Question about HP Business InkJet 2800 Printer
HOW DO YOU REMOVE THE COVER OF THE HP2800 TO ACCESS THE COVER SENSORS?
  • glcofaz Jul 24, 2009
    your comments regarding caps usage shoiw your head is bigger than your knowledge
    President:
  • HP Master
  • 1,996 Answers
I'm not sure why you want to access the sensors, but the only manual I know of for that machine is here. If you're trying to avoid the false out of paper error message that shows on your machine, you need to do a forced reset by following the instructions in the second to last post in this thread.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 23, 2009
  • efs_perpends
    efs_perpends Jul 23, 2009
    I guess I should have known better than to attempt to help someone who uses all caps to make demands. Call HP support. I'm sure they'll help you.... NOT
  • efs_perpends
    efs_perpends Jul 24, 2009
    thanks for the confirmation!
Where is the transmission temperature censer located on a 2003 Buick regal?
(391) Automatic Transmission Fluid Temperature (TFT) Sensor
Inside the transmission behind side cover
Removal Procedure
Remove the case side cover. Refer to Control Valve Body Cover Replacement .
Important: Lock steering wheel in centered position with wheels straight ahead.
Remove the engine dress cover.
Remove the air cleaner intake duct. Refer to Air Cleaner Inlet Duct Replacement in Engine Controls - 3.1L or Air Cleaner Inlet Duct Replacement in Engine Controls - 3.8L.
Remove the engine mount struts. Refer to Engine Mount Strut Replacement in Engine Mechanical - 3.1L or Engine Mount Strut Replacement - Right Side and Engine Mount Strut Replacement - Left Side in Engine Mechanical - 3.8L.
Important: For supercharged engines, remove the throttle cable bracket.
Disconnect the shift cable bracket.
Remove the transaxle top side cover bolt.
Install the engine support fixture. Refer to Engine Support Fixture in Engine Mechanical - 3.1L or Engine Support Fixture in Engine Mechanical - 3.8L.
Disconnect the transmission wiring harness connector.
Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
Remove the left front tire and wheel assembly. Refer to Tire and Wheel Removal and Installation in Tires and Wheels.
Remove the left inner splash shield 3 push pins.
Loosen the wheel speed sensor harness from the 5 retainers at the cradle.
Remove the transmission support to cradle nuts only. Refer to Transmission Mount Replacement .
Raise the vehicle.
Remove the front splash shield 5 bolts.
Loosen the engine mount lower nuts. Refer to Engine Mount Bracket Replacement in Engine Mechanical - 3.1L or Engine Mount and Bracket Replacement in Engine Mechanical - 3.8L.
Remove the stabilizer bolts and reposition the stabilizer.
Remove the steering gear cradle bolts, then support gear before lowering cradle.
Support the left side of the frame with a jackstand.
Remove the left side frame bolts. DO NOT loosen the right front or the right rear frame bolts. Refer to Frame Replacement in Frame and Underbody.
Remove the left ball joint from the steering knuckle.
Position the drain pan under the transaxle.
Remove the left drive axle from the transaxle. Refer to Wheel Drive Shaft Replacement in Drive Axle.
Secure the drive axle to the steering knuckle/strut.
Adjust the jackstand to lower the left side of the frame until it hangs free. Remove jack stand.
Lower vehicle to access engine support fixture.
Lower the engine/transmission assembly with the engine support fixture to gain access to remaining side cover bolts.
If replacing the side cover, remove 4 engine mount bracket bolts.
Remove the harness retainer.
Raise vehicle to access side cover bolts.
Remove the case side cover bolts (56-58).
Remove the case side cover pan (53).
Remove the case side cover gasket (54).
Clean the case.
Clean the side cover gasket mating surfaces.
Disconnect the wiring harness assembly from the fluid temperature sensor (391).
Remove the fluid temperature sensor (391).
Installation Procedure
Install the fluid temperature sensor (391).
Connect the wiring harness assembly to the with fluid temperature sensor (391).
