Question about E-Machines eMachines Desktop PC
Same problem boots up then shuts down
I have diconnected the hard drive and cd rom it will boot the bios and continue to run i have also changed the power supply no help i have another os on a live cd i disconnect the hard drive and boot the live cd and it does the same thing it will start to boot up then just shut down i am still working on it if i find the problem i wil post it
if anyone knows anything your help would be great
  • 23 Answers
Do you get a beep code while it is loading? Memory card /motherboard and cpu problems normally advertise themselves with a beep code. You can then google the code against your motherboard.
If you have already cahnged the power supply then it sounds more like your cpu is overheating. The more things you have plugged in, such as hard drive cd drive and so on, the quicker it will overheat and cut out.
I get this at work occasionally.
To see if this is the case boot to your set up screen. Somewhere within there there will be the option to see what temperature your cpu is running at. Leave it going for a while and just watch it.
I think generally if it runs in the 40's or 50's then there is no real problem with cooling. If it goes up to 60's and above(depending on the cut off set by the manufacturer) then you have an issue there.
If this is the problem its quite easy to fix.
If you know what you're doing, then check your fan is clean. Then replace the thermal grease between your fan and cpu to make sure the heat is dissapating properly.
In you r bios you may also have the optino to alter the speed at which your fan works, just in case thats not doing the job
Hope this helps
Posted on Jul 26, 2009
    Problem Solver:
  • 11 Answers
Insure your "boot sequence in the bios" is set to see your cd/dvd or maybe inadvertently be set to find the operating system on a "network" which will cause it to boot to the bios then idle awaiting connection to a network which of course doesn't exist. just a thought
Posted on Jul 24, 2009
    Habit-Forming:
  • 62 Answers
If your hard disk or DVD / CD player will not see from this is you can offset your IDE cable is removed the connection, can also damage the IDE cable and need a change, it would help you.have a nice day
Posted on Jul 23, 2009
  • 5 Answers
Could be one of your pci cards went bad. Open your case and remove one pci card then try starting your computer. If the problem continues try the next one. If the computer stays on, you know you need to replace whatever card you took out last. If that solution doesn't work try replacing your RAM or if you have 2 sticks or more remove them one by one like the pci cards. Hope this helps.
Posted on Jul 25, 2009
How do I unlock the Bios on an Acer ES-1 111M Laptop
To boot from a CD, DVD or USB device, make sure that the device has boot sequence priority over the hard drive.
BIOS Boot
BIOS (Basic Input Output Subsystem) is a programmable chip that controls how information is passed to various devices in the computer system. A typical method to access the BIOS settings screen is to press ESC, F1, F2, F8 or F10 during the boot sequence.
BIOS settings allow you to run a boot sequence from a floppy drive, a hard drive, a CD-ROM drive or an external device. You may configure the order that your computer searches these physical devices for the boot sequence.
The first device in the order list has the first boot priority. For example, to boot from a CD-ROM drive instead of a hard drive, place the CD-ROM drive ahead of the hard drive in priority.
Before you set boot priority for a USB device, plug the device into a USB port.
To specify the boot sequence:
  1. Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. Depending on the BIOS manufacturer, a menu may appear.
  2. Choose to enter BIOS setup. The BIOS setup utility page appears.
  3. Use the arrow keys to select the BOOT tab. System devices appear in order of priority.
  4. To give a CD or DVD drive boot sequence priority over the hard drive, move it to the first position in the list.
  5. To give a USB device boot sequence priority over the hard drive, do the following:
    • Move the hard drive device to the top of the boot sequence list.
    • Expand the hard drive device to display all hard drives.
    • Move the USB device to the top of the list of hard drives.
  6. Save and exit the BIOS setup utility.
  7. The computer will restart with the changed settings.
Boot Priority Options
Some computer manufacturers allow you to select the device that contains the boot sequence from a special device selection menu. The example below uses a Dell system board.
To set boot priority using a device selection menu:
  1. When the computer starts to boot up, after the manufacturer's ID screen, press F12 several times. The device selection menu appears.
  2. Use the up and down arrows to select CD-ROM or
May 04, 2015 | Acer Aspire Computers & Internet
How to make CD Rom run as BOOT? please key in
Go into the BIOS and change the boot startup device order. Make the CD the first boot device and the hard disk the second boot device.
If you do not wish to change the BIOS you may select the CD drive as an alternate boot device by pressing F10 or F!2 as the laptop boots up to bring up a list of devices to want to boot from, select the CD drive and the follow the screen prompt.
Aug 29, 2011 | Dell Inspiron 1525 Notebook
Carresearch, I just put the cd in and restarted the computer but the reinstallation didn't start. How do I reboot the cd first?
OK, Here's what you need to do. Shut down the computer. When you restart it, as it boots, continue to press and release the F2 key as the computer starts up. When it does, you will get a BIOS setup screen. From there, there will be an option to change boot sequence. Make CD drive first and then C: drive. Save your changes and then reboot. This time, the computer should load your reinstall disk. Let me know how it goes.
Apr 03, 2011 | Dell DIMENSION 3000 CELERON 2.4GHZ...
Want put additional hard drive in presario s6020wm is this possiable, also do the rpm speeds have to be the same I have a maxtor diamondmax plus 9 80g that spins at 7200, the one in the computer spins at...
It’s very possible to do and no it doesn't matter that each drive runs at different Rpm speeds.
