use the VCR built-in tuner it is still analog and you won't be able to record digital channels that way. If your digital TV converter has video-out and audio-out connectors, then you can connect those to the corresponding connectors on your VCR to record.
Dec 28, 2008 | Insignia Digital-to-Analog Converter for...
One channel fuzzy
Tis is an ongoing problem I seen increase alot over the past few months. From what I can gather, all the channels being broadcast over going from the analog to digital, there's no big suprise to anyone. However, the change from analog to digital is changing at a faster rate, so when you look at the TV some channels will be fine and others will have grey lines, fuzzy picture. The only solution-you need a TV with some kind of digital tuner. On the TV itself if the (TV has one) it will say "SD" or "ED" which stands for standard digital or enhanced digital.
Jan 25, 2008 | GE 27GT277 27" TV
Televison & Video Logo
135 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
