No cool air but only fan working in central air condition
Have central air condition and the gas people came to do some work abt 2 days ago and now the cool air is not coming out but only the fan work in fan mode and in auto. what do u think the problem might be pls help. thanks
  • 614 Answers
Check to see if outside unit is running. If it is check breaker,float switch inside. If everything is ok You have to call a Service Tech. There is only so far you can go. If you think the gas company had anything to do with it call them back and tell them it was working before you checked the gas. They could have left something off. Russ
Posted on Jul 23, 2009
Radiator cooling fan, air con & central locking not working
Search Results
    newrremedies - Range Rovers
    www.rangerovers.net/newrremedies.html
    Feb 1, 2012 - Shop Manual: To diagnose and cure problems on the 4.0/4.6 it is almost... When the air conditioning failed during a summer off-pavement expedition in the..... the security/central locking portion of the service manual describes a process .... I asked the dealer to check the radiator and the viscous fan clutch.
    Air Conditioner Fan Not Working - Repair Parts ...
    www.repairclinic.com/RepairHelp/...Air-Conditioner/...---/Air-conditione...
    Heating & Cooling ..... Most Frequent Causes for Air conditioner fan not working ... On one side, the fan blade draws in outside air over the condensing coil to ..
Jan 13, 2016 | Cars & Trucks
Fan doesn't work in heat mode it works on all other functions. Heat does come out but fan doesn't kick in. Outside unit is operating
AC inside fan doesn't come on AUTO - DoItYourself.com Community Forums
www.doityourself.com > ... > Air Conditioning and Cooling Systems
Jul 21, 2004 - The inside FAN doesn't run when in AUTO mode. If I leave ... Is the thermostat not working correctly or something in the AC unit causing it to do this? Thanx ... The unit is electric central air-conditioning(heat and cool). It made ... Carrier A/C condenser fan not working
Jul 27, 2012
Heater Fan Doesn't Work on AUTO
Jan 23, 2006
Blower doesn't work in ON position after repair
Mar 25, 2005
Central AC/Heat, Blower Doesn't work on Auto
Nov 30, 2004
More results from www.doityourself.com
Nov 01, 2015 | Heating & Cooling
Whirlpool model WC260A-1A cannot find manual and central air conditioner will not turn on worked well 2 days ago.
Does the fan turn on when you have it set to cool? does the furnace still work? Does the fan auto, and on options still work?(for example when on its on, when auto, and neither the cool or heat functions should be running, the fan is off)? Basicly i'm asking your to test your thermostat right now.
Aug 04, 2013 | Whirlpool Central Ac Condenser-new...
Central air conditioning unit
you must do the maintenance . Call to the tech for to make the maintenance required. to due the activity of work.
God bless you
Jul 19, 2013 | Vehicle Parts & Accessories
It is 105-110F outside and I think that I am only getting no more than 2 degrees of cooling from my central air conditioning unit. I have been changing my air filter about every two days, two months ago...
Two thoughts come immediately to mind. Your outdoor condensing unit may not be running at all or is extremely low on refrigerant due to a leak or you have flexible
ductwork and it has come apart under your home especially in the return area.
Also, if you feel the larger of the two lines to the outdoor unit and it is not "Beer can cold" then the compressor is most likely not running, just the fan which would give the appearance the unit is running.
This would most likely be a failed capacitor. (secure all power from
all sources to inside and outside unit and pull out the disconnect before attempting
replacement). Check for bulged cans or leaking cans and replace with exact same
microfarad/ voltage rating. You can get the caps from any HVAC store for around 20 dollars.
Aug 07, 2011 | Heating & Cooling
Air conditioning not too cold ??
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
Let me explain in layman's terms how the air conditioning (AC) system works and what could be happening to your car.
