SOURCE: Cant get LG HBS-250 into pairing mode
Make sure the headset is off when you hold the call button for 5 sec. And don't stop holding it when you hear/see something happen after the first 2 sec. Keep holding it for the full 5 sec. The blue light will become solid which means it's in pairing mode.
SOURCE: What is the pass key code to pair lg tone pro HBS 750 to my ps3?
1. You need to charge your headset to full capacity using the charger supplied with it.
2. Disconnect it i.e. your headset from the charging source.
3. Press and hold the "Call/Send" button located on the front of the headset for like 5 seconds to activate pairing mode.
4. You should notice an indicator light begin to flash. Your headset is in pairing mode already.
5. By now, you must have had the bluetooth on your PS3 on.
6. Have both devices pair with each other.
LG headsets use a pairing passkey of four zeros ("0000").
SOURCE: Hbs-730 the blue light won't stop blinking and turn solid so I can pair it with phone
Blinking blue means the HBS in a pairing mode. Go to BT settings on your phone, find your hbs and push "pair". If asked put the code 0000 or 1111.