Install the case side cover. Refer to Control Valve Body Cover Replacement .
Important: It is recommended that transmission adaptive pressure (TAP) information be reset. Resetting the TAP values using a scan tool will erase all learned values in all cells. As a result, The ECM, PCM or TCM will need to relearn TAP values. Transmission performance may be affected as new TAP values are learned.
Reset the TAP values. Refer to Transmission Adaptive Functions .
Nov 23, 2016 | Buick Cars & Trucks
Location of airbag sensors
Are you talking about impact sensors? Two are located on front right and left frame support. They are accessible from the bottom but its easier to take the bumper off to gain easy access to them. Another two are locates on bottom of B pillar around the area where the driver and passenger seatbelt tensioners are. You have to remove the door seals and plastic cover of the B pillar to gain access to them. Last two are mounted below C pillar behind the seat back cover. You have to remove cushion and back piece to gain access to them. Some people say there are versions without the sensors under C pillar tho, but I worked on one that had those sensors.
Jun 27, 2014 | 2013 Honda Accord
Where is the crank shaft sensor located on a ford taurus 2005.
  • Disconnect the ground battery cable using a wrench to hold the terminal bolt in place as you loosen the retaining nut with another wrench.
Locate the accelerator cable next to the throttle assembly towards the back and top of the engine and remove the shield. Pull the retaining pins using a pair of slip joint pliers if necessary.
Remove any other accessories that might interfere with the removal of the camshaft sensor like wiring harness, spark plug retainers or engine cover, depending on your particular Ford Taurus model.
Move the fuel-injectors wiring harness off the valve cover studs as well to gain access to the camshaft sensor if necessary.
Locate the camshaft sensor around the top of the engine. For more information, see the Resources box at the bottom of this article.
Unplug the camshaft-sensor electrical connector by pressing on the lock tab and pulling the plastic connector off the sensor.
Unfasten the two sensor mounting screws using a Phillips screwdriver and remove the sensor from the engine compartment.
Installing the Camshaft Sensor
Position the new camshaft sensor in place and start the two mounting screws by hand to avoid damaging the threads.
Tighten the two mounting screws using the Phillips screwdriver.
Plug the camshaft-sensor electrical connector.
Realign the fuel injectors' wiring harness over the valve cover studs.
Install any other accessories you had to remove to gain access to the camshaft sensor like wiring harness, spark plug retainers or engine cover.
Replace the accelerator cable shield if you had to remove it. Use the slip joint pliers if necessary.
Connect the ground, battery cable using one of the wrenches to hold the terminal bolt in place and tighten the retaining nut with another wrench
Nov 29, 2011 | 2005 Ford Taurus
Where is the cam sensor located in 00 rodeo 4 cil.
Its behind the timing cover. You have to remove the spark plug cover and the timing cover to gain access to the cam sensor.This also calls for removing the balancer from the crank as well. Its really a pain in the rear to do so make sure its bad before you replace it.
Jul 11, 2011 | Isuzu Rodeo Cars & Trucks
Where is the cam shaft sensor on a 1993 buick lesebre custom
Hi, on the 1993 Buick Lesabre the crankshaft sensor is located under the dampener pulley. Remove the serpentine belt. Remove right front wheel. Remove plastic access cover thats behind that wheel. With an impact wrench remove dampener pulley bolt. With an Dampener pulley puller remove pulley. There is a plastic cover that snaps in place over the sensor, remove it, and you will have access to the sensor.
May 11, 2011 | 1993 Buick LeSabre
Where is the PVC Valve located on a 2006 Pontiac Grand Prix
It's under the MAP sensor in the upper plenum. You need to remove the MAP sensor by turning it ¼- turn while pushing down. Remove the sensor and the PCV should be under that. Reach in with needle nose pliers to grab it.
REMOVAL PROCEDURE: Remove the injector sight shield from the fuel rail and intake. Remove the MAP sensor. Use a 16 mm socket to press the access cover down and rotate 1/4 turn counterclockwise. Remove the access cover. Remove the PCV valve and the O-ring from the intake manifold.
