Question about HP Officejet J5780 All-In-One InkJet Printer
Printer say, Cartridge Error: remove and re-insert cartridge on left. How do I do this?(where on left
    President:
  • 2,306 Answers
When you open the cover the inks come to the center, the color one, the one on the left side has a problem.
Posted on Jul 23, 2009
Hp4355 print catridge error
Each cartridge having printing life, as long as cartridge health condition is good it won't gives any trouble. Subjected series printer having mono & colour cartridges,1. Remove both cartridge from the printer 2. Switch on & wait till message appears for insert the cartridges..3. Insert mono(Black) cartridge, close the door & wait till message appears on screen. If message appears same as cartridge error mean that mono cartridge is faulty replace it, if message appears like insert another cartridge, it's confirmed that colour cartridge faulty.. Replace it..
Apr 28, 2012 | HP Officejet 4355 All-In-One InkJet...
My printer has an error "no print cartridge?
10_14_2011_1_19_00_am.jpg> Switch off the machine, remove power cord,> remove right,left & back doors,> see the snap shot observe sensor & spring> clean the sensor from dust > check spring dislocated? fix it properly, ensure that sensor flag maintain its home position> insert/remove cartridge,observe sensor flag moving properly > Power on the machine, check.. OK?,
Oct 14, 2011 | HP LaserJet 3050 All-In-One Printer
"LEFT CARTRIDGE INCORRECT" everything was ok
Re-seat the black cartridge and make sure it's properly inserted. If error continues, try to insert a different known working black cartridge to determine if the other is faulty.
Apr 26, 2011 | Lexmark X4650 InkJet Printer
HP 4215 "cartridge Error"
Remove the color cartridge and close the lid
If the error comes up again, remove the black cartridge and insert the color cartridge.
When the error disappears the faulting cartridge will be the one that has been removed
from the printer.
The cartridge will need to be replaced
Feb 15, 2011 | HP Officejet 5610 All-In-One InkJet...
I have a lexmark printer model 5495,it tells me that the right cartridge is incorrect, i just put in new cartridges in . the cartridges 28-black/29-color, it still tell me the samething
Hi, The Right Cartridge Incorrect error message generally indicates a communication error between the All-In-One and the cartridge. This can be due to a faulty cartridge or to a simple interruption in the communication between the cartridge and the All-In-One. The procedures below will help you identify the cause and resolve the issue.Lexmark uses, at least they used to, a chip in the ink catridges that verifies that the ink catridge is Lexmark and hasn't been refilled. There are ways around it, which is why third party cartridges work. Yours may not have been reset or damaged when refilled. Follow the below steps: 1) Disconnect the power from the printer.
2) Remove the black power brick/block from the rear of the machine. (It may be a little tough to pull it out the first time you remove it.
3) Open the top of the printer/multi-function unit.
4) Gently pull the ribbon in order to center the printer cartridge carrier.
5) Open either the left or right side and remove the cartridge. (Depends on which side the error is occurring on, black on the left, color on the right)
6) Verify that all of the plastic strip that covered the new contacts on the cartridge have in fact been removed.
7) Wipe both the cartridge and printer contacts with a dry, lint free cloth.
8) Wipe the bottom of the cartridge with a damp, lint free cloth in order to verify that the ink is flowing and looks correct.
9) Make sure there is no water remaining on the cartridge.
10) Re-insert the cartridge into the carrier and make sure that it is bottomed and inserted all the way to the rear of the carrier slot.
11) Re-insert the power brick/block.
12) Re-connect the printer power cable.
13) Power on the printer and the error should be resolved.
14) Run the print alignment and print or copy several pages to insure the problem has been resolved.
IF YOU NEED TO BE WITH THE ORIGINAL CATRIDGES PLASE FOLLOW THE BELOW STEPS.
