Hello, If the problem is that water come from steam arm only,and if you try to make coffe is nothing happen- try to make several coffees with descaler liquid in the water tank.
A common place for a leak under the machine is the barista seal that goes in the bottom of the boiler around that eject rod. Barista seal part number is MS5002202, Seals on the tamping piston are MS5002040 (there can be 1 or 2 of these piston seals) If fixing the leaks does not fix error 6 then I expect it will end up being the distributor. Part number MS2A01500
Hi I would say you have a stripped thumb screw. It is in the top left side of the brew unit and holds the filter screen in. If it is stripped there will be water or coffee in the pocket on top left of the brew unit.
that usually means you have a game or java application running. to get it off try going into your games and apps and ending any game or app that's may be running. this should work
A aroma is very easy to open up so if you can find a erpair station near you i would suggest you to fix it your self.
open it up and reset the fuses there is one on the top of the boiler when you open it up.
Then you need to prime it.
Turn it on ( as this should work now)
open up the steam valve and then press for making of a cup of coffe. this hould prime the machine though the steam nossle.
if you are loosing our steam you have a seal problem you have to open the machine and activate it look were the steam come out remove the piece clean and ghange seal good luck cheers
there is normally a special rice bowl, which looks like the lid upside down which is used for rice cooking and should be placed at the highest point in the upper steam bowl and place the lid on top.
for 1 cup of white regular rice, use 1 1/2 cups of water, steam for 45-50 mins
for 1 cup long grain rice use 1 2/3 cups of water, steam for 50-55 mins
for 1/2 cup of brown regular rice, use 1 cup water and steam for 42-45mins
