Auto-dimming defect I am considering purchase of a KDL-40V5100 LCD TV but want to be able to ensure that it has the fix for the auto-dimming problem incorporated. I do no want to purchase a produce which requires me to search out a patch. Can I select serial numbers which were shipped with the fix incorporated or should I stick to other manufacturers?
    Filmmaker:
    Uploaded 5 video answers.
  • 43 Answers
I do not know of a reference to a list of pre-update serials, the fix has been in place for several months. I helped a colleauge with this problem, the update can be downloaded here:
http://esupport.sony.com/US/perl/news-item.pl?news_id=336&mdl=KDL40V5100
and placed on a USB drive, the tv will do most of the rest.
Sony will also mail it to you on a usb drive.
they advise to turn the Advanced Contrast Enhancer to low or off after the patch, but my colleauge was satisfied with the results of the patch and did not do this.
Posted on Jul 23, 2009
    President:
  • 1,284 Answers
Most of these issues would be firmware updates that the owner can do. In most cases Sony will send the update to you if needed.
MY TV SONY BRAVIA MODEL#KDL-40V5100 ONLY SHOWS A BLUE SCREEN AND IT DOES NOTHNIG
Sounds like tuner fault. Contact any service technician to check and confirm. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 06, 2014 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
TV powers on with no splash screen and then powers off.
Main board fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 14, 2014 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
My son thew a toy and cracked the screen can i fix with new screen model kdl40v5100
LCD Screen would cost you more than tv worth, a new tv would be good choice instead of lcd screen replacement.
Thanks.
Jul 16, 2011 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
WHAT IS THE HZ SPEED FOR THIS TV PLEASE
This set is a 60Hz model the model 40V5100 is 120Hz
If this is helpful; a vote with the thumbs up would be appreciated and Thanks for using Fix Ya
Jul 05, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
SONY KDL-40V5100 SCREEN GOES BLACK WHEN I TURN IT ON
Problem is in either power supply or the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more. Check those.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
Hope this will work in solving the problem.....
Dec 06, 2010 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
When turning on TV, sound is often absent.
Unplug,replug the tv about an hour later,let the tv reset itself.Tries goto tv menu,go to AUDIO,go down to reset the audio setting,back to factory setting.Goto menu to PICTURE,go down to reset,to resetting the Tuner board back to factory setting.The sound,should be there,now all the time.Not,than the Tuner board have problems.That the board,where the broscasting signal cable plug into it.That the Tuner board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Jul 23, 2010 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
Sony KDL-40V5100 Switches off by itself
Sorry to say but it sounds like your power supply is bad, although it is possible it is some other components in the TV because turning it off allows all diodes etc to power down completely. Unfortunately after a bit it happens again which leads me to believe again power trouble.
Nov 05, 2017 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
Sony kdl-40v5100 has handshake problem
1.This issue sounds as though the TV connection circuit has an issue.
2. You have changed the DVR and the HDMI cables and you still have an issue with the video (pink screen) indicates a video circuit issue ( improper voltage or current) at the video section of the circuit.
3. This will require some troubleshooting by a qualified tech.
4. To make sure, try connecting another properly working LCD TV to the cable box or DVR an check.If you get a picture and sound properly it is the TV.
5. Usually a cable box is QA'd (quality assured) by the company and will not be sent unless tested 1st
Feb 05, 2010 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
KDL-40V5100 TV HDMI Issue
I have the same problem did you ever find a solution
Jan 07, 2010 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
Will A Sony Bravia KDL 32s2010 TV purchased in the
This TV will work in Australia as its multi system and auto-power TV.
Apr 13, 2009 | Sony BRAVIA KDL-32S2010 32 in. LCD...
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