Like your body, the air conditioning compressor is the heart of the AC system, and Freon is the blood. The compressor pumps Freon throughout the AC system, either the older type R12 which costs as much as gold it seems these days, or the new environmentally-friendly R134A Freon. This Freon is a gas and liquid combination that is compressed and circulated throughout the air conditioning system. The compressed Freon is pushed through the system under pressure and is passed through different sized metal and rubber hoses and a special valve called an expansion valve that cause the gas to expand and contract.
This expansion and contraction makes the Freon gas very cold. This cold gas makes its way via metal lines into the dash area of your vehicle to the evaporator core. This evaporator core is like a small radiator, except it has cold Freon circulating inside and not hot antifreeze. A small fan (the AC blower fan which you control from the control panel on the dash) sits in front of the evaporator core and blows air across this cold evaporator and then through the vents inside your vehicle.
The other objective of the air conditioning system is to remove the heat from inside the cab of the vehicle. This heat is removed by the Freon with the help of the AC condenser located at the front of the car (usually in front of the radiator). The Freon coming back from the evaporator carries the heat from the cab to the condenser via rubber and metal hoses. Just like your radiator, the condenser is lightweight aluminum with many internal winding coils.
The Freon travels through these coils, and in between these coils are small slits or fins that the Freon is forced through. The condenser will have an electric cooling fan mounted in front or behind it to push or pull air through these fins to remove the heat from the Freon. Some vehicles still use the old fashioned fan blade driven by the engine to pull air across the radiator and the condenser.
Now I know that is just a tidbit of information on how the air conditioning system works, and it is very general, but I wanted you to know what to look for to give you insight as to what might be happening with your vehicle.
A few causes of low cooling efficiency or no cooling at all at idle are:
Lack of air flow across the condenser. Make sure the electric cooling fan motor near the condenser is coming on, or in models that are equipped with a fan blade make sure this fan is turning and is turning very fast.
Low Freon levels. Freon level and pressure should be checked by your certified air conditioning mechanic.
Overheating. If the engine is running hot or overheating, it can have a noticeable negative affect on the air conditioning system. Some cars have two electric cooling fans, one for the air conditioning condenser and the other for the radiator. Make sure they are both working properly. Usually at idle on a hot day with the AC on both fans will be on.
When the vehicle is traveling at freeway speeds, the compressor is pumping the Freon throughout the system much faster and harder than at idle. There is a dramatic increase in air flow across the condenser due to 55 mph winds, and the engine is usually operating at a cooler, more efficient temperature as well, thus allowing the air conditioning system to operate efficiently.
Note: An air conditioning system that is somewhat low on Freon can still feel comfortable at freeway speeds due to the added air flow across the condenser which can overcome the ill effects of slightly low Freon. Periodic air conditioning performance checks by your mechanic are the best way to keep the system in great shape.
Hope this helps.
Goodluck
Oct 08, 2010 | 1998 Cadillac DeVille
The air condition blow out cool air but stop in 3 second, low fan, the switch seen to work ok the inside switch, the freeon was put in to days ago the pump is turning but hi persure is not activating to...
need to replace the pressure sensor and fill up the gas 134 R or the filter gas is blocked , when is running the pipe are one hot and the others is cold be sure the vent fan is switch on
May 24, 2010 | 1997 Cadillac DeVille
Air conditioning compressor
the missing part could be the cover... its ok , not cooling very well could be:-
1, aircon fan not working
2, system need to be service
3, need to add air-con gas
for air-con works only in full position.... need to change the switch.. its faulty.
Oct 19, 2008 | 1988 Daihatsu Charade
1994 Hyundai Excel Air conditioning RADIATOR´S FAN works always very fast
this not really a problem as the fan speed is controlled by the high preasure switch in the ac system the hotter it is outside the higher the preassure will be in the system as hot as its been the preasure is high already when the compressor cycles it pulls suction on one side and outputs high preasure on the other the fans cool the condenser the higher the ambient temp the faster they go so all is fine...
Jun 08, 2008 | 1994 Hyundai Excel
Heating & Cooling Logo
204 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
