Question about Dryers
How do I change the rear vent outlet on a Kenmore dryer to the left side?
    President:
  • 1,714 Answers
If it's designed to change, there will be metal plate on the side that you remove and place over the back outlet (remove vent hose), then move the vent hose to the side and hook it up.
Posted on Jul 23, 2009
  • Craig Butler
    Craig Butler Jul 23, 2009
    A good rating would be nice...thanks!
How do I change the dryer vent from rear to side
there is usually a pc that can be removed on the side a round plate with light soder
Jul 02, 2014 | Kenmore Dryers
How do i change the high limit thermostat on a kenmore dryer # 72822
Unplug the dryer from the electrical outlet. Slide the dryer out from the wall and disconnect the dryer vent from the back of the dryer. Loosen the retaining screw on the clamp connecting the vent to the dryer's exhaust port and slide the vent off of the port.
Remove the hex nuts holding the dryer's rear panel in place and slide the rear panel off to the side of the dryer. Locate the high-limit thermostat on the heating element housing on the right side of the dryer. The oval-shaped thermostat can be found a few inches from the bottom of the heating element housing.
Unplug the two thermostat wires by sliding them off of the thermostat's contact posts. Slide the old thermostat out of the socket on the heating element housing.
Mar 12, 2011 | Kenmore 72822Gas Dryer
Install side vent for GE dryer
Unlike some other dryers that have knockouts on the side and allows the vent to come out the side I don't believe this one does. The air duct has the rear discharge outlet built right into it. Since it sounds like you don't have enough room to put a 90 degree elbow on the back of the machine, which would move the dryer out about 6 in, you might try one of those square duct dryer fittings. See link for example:
http://www.northlineexpress.com/itemdesc.asp?ic=5CO-89638&source=froogle&kw=5CO-89638. If you had to you could put this 90 degrees, and continue it out with retangular metal duct.
Jul 20, 2010 | GE DVLR223 Dryers
Need to change vent from rear to left side
why don't you just go to home depot and buy a longer flex hose?mike
Feb 19, 2010 | Kenmore 64942 Electric Dryer
I have a Kenmore Series 600 electric dryer and it takes forever to dry clothes. Over an hour for a regular load. There is no way this can be right. Is this a common problem with this model.
This is likely the result of an air flow problem if you are sure the heater is working properly. Ensure you are not running the dryer in a closed room which would starve the dryer of air dramatically reducing the air over the clothes even if the full length of your vent is brand new. Next, remove the vent hose from the rear of the dryer and check for strong air flow at the outlet. If it seems strong enough then run a vent through a window or out into another room and do one load in this fashion. If this resolves your problem the blockage exists in the vent line outside your dryer and disassembling dryer becomes unnecessary.
If not, ensure you have seen and touched every inch of interior dryer piping and hold the lint filter up to the light to be sure you can see through it. Disassemble and clean ANY section of piping you can't get your hand into. The area below the lint filter tends to catch a lot of lint and can only be accessed by removing the housing at the rear on the left side as you face the rear. Ensure the blower wheel turns when the motor turns. (Newer models may have the filter housing at the front)
Having performed all these actions will likely resolve the problem.
Oct 31, 2009 | Kenmore Dryers
My dryer though feeling quite warm takes a long
This is likely the result of an air flow problem if you are sure the heater is working. Ensure you are not running the dryer in a closed room which would starve the dryer of air dramatically reducing the air over the clothes even if the full length of your vent is brand new. Next, remove the vent hose from the rear of the dryer and check for strong air flow at the outlet. If it seems strong enough then run a vent through a window or out into another room and do one load in this fashion. If this resolves your problem the blockage exists in the vent line outside your dryer and disassembling dryer becomes unnecessary.
Sep 20, 2009 | Kenmore Dryers
Drying not drying, clothes moist after hours
Sep 19, 2009 | Kenmore Dryers
I have a kenmore electric dryer.When I push to start ,the timer ticks but do not start.The door switch is working.When I open the door the ticking stop.What can this be?
Replace the thermal fuse located on the rear of the dryer.
Remove the rear panel the thermal fuse is white about 1 and 1/2 inches long by 1/2 inch wide.It is on the exhaust vent on the left side near were your connecting vent attaches.
Apr 12, 2009 | Kenmore Dryers
Dryer will not come on. i changes all my fuses and got a voltage tester and all that is fine, where can i find out about checking any fuses on the dryer itself?
Check the thermal fuse on the dryer.
Remove the rear panel.
The thermal fuse is located on the exhaust vent.
It is about 1 and 1/2 inches long and 1/2 inch wide. It is white in color.
It is at the left side of the exhaust vent outlet.
Mar 09, 2009 | Whirlpool LER4634J Electric Dryer
Change dryer vent from side to rear
Not all dryers have the facility to vent out of the side, if they can , you should see a knockout panel or cover at the side, remove this and fit vent to side.
It is important that you blank off the outlet where the hose was fitted originally.
Plz rate my answer.
Thanks..
Jan 20, 2009 | Dryers
Dryers Logo
195 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
