Question about T-Mobile Sidekick ID Cellular Phone
My screen is blank white and I've tried resetting, removing battery and SIM card.
  • 33 Answers
Since you have already tried all of that and no good going.
well, unfortunately, you might will have to get a new one or find
some used one on ebay.
because, the way you describe the problem you have and had done tried
all of that resolution. it could be the back light is out. which mean, it need to get
a new motherboard or back-light thing to replace/fix it. so, if you know how to fix it
then you can find supplies for it on ebay to fix that issue or try find a place t
hat they can fix it for you.
good luck. =/
Posted on Jul 25, 2009
Absolutley EVERYTHING still works just blank screen after dropping in water.
If you put it in water, immediately shut the phone off, pull the battery, sim card (if applicable) and put everything in a bowl of white rice for a few days. The white rice should remove the device enough so everything should be usable.
I've also heard that immediately freezing the phone works too, your choice.
Jun 11, 2011 | Cell Phones
Screen blank after fitting orange sim card
I had similar problem. Try: Remove battery, sim card and data card. Replace battery and turn on. This fixed my screen problem. Then I selected factory defaults from general settings, though I dont know that this was necessary. Cheers
Dec 20, 2009 | Nokia N95 Cellular Phone
Blank screen
Remove the keep the battery out for 5 mins. Press the power button for 30 seconds without the battery to drain any charge on the main hardware.
Reseat the battery and turn on the phone.
Jan 26, 2009 | Sony Ericsson K800i Cellular Phone
Blanked out blackberry
Blanked out as will not turn on? Try pressing the green phone **** for aabout 10 seconds shoud either turn phone off or on. ALso call phone from different number to see if it rings. If these steps do not work try the following:
Remove back of phone, Take out battery. completely remove Sim card (possibly large white card in phone, reseat the sim card then replace battery. If you have no sim card just try to remove the battery for a few seconds then replace.
Let me know if it works and vote for me if it does.
Jan 02, 2009 | RIM BlackBerry Pearl 8100
Nokia e 61i white screen
My Nokia E61i sometimes starts up with the welcome screen and works normal for a while.
Then sometimes the screen will flash on start up or continues to flash
with spotted colors and not come on. Could this be a software problem?
Thank you Jason
Dec 15, 2008 | Nokia E61i Cellular Phone
My sony ericsson w600i just went blank
i have white screen in W600i model please solve this problem
Sep 10, 2008 | Sony Ericsson W600i Cellular Phone
N70 - blank screen
Take your SIM card out.
Make sure your phone battery is fully charged.
Press * 3 send at the same time and turn the phone on. Keep them pressed until the reset screen appears.
Give it time to reset.
Yes! I know, you need someone to press the ON button.
Mar 23, 2008 | Nokia N70 Cellular Phone
Blank screen
its is known as WSOD (white screen of death).... u have to update ur mbile for it
and i am also searching how to update my mobile....
Mar 17, 2008 | Sony Ericsson W550i Cellular Phone
My sidekick3 screen is blank
If your sidekick ID or Sidekick 3 screen is a blank white, then the lcd flex cable has come loose. It is a little difficult to repair but any one can do it. The worst that will happen if you try to repair yourself is that it will not work and you buy a replacement screen from ebay for 45 dollars.
Here are the detailed instructions. Just reinstall your lcd instead of putting a new one on.
Sidekick 3 LCD Screen Only Replacement
Here is a link to find lcd screen on ebay.
Sidekick 3 LCD Lens
Oct 27, 2007 | T-Mobile Sidekick® 3 Cellular Phone
Screen went blank
There is something you can try. Using a Torx 6 driver, remove the two screws located beneath the battery. Gently pry the plastic cover loose. There will be a flex cable connecting it to the other portion of the phone. Gently disconnect it. Using 99.5% isopropyl alcohol and a soft bristled brush clean the connectors on both the cable and the circuit board. Reseat the connector and reassemble the phone. If this does not work the flex cable or LCD may need to be replaced.
Sep 05, 2007 | Motorola Mobility RAZR V3
T-Mobile Sidekick ID Cellular Phone Logo
95 people viewed this question
Top T-Mobile Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
Computer Repairing
Computer Repairing
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