The difference between a hard disk drive that runs at 5400Rpm and a 7200 Rpm is data transfer speed. The 7200 drive will run faster but the drives cache also plays a big part when transferring data. A drive that runs at 7200Rpm with a 16MB cache will run faster than a drive with 8MB cache. The 7200Rpm drive will run a little hotter than a 5400Rpm drive and use a little less power. Typically you’d want to use the 7200Rpm drive as the primary drive. (With windows installed on it).
The 5400Rpm drive should be used as a storage drive and be connected on the same data cable as a slave drive. How to safely remove data from the 5400 drive. Before you shut down the system, open windows explorer. Click on the C:\ than delete the Boot.ini, AUTOEXEC.BAT, and IO.SYS files. (By doing this the drive will no longer be bootable but all the data will stay intact). Shut down the system. Remove the 5400Rpm drive from the system. Install the 7200Rpm drive. (The new drive is an IDE drive. Set its jumper so it is a Master.) Guide to setting-up an IDE drive; http://freepctech.com/pc/001/installing_ide_devices.shtml
Set the jumper for the 7200 drive as a Master with a slave. (The 5400 drive will be added later).
Once the drive is configured and installed boot the system and enter the bios/CMOS menu. Press the delete key to enter the bios or watch you're screen you may need to press the F1, F2 key or F10 key to enter the bios menu. Instruction on how to move about while in the bios is shown at the bottom of the bios screen. You should see the model numbers of you’re 7200 DiamondMax drive within the main bios menu.
You will also need to set the boot menu / boot order.
Open the Boot menu. A typical boot menu would list as follows:
1st Boot device, Floppy disk drive
2nd Boot device, CD-ROM drive
3rd Boot device, Primary hard disk drive.
4th Boot device, not needed
Compaq does not provide bios settings within their user guide. Before you save and exit the bios, open the CD-ROM drive and load you're windows CD or the restore CD from Compaq. Save and exit the bios. When the system reboots it should start up the windows CD or the restore CD. Follow the on-screen instructions from the restore CD. Once windows is installed update windows. When finished it is now time to add the old 5400Rpm drive. Shut down the system. You will need to change the jumper on the on the 5400Rpm drive. Set the jumper to Slave and insert it into an open bay. Connect the data cable and power cable. Check that all cables are fully connected. Boot you're system. Windows should load. You're 5400Rpm drive will most likely be labeled as letter E. You can change the drive letter order by opening the run window. Click Start and in the run window type in: diskmgmt.msc than click ok. Open Help. Click, help topics. Click on disk management.
Compaq Presario S6020WM Desktop computer web site;
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00058482
User Guide for S6020WM
http://h10032.www1.hp.com/ctg/Manual/bpb13287.pdf
Cheers'
Mike
Feb 01, 2010 | Compaq Computers & Internet
Can not boot from cd rom...bios boot order is set
Set all in Boot priorty to CDROM
Set Other Boot Device to No.
Jan 07, 2010 | EliteGroup NFORCE 570 SLIT-A Motherboard
Dell Dimension 8300 - Can't Boot from XP Disk
When in doubt do without, that is remove the new hard drive cable and power, remove the DVD drive and try loading booting the XP from just this CD device. Enter the BIOS and check if the system sees the device. If it's not found in the BIOS then you'll never boot anything. Address it as the Primary device on the cable (I don't use CS) and see if the BIOS sees it.
If you get CD device seen in the BIOS then try to boot the CD in it. If it boots then power off and connect up your 40gb drive (optioned as Primary) on the other cable. Now power on as check the BIOS for the drive and the DVD device. If both are seen then boot the cd and try to load XP. After it's up and running install the other CD device as a Slave on one of the cables.
May 28, 2009 | Dell Dimension 8300 PC Desktop
Dell b130 upgrade to new hard drive trying to boot of from cd-rom but wont..... need help
did you change the order in the bios setinbg?put the 1st device for boot to be the CD/DVD-rom not HARD drive, to get into bios try F2., ESC, ,F12 . and in the bios setup change the order put 1st boot device to be CD/DVD-rom, then try again to setup Windows.
Mar 13, 2009 | Dell Inspiron B130 Notebook
I can;t boot my laptop compaq Evo N610c from cd-rom drive
Disable the SATA option in BIOS settings then it automaticaly takes the CD ROM
Mar 04, 2009 | Compaq Evo N610C Notebook
Acer quit working
Well, the 1st thing to check is boot into safe mode (F8 at boot) and see if you can get to the desktop.
If you can, run system restore and then see if you can boot to normal mode.
If it shuts down, boot to the system BIOS, and see if the system will continue to run, if it does, then your issue is most likely a operating system problem or a hard drive problem causing an OS problem.
If the system doesn't shut down in BIOS, next is try to boot to a CD. You may have to remove the Hard Drive to exclude it from the issue. If the system boots to a CD and will continue to run, then we are pretty sure the HDD/OS is the issue.
Next would be trying to run diagnostics on the hard drive, if they fail, replace the drive. If they pass, reinstall WIndows.
Jul 11, 2008 | Acer Aspire 5315 Notebook
My pc was doing this but now it's doing something different but simular
Try telling it to boot the CD instead of the disk for now, since you need to install from that...or perhaps a newer OS.
Jun 23, 2008 | E-Machines eMachines T3830 PC Desktop
E-Machines eMachines Desktop PC Logo
301 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
