"H-SET" is the "0" hands position.To do this right,go to manual (link below) by using the module nbr found on the back cover (4 digit code in a frame). Timepieces Watches Manuals CASIO
Press the "mode" button (bottom left) until the display says "HS" then press either the top right or bottom right button (depending whether you want to advance or ****** the hands) until the hands point the correct time.
When you have finished, press the mode button until the display returns to normal.
If you have any problems, (I have given you instructions that apply to my Casio, which is a different model, then you can get instructions for your model from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals", watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Thank you for contacting FixYa.
To set the analog time, press the lower left button 6 times. Next, press and hold the upper left button until the digital time starts to blink. This indicates that you are in analog time setting mode.
Analog time adjustment is completed using the lower right button. Every time you press the button, the analog time will advance 20 seconds. If you need to make a big change to the analog time, press and hold the lower right button to make the hands move faster. Once the analog time is set, press the upper left button to exit the analog time setting mode. Best regards. Jewel
On the assumption that my Casio watch works the same as yours, press the mode button (lower left), until "HS"appears, then use the buttons on the right to advance or ****** the hands.
If this does not do the trick, then go to the Casio web site "casio.com" select "support"then "manuals"; accept terms and conditions and the select "watch manual archive"
Insert the required number off the back of your watch and download the instructions.
I found a hand setting mode. Press lower left button 6 times until the readout shows HS. Press and Hold Upper Left Button (A) until flashing. Press lower right button (D) to move the hand forward. Press upper right button (B) to move the hand backwards.
Dear I received gift of G-300 Casio watch but could not adjust the analog time where as digital time adjusted. Could you please help me to guide for adjsuting its Analog time.
