My lap not work
I have a problem in my inspiron 6000 sometimes works and sometimes does not work and when it does not work lamps lights then turn off the device
  • Art Ellison
    Art Ellison May 11, 2010
    Please give me more information- Are you saying that sometimes you can turn it on and it works but other times when you try to turn it on it doesn't start? Or does it start and then shut down?
Monitor will not come on on my dell insprion 6000 but works fine with an external monitor
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Jun 11, 2012 | Dell Inspiron 6000 Notebook
Try turning on but not able to
hi, you need to test the adaptor first, it is works check the pc plug in , you must to open the lap top for do this
Aug 10, 2010 | Dell Inspiron 6000 Notebook
My Dell Inspiron 6000 (which I think I bought in
Have you tried this:
1. After removing the battery
2. Press and hold the power button for at least 10 sec.
3. Put back the battery
4. Turn it on
if this doesnt work, there could be a problem with your operating system. Try accessing safe mode if you can login .TAP F8 continously on the dell logo screen, and it will open advance boot options. (Just select safe mode) If safe mode boots properly try running system restore to restore it back to the previous date where your computer is still booting to windows. Hope this helps
Dec 08, 2009 | Dell Inspiron 6000 Notebook
I have a dell inspiron 6000 lap top I cannot
Press and hold the "Ctrl" and "F11" keys simultaneously when the Dell splash screen appears. The "Dell PC Restore by Symantec" window will appear. Click "Restore."
Just make sure you have saved all your data before doing that.
Oct 29, 2009 | Dell Inspiron 6000 Notebook
I have a dell inspiron 6000 the screen goes black
the lcd screen may be causing this. Try to connect the laptop to an external monitor and have both working at the same time by toggling Fn F8 on the keyboard. Wait until it goes black on the LCD. post back what happens. If the external monitor wont go out when the lcd does, the lcd may have to be replaced. If the monitor goes out too, it's a video card issue which may be resolved by reinstalling the driver.
Jan 31, 2009 | Dell Inspiron 6000 Notebook
My lap topwill not turn on.
Try to check if your AC adapter has a light itself. If it the light is off. Then try a known good adapter. If the AC light is green, then try to wiggle the cord from the port and see if it ain't loose. Try to also check if the AC pin is not bent or broken.
Nov 25, 2008 | Dell Inspiron 6000 Notebook
Not starting
Just to sum it up, are we talking about the Dell Inspiron 1750 or a Dell Inspiron 6000? Seeing two different things here. With the regards to the ac adapter, How "Warm"are we talking about here. 1 to 10. "1" 100 below 0 or "10" Nuclear Reactor Hot? Any adapters can get warm to the touch without overheating and frying. Was there a blackout or power outages in your area or T-Storm on the day you left. Take off the battery from the laptop. Check the battery lights. Do they flash or do they all light up when you press the button. With the laptop not working, lets hope the battery didnt fry the mainboard. Have you try to fire it up again after the adapter has a chance to cool down. By now, it should be fine, if you haven't use it.
Let me know
comier957
Aug 10, 2008 | Dell Inspiron 6000 Notebook
Monitor is very dark
I have to assume you have tried through existing means to change brightness and contrast.
These are generally provided for the user.
LCD screens are backlit via a fluorescent lamp. This is a high voltage device so the problem could come from either a failing lamp or the inverter circuit that drives it.
Access to the lamp varies greatly and to even check it may well be a job for a technician.
Mar 29, 2008 | Dell Inspiron 6000 Notebook
Computers & Internet Logo
David Payne
David Payne