INSTALLATION PROCEDURE: Install the crankcase ventilation valve ; replace the O-ring if necessary. Install the access cover. Install the MAP sensor. Install the sight shield.
From: http://autorepair.about.com/library/a/1a/bl338a.htm
Apr 16, 2011 | Pontiac Grand Prix Cars & Trucks
Where is the battery in HP2800?
well it really looks like a bar and it should be to the further back of the laptop directly under where the bottom of the screen and the laptop meets... its actually not on the inside its attached to the bottom/ back of the laptop there should be a sorta slide switch that you push and the battery normally comes right off... hp2800
Mar 15, 2011 | Computers & Internet
I am not getting fuel to my engine
Removal
  1. Relieve the Fuel System Pressure . Refer to the procedure in this section.
Cushion Cover and Pad, Rear Seat — One-Piece and 50/50 Split Fold Removal
  1. Remove the two rear seat cushion bolts.
  1. Fold the rear seat back cover and cushion (60084) forward.
  1. Carefully pull the rear seat cushion and cover (60030) out from under the rear seat back cover and cushion and remove the rear seat cushion and cover from the vehicle
  1. Remove the rear seat cushion and cover (60030). Refer to Section 01-10 for the removal procedure.
  1. Remove the three luggage compartment floor cover hold-down pins and fold the luggage compartment floor cover (45455) forward until the fuel pump assembly access plate is visible.
  1. Remove the four fuel pump assembly access plate screws, the ground lead, and the fuel pump assembly access plate from the chassis.
  1. Disconnect the fuel pump assembly electrical connector.
  1. On 4-door vehicles, remove the fuel vapor tube shutoff valve bolt and the evaporative emission tube shut off valve (9G332) from the bracket on the fuel pump assembly housing.
  1. Loosen the two hose clamps and disconnect the two fuel pump hoses from the fuel pump hose fittings on the fuel pump assembly housing.
  1. Remove the four screws (2-door) or eight screws (4-door) and lift the fuel pump assembly housing from the fuel tank (9002).
  1. Disconnect the fuel level sensor electrical connector.
  1. Remove the two fuel level sensor washers and fuel level sensor nuts and the fuel level sensor.
Section 10-01: Fuel Tank, Filters, Lines and Electric Fuel Pump 1996 Aspire Workshop Manual
REMOVAL AND INSTALLATION Fuel Pump Removal
  1. Remove the fuel level sensor. Refer to the Fuel Level Sensor removal procedure in this section.
  1. Remove the fuel pump screw, fuel pump grommet and the fuel pump bracket from the bottom of the fuel pump (9350).
  1. Remove the fuel tank sender filter bracket, fuel tank sender filter (9A011) and the fuel tank sender filter retainer from the fuel pump.
  1. Disconnect the fuel pump electrical connector.
  1. Remove the clamp and the fuel pump from the fuel pump assembly housing.
Apr 19, 2009 | 1995 Ford Aspire
HP DESKJET 1180C
HP Deskjet 1180c and1220c Professional Series Printer and HP Deskjet 9300 and 1280 Printer - Troubleshooting a Blinking Print Cartridge Light Introduction The Print Cartridge light continues to blink with both cartridges properly installed and the Access Cover (also known as the top cover or lid) closed. Instructions The blinking Print Cartridge light may be caused by a faulty cartridge, the plastic case of the printer being dislodged or slightly out of position (which prevents the Access Cover from seating properly), the Access Cover sensor (also known as the top cover sensor or lid sensor), or by the actuator on the Access Cover. Follow the steps below to resolve the issue.
  1. With the printer turned on, open the Access Cover. The carriage will move out of the capping station and stop at one of the cartridge status icons located inside the printer under the Access Cover. The yellow arrow on top of the carriage will point to one of the cartridge status icons to indicate a good, empty, or faulty cartridge. See Figure 1 below.
