Question about HP Officejet 5610 All-In-One InkJet Printer
Fax will not send on HP 5610v All in One
I realized that when I send 5 faxes, the monitor on the printer screen shows that only pg 1 was faxed. In the end, the fax transmission shows "failed" transmission. How do I fix this?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 80 Answers
Their could be many reasons your fax machine is doing this but I'm going say with the information given that you may have a bad phone cable or no connection at all. also if your fax is not on a dedicated line someone could be using that line or simply picking up a phone on the same line before you fax will cause you your fax to fail. I hope this has been of some help... please don't forget to rate
Posted on Jul 23, 2009
TELEPHONE HOOK-UP REQUIREMENTS
Just a plain telephone cord, plug it in. Go into setup and setup your fax name and number that will appear on the fax your sending. Set the number of rings before answering. Place a test fax call to some fax machine.
  1. Send a one page black and white text fax to 1-888-hpfaxme (1-888-473-2963).
  2. When your fax is received by the HP Test Fax Service, we will generate a return fax to you within five minutes confirming that we received your fax. This verifies that you can both send and receive a fax with your fax machine.
If you do not receive a return fax within 5-7 minutes, there may be a problem with the setup of your fax machine. Consult the user manual that came with the product for proper setup and configuration.
May 10, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Hp officejet 6310 all-in-one send fax configure
1. Press Setup on the front panel of the All-in-One.
2. Press 2 to enter in to Print Report.
3. Press 1 to enter in to Fax Confirmation.
4. Press 1 to turn on Fax confirmation
5. Press 2 to enter in to Image on Fax Send Report
6. Press 1 to turn on Image on Fax Send Report
Jun 03, 2009 | HP Officejet 6310 All-In-One InkJet...
HP 5610v All in One Copy Fax. Several numbers on the keypad ( Fax) don't work. When you're trying to fax, the numbers 2, 4 and 9 don't work. The HP is only 6 months old, bought at Walmart. Called HP...
Chances are pretty good that it is indeed a hardware problem. I'm not sure how Wal-Mart handles their warranty services, seeing as it's only 6 months old you should still have the 1-year manufacturer's warranty for the unit. I would either give Wal-Mart a call, or even bring it directly to them and see how they want to handle the warranty service on it.
May 07, 2009 | HP Officejet 5610 All-In-One InkJet...
Cant fax
Are you sure the FAX line is connected to a working phone jack and plugged into the correct jack (line not phone) on the machine?
Step by step FAX instructions can be found here on the HP website.
Jan 07, 2009 | HP Officejet 5610 All-In-One InkJet...
Please help me send a fax on my HP 5610
Send a fax
You can send a fax in a variety of ways. Using the control panel, you can send a blackand-
white or color fax from your HP All-in-One. You can also send a fax manually
from an attached phone. This allows you to speak with the recipient before sending
the fax.
If you frequently send faxes to the same numbers, you can set up speed dial entries.
For more information on setting up speed dial entries, see Set up speed dialing.
Send a basic fax
You can easily send a single- or multiple-page black-and-white fax by using the
control panel, as described here. If you want to send a color or photo fax, see the
onscreen HP Image Zone Help.
Note If you need printed confirmation that your faxes were successfully sent,
enable fax confirmation before sending any faxes. For more information, see
Print fax confirmation reports.
Tip You can also send a fax manually from a phone or by using monitor
dialing. These features allow you to control the pace of your dialing. They are
also useful when you want to use a calling card to charge the call and you
need to respond to tone prompts while dialing. For more information, see Send
a fax manually from a phone or Send a fax using monitor dialing.
1. Load your originals, with the print side up, into the document feeder tray. If you
are sending a single-page fax, such as a photograph, you can also load your
original on the glass.
Note If you are sending a multiple-page fax, you must load the originals
in the document feeder tray. You cannot fax a multiple-page document
from the glass.
2. Press Fax.
Oct 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP Office Jet 5610v All-In-One
If it is a dedicated fax line.
Then make sure auto answer is turned on.
Then go to Setup/Menu> and press the right arrow key till you see basic fax setup>
Then press Ok> Then press the right arrow key and scroll to basic fax setup> then press ok.
Then scroll to rings to answer and set it to 2.
Then press cancel and come to the main display.
Press setup/menu> and scroll to advance fax setup> and scroll to distinctive ring pattern> and select all rings.
You should be able to receive and send faxes without any problem if it is a dedicated fax line.
If it is a shared line with phone, voice mail or answering machine then you will hev to get a distinctive ring pattern from your telephone service provider.
So that it can distinguish your Fax message and voice message.
If any problem let me know.
Sep 17, 2008 | HP Officejet 5610 All-In-One InkJet...
HP LaserJet 3330MFP quit recieving & sending faxes
Your Line Interface Unit (L.I.U.) is bad. The part # is C9138-60001. Google for part availability.
1 Open or remove the left side door.
2 Remove one screw at the left of the formatter board.
3 Disconnect the flat flexible cable from the connector.
4 Rotate the LIU around the hooks to remove.
It's about a 5 min job. Good Luck.
Feb 17, 2008 | HP LaserJet 3330MFP All-In-One Printer
Fax report stuck in queue
try unpluging the power from the fax machine/
Jan 09, 2008 | HP Officejet 9110 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
124 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
