Question about Vacuums
Kenmore Beltless Vacuum brush will not spin. Everything else works.
    Sniper:
  • 84 Answers
There is a reset button on the side of the lower base of the machine, plug in the unit turn on the switch to the brush and vacuum are both engaged hit the reset button, remember the roller will not engage when the handle is in the upright position, release the handle and your ready to go.let me know if that helped you . thanks renevacdoc
Posted on Jul 24, 2009
  • Nikosala02 May 08, 2012
    Like you need all these POINTS
  • Nikosala02 May 10, 2012
    Your mean
If kenmore progressive brush won't spin buy a new motor with a belt Gage and a new brush roll and a belt
Posted on May 08, 2012
2 Suggested Answers
  • 61 Answers
SOURCE: I have a kenmore beltless upright the beater brush dosetn spin
If it is direct drive then the motor or the wireing to the motor are bad. If it is gear driven then the gears are probally stripped.
Posted on Apr 15, 2009
Why did the brush roller stop spinning?
With the cleaner unplugged, turn the unit over and look inside the opening where the brush is located. Do you see the clogging of the brush with lots of hair? If so, you will need to disassemble it to remove the hair. In any case, you will probably need to take off the cover to see if there is an obstruction jamming the brush. Also, check to make sure that motor for the brush is getting power. If there is an electrical cable on the outside connecting the brush housing to the rest of the vacuum cleaner, check if it is disconnected. When you have the cleaner on, do the lights glow? Do you hear the motor running? Try the above and report back.
Jul 21, 2015 | Kenmore 31913 Progressive Direct Drive...
Cord got into brush area. pulled cord and now rollers will not turn. Beltless drive Vacuum kenmore 3 years old 11635922500
Greetings,
Your Kenmore Beltless Drive upright model 116.35922500 has an overload protection system designed on it. This will prevent anything from damaging the brush motor, or your roller brush if you were to vacuum up something in it (i.e. your cord).
The reset switch can be found in this below diagram as item # 3. This would be the first thing I would try. Simply just push down on the red switch actuator while the vacuum is on, then recline the handle down. Did this fix it?
If this doesn't fix it, please let me know by requesting a clarification request, or by adding a comment to the repair here on Fixya. I think from how you explained it that this should fix your vacuum cleaner. I hope this helped you. If this was helpful, please be sure to rate the repair solution as helpful by clicking the thumbs up icons in the top right hand corner of the repair. Thank you very much,
Chris Jones
GoVacuum
Mar 23, 2010 | Vacuums
The brushes have stopped spinning. This is a
the brush spins on a bearing, you might want to get to the bearing and make to it has not cracked or broken.
Nov 30, 2009 | Kenmore 33923 Bagged Upright Vacuum
I have a model 116.35922 beltless drive vacuum. The agitator brush will not turn with the vacuum running and the handle down. The brush turns by hand and the reset button has not popped. Ther is nothing...
I just had the same problem. The roller will not turn if the unit is overheated. I discovered that my bag was too full. I changed the bag then the roller started turning again. I don't know if this is true cause and effect, but it couldn't hurt to try.
Aug 23, 2009 | Kenmore Vacuums
Vacuum roller stops turning
with cleaner plugged in and turned on, push the little reset button on the side of the lower base of vac. Remember that the brush will not turn in the upright position. release your handle and you should be in business. hope this helps. please let us know. thanks renevacdoc
Jul 22, 2009 | Kenmore 31913 Progressive Direct Drive...
Apr 11, 2009 | Windsor SR12 Sensor Bagged Upright Vacuum
My kenmore beltless upright canister vaccuum doesn't spin anymore
Ensure the agitator is not bound up and can be moved manually by hand in both directions. Clean any string or binding material if you find it. Press the reset button on the top of the chassis. If it clicks, then you should try turning it on and see if the agitator spins. If it doesn't spin, I have had luck giving a sharp kick to the top of the chassis.
Mar 24, 2009 | Kenmore Progressive Bagless Upright with...
Non spinning brush
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=632342
Generic problem for all Vacuums
Non spinning brush
Posted by tillie14 on May 29, 2008
I have a Kenmore upright beltless that suddenly, the brush stopped spinning. Do you have an answer for this?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. On the Kenmore upright the belt is broken and needs replacing and you can take it to Sears / Kenmore or a local vac dealer and they can change it for you or you can attempt to do it yourself, usually it just takes a screwdriver and either a flat or a geared belt for less than $10.00 to $15.00 is an estimate.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 29, 2008 | Vacuums
Vacuums Logo
3,387 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