    1. If the carriage stops in the cartridge’s OK position, indicated by the happy face in Figure 1, continue with Step 2.
    2. If a problem is indicated with one of the cartridges, remove the cartridge and verify that the cartridge part number is correct. The black cartridge part number is 51645A and the color cartridge part number is C6578A or C6578D.
    3. If the cartridge part number is correct, clean the electrical contacts on the cartridge with a soft, lint-free cloth. Do not touch or wipe the nozzle plate.
    4. If a faulty cartridge is still indicated after verifying the cartridge part number and cleaning the contacts on the cartridge, replace the cartridge.
    5. After replacing the cartridge, turn off and then turn on the printer to clear the cartridge error from the printer's memory. If the cartridge error cannot be cleared, the printer will require repair. If the carriage stops in the cartridge’s OK position, indicated by the happy-face in Figure 1, continue with Step 2. NOTE: The printer checks the status of both print cartridges before printing. Both the black and color cartridge must be functional and installed in the printer in order to print.
    Figure 1: Cartridge status icons c00001225.jpg Icon/Drawing Problem identified by the symbol Solution c00001226.jpg The color cartridge is missing, improperly installed, defective, or the wrong print cartridge is installed. 1. If there is no color cartridge in the cartridge cradle, insert a color cartridge.
    2. If there is a color cartridge in the cradle, remove the color cartridge and firmly reinsert it.
    3. Check to make sure the color cartridge is appropriate for the printer.
    4. If the problem persists, replace the color cartridge. c00001227.jpg The black cartridge is missing, improperly installed, the wrong print cartridge, or is defective. 1. If there is no black cartridge in the cartridge cradle, insert a black cartridge.
    2. If there is a black cartridge in the cradle, remove the black cartridge and firmly reinsert it.
    3. Check to make sure the black cartridge is appropriate for the printer.
    4. If the problem persists, replace the black cartridge. c00001228.jpg The color print cartridge is running low on ink. Replace the color print cartridge with a new color print cartridge. c00001229.jpg The black print cartridge is running low on ink. Replace the black print cartridge with a new black print cartridge. c00001230.jpg None. The print cartridges are working correctly. None. The print cartridges are working correctly.
  2. Close the Access Cover and wait for the printer to initialize. If the Print Cartridge light is still blinking, remove the Access Cover by following the steps below:
    1. Open the Access Cover and hold it open.
    2. Dislodge the Access Cover from the hinges with a sharp blow to the hinge area of the Access Cover and then remove the Access Cover.
  3. Install the Access Cover by following the steps below:
    1. Align the hinges on the Access Cover with the hinge pins on the printer.
    2. Push down firmly on the Access Cover until the hinges snap into position.
  4. Close the top cover and wait for the printer to initialize. If the Print Cartridge light is still blinking, the printer case may be dislodged or slightly out of position. To restore the printer case to the proper position, squeeze the printer by applying pressure to the front and back pressure points shown in Figure 2. Figure 2: Pressure points c00006497.jpg Firmly squeeze the pressure points on the printer case as shown in Figure 3. If the Print Cartridge light continues to blink, continue with step 5. Figure 3: Squeezing the pressure points c00006498.jpg
  5. If the Print Cartridge light is still blinking, push down firmly on the center of the Access Cover (the extra pressure may engage the sensor). If the Print Cartridge light quits blinking, remove the pressure from the Access Cover to see if the Print Cartridge light starts blinking again. Re-apply the pressure to the center of the Access Cover to see if the Print Cartridge light stops blinking again.
    1. If the Print Cartridge light quits blinking with pressure applied, the Access Cover is faulty and should be replaced.
    2. If the Print Cartridge light continues to blink even with pressure applied, the Access Cover sensor may be faulty and the printer will require repair.
Oct 18, 2007 | Office Equipment & Supplies
HP Business InkJet 2800 Printer Logo
585 people viewed this question
Seeker5211
Seeker5211