ALWAYS PREFER LEXMARK CATRIDGES FOR LONG LIFE OF PRINTER
  1. Remove the indicated print cartridge.
  2. Disconnect the power cord from the electrical outlet.
  3. Reconnect the power cord to the electrical outlet.
  4. If the button_power_0.jpg button is not lit, press button_power_0.jpg.
  5. Reinsert the print cartridge.
  6. If the error:
    • Does not reappear, the problem has been corrected.
    • Reappears, replace the print cartridge with a new one.
      BESTWISHES.....
Dec 19, 2010 | Office Equipment & Supplies
I have followed the instructions exactly for replacing the black toner cartridge on my Magicolor 2300 DL, but i still have the error message "Replace Toner Black." I tried taking out the cartridge and...
If you have changed the toner cartridge, the printer must complete a calibration cycle (up to 150 seconds). If you open the door before the Ready indicator on the control panel lights up and the Error indicator turns off, the printer stops and repeats the calibration cycle.
1. Open the Status Display (double-click on Status Display icon in the system tray on the lower right-hand portion of the task bar, OR click Start/Programs/KONICA MINOLTA magicolor 2300W Utilities/KONICA MINOLTA magicolor 2300W Status), and then check which toner color is empty.
2. From the Print menu choose Toner Replace...
3. In the Color list box, select the color of the toner cartridge to be replaced (CYAN, MAGENTA, YELLOW, or BLACK).
4. Select the capacity of the new toner cartridge (1500 or 4500).
5. Click OK.
6. When the toner indicator on the control panel starts flashing, open the printer's front door. The carousel is automatically repositioned so that the appropriate toner cartridge can be removed.
2300-0.gif 7. Insert your thumb and index finger into the two holes in the front of the toner cartridge, and then pull the cartridge straight out about 6" (15 cm).
2300-1.gif8. Support the middle of the cartridge with your left hand, and then pull out the cartridge.
2300-2.gif9. Remove the new toner cartridge from its shipping carton.
10. Remove the protective cover clearly marked 'Remove'.
Each toner cartridge has a colored end that corresponds to a color inside the cartridge slots. Always install the toner cartridge in the slot of the same color.
2300-4.gif11. Support the middle of the cartridge with your left hand, insert the thumb and index finger of your right hand into the two holes in the front of the toner cartridge, and then insert the cartridge so that the guides on the cartridge fit into the rails in the cartridge compartment in the carousel.
2300-5.gif12. Gently push the new toner cartridge into the printer.
13. Close the printer's front door.
The printer must complete a calibration cycle (up to 150 seconds) after any consumable has been replaced. If you open the door before the Ready indicator on the control panel lights up and the Error indicator turns off, the printer stops and repeats the calibration cycle.
Sep 01, 2009 | Konica Minolta magicolor 2300DL Laser...
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    OR
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    Error code 1203
    To determine whether this error is due to a cartridge failure or a hardware problem with the printer, do the following: Make sure the printer is powered on. Open the printer's top cover. The print cartridge carrier moves and stops at the loading position. Press down on the cartridge lever to raise the cartridge lid. Remove the cartridges. With the cartridges out of the printer, close the top cover. Power the printer OFF and then back ON. Check the operator panel to see if the 1203 error has returned or if a new message is displayed. If the message displayed is 1203, there is something wrong with the printer hardware. Please contact Lexmark Technical Support. If the message is Cartridge Missing, reinstall the cartridges into the printer. Insert the black cartridge in the left carrier. Insert the color cartridge in the right carrier. Snap the lids closed. Close the top cover. Check the operator panel. If the 1203 message is still present, you need to insert one cartridge at a time to determine which cartridge is producing the failure. With one cartridge in the carrier, close the top cover and check the operator panel. If the 1203 message is displayed, that cartridge is producing the error. If Cartridge Missing is displayed, the second cartridge is the defective item. Please replace the defective cartridge.
    Aug 20, 2007 | Lexmark P315 InkJet Photo Printer
    HP Officejet J5780 All-In-One InkJet Printer Logo
    153 people viewed this question
    Seeker5211
    Seeker5211
