Question about Motorola Mobility H3 Bluetooth Headset, Black Headset
Blackberry curve is asking for a password when setting up bluetooth. I have an Motorola H3
Posted on Jul 23, 2009
Trying to pair my uniden bt108 bluetooth with my black berry. dont know password
Ok, well the password is something that you set from your blackberry device while you are in the process of paring.
So when you begin to pair the device your BB will ask you for a password, that's how you set the password. Then whatever password you chose when your BB asks for one will be the same password you use on the BT108 device.
Sep 22, 2010 | RIM BlackBerry Curve 8520 Smartphone
I can't get my H3 headset to pair or even be recognized on my blackberry curve or my envy. What can i do? it still turns on.
Try to reset your bluetooth headset by pressing the power key and volume up key until LED glows in a different manner, now you should be able to connect to your mobile.
May 20, 2010 | Motorola Mobility H3 Bluetooth Headset,...
What is the password to activate my motorola H3 bluetooth for my blackberry curve? thx.
When you pair a device, the passcode is typically set by you. If not, however, 0000 is a common passcode for motorola.
Hope this helps! Rate my solution!
Jan 07, 2010 | Motorola Mobility H3 Bluetooth Headset,...
I want to pair with another device, a blackberry curve
I have a Blackberry curve and i use this headset. You just hold in the key to your bluetooth till it stays solid blue light, then go on your blackberry under "options" then "bluetooth" then search or add new device. it will search it, pascode is "0000" should load up then. then everytime u put ur bluetooth on and hit the button to turn it on ur blackberry will pop up and ask if you want to use it, just hit yes and your good to go.
Mike
Jun 12, 2009 | Motorola Mobility H300 Wireless Headset
Won't pair with Motorola HS850 headset
How to pair a Motorola HS850 bluetooth headset How to place a Motorola HS 850 bluetooth headset into paring mode:
  1. Close the boom to turn the unit off.
  2. Hold down the call button until the blue light comes on.
  3. While holding down the call button, swing the boom open.
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
Apr 20, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Blackberry curve won't pair with my bluetooth headset
Try the following. Hope this helps.
Okay,
1. Go into "Media" on your BlackBerry and enable incoming files (Menu-->Receive using bluetooth).
2. Find the file on your friend's device that you wish to send, and beam the said file accordingly.
2a. If you have not "paired" (created a friendship between) the two devices before, you will need to do this first...
2b. One of the devices will ask for a PIN code first and on this device you need to create a four-digit, numeric password that can be anything you like.
2c. On the second device, enter the four-digit, numeric password you created and follow the simple, on-screen prompts on both devices to complete the pairing (you can also pair the devices in advance by going into Menu-->Set Up Bluetooth).
2d. Depending on the devices being used and the time taken to complete the pairing, you may need to re-send the file (go back to step 1), otherwise, continue below...
3. When your friend's device tries to send you the file, your BlackBerry should ask you to name the file and where to save it; if you have not set the device as "trusted" in the bluetooth settings (Options-->Bluetooth-->your friend's device), you may need to approve the file transfer first though.
4. The file should now be on your device.
Note: by default, all
* Pictures are saved into /Device Memory/home/user/pictures or /Media Card/BlackBerry/pictures if you have a memory card.
* Sounds (including songs) are saved into /Device Memory/home/user/ringtones/ or /Media Card/BlackBerry/ringtones/ if you have a memory card.
* Videos are saved /Device Memory/home/user/videos or /Media Card/BlackBerry/videos if you have a memory card.
In other words, unless you specify somewhere else in step 3, this is where you will find your file.
And remember, your incoming file transfer WILL NOT WORK UNLESS YOU FIRST "PAIR" (CREATE A FRIENDSHIP BETWEEN) THE DEVICES, go into Media and CLICK MENU-->RECEIVE USING BLUETOOTH!!!
Jan 28, 2009 | RIM BlackBerry Curve 8310 Smartphone
BlackBerry won't pair with device anymore via Bluetooth
1. Go to Options/Bluetooth
2. Select device found
3. Select device properties
4. At Trusted select yes
It'll never ask again
Dec 30, 2008 | RIM BlackBerry Curve 8310 Smartphone
I can't pair my Motorola H700 to my Blackberry curve.
http://khaoohs.wordpress.com/2007/11/16/motorola-h700-bluetooth-blackberry-pairing/
this actually works.
Aug 09, 2008 | Motorola Mobility H700 Wireless Headset
I have a blackberry curve and am wanting to pair my bluetooth HS850 to it. Please help!
There actually is a trick to the HS850 - flip the boom closed, then hold down the button just until the light holds solid - IMMEDIATELY after it does flip the boom open and this should keep the light solid. Then on your cell/device search for bluetooth devices - you should be able to find it now. Passkey for most devices is 0000.
Jun 30, 2008 | AT&T Blackberry Curve 8300 Smartphone
Motorola Mobility H3 Bluetooth Headset, Black Headset Logo
171 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
