Cannot find how to get out blue screen with D V D on it tried switching off and on again but still there
  • 66 Answers
Switch you main source back to tv whenever you're trying to get out of any of your component source which is set to DVD
Posted on Jul 29, 2009
Compaq presario b1900 fails to give output to monitor. If output comes out it gives blue screen and shuts down. If you switch on again the fan and disk do run but no output to screen. An external monitor...
That blue screen and shut down, means a problem on both OS and Hardisk.
If you got any hardisk for that laptop. try it and am sure it will work.
The faint beep means a good memory card.
Hope that helps!
Dec 02, 2011 | Compaq Computers & Internet
Blue screen of death
usually blue screen is shows when there is a problem on your computers memory on your hard disk drive,first try to clean the memory by using a clean paper on the contacts of the memory that is usually copper in color then after cleaning if the blue screen comes again try to replace a good memory if the blue screen appears again then try to reformat the hard disk drive which is the final solution to your problem.. hope this helps you
Jul 25, 2011 | Asrock P4I45GV R5 Motherboard
Hello, well I hooked up my computer to my vizio with a vga cable. At first it worked just fine, then once I tried changing the resolution for a video game, the screen went blue and says "not...
The VGA cabel has vast signal capacity. However, the computer to has as much sigal cacity. The TV also has as much signal capacity as well. The computer in this situation is providing the signals to all devices connected to the insfrusture. However, the computer has a functionality requirements mode. For exaomple, the computer blankout whenever resolution is increased is n consideration of requirng so much power supply for all displays on several powerfun screens of much high defincition capapacity. The more high definition the computer, the possibility of powering signlas to TVs of much least intensity not vise verser.
Jan 11, 2011 | Computers & Internet
My advent 7108 had the blue screen followed by the white screen
it is Hard disk problem. pls replaced it & installed os again.
Aug 21, 2009 | Acer Aspire 4720 Notebook
Vaio wireless lan switch repeatedly restarts windows
Thats sounds like the wrong drivers for the network card. Some models can have different models or brands of cards so you can get the wrong one in there. You should be able to boot up in safe mode (F8) and then go under control panel - system- hardware manager-network adapters. Find the card that is causing the problems highlight and delete it. Then reboot. This takes the card out of the system and it will be detected as a new hardware next startup. Then try another driver.
You might want to go to the Sony website and check under support to see what other drivers you can get to try for your model. There might be 2-3 to try. Usually the oem disks are right but the replacements don't always get things right.
If this were hardware you shouldn't get the bluescreen of death (BSOD). That usually means software or drivers.
Jul 21, 2009 | Sony VAIO A260 Notebook
Blue screen
just to the bypass code but if the teh battery is disconncected you have to do it again
Oct 06, 2008 | Jensen VM9510 Car DVD Player
Blue screen when using tomtom6
you try to change you lcd or screen of your cellphone
Aug 01, 2008 | Nokia N73 Cellular Phone
Toshiba 42wt29b. screen keeps turning blue
MMMM Hard call here. The fact that it does try to come on blue maybe an indication that the power supply regulator circuit is good. It could also be a shorted blue tube and when it comes on its overloading the screen drive and the set goes into overload protection shutdown. The real way to see Would be to pull off the blue crt socket as well as the Hi Voltage lead on the crt and see if the set comes on without blue. If it does Your gonna need a pict tube. If it dosent then troubleshooting along the switched power supplys would be neccassary.. BUT I advise you THAT IF YOU HAVE NO EXPERIENCE TROUBLESHOOTING TV SETS PLEASE SEEK A PRO TO ASSIST YOU AS THERES VERY HIGH VOLTAGE INSIDE THESE SETS EVEN IF THEY ARE UNPLUGGED. GOOD LUCK
Jun 28, 2006 | Toshiba 42H83 42" Rear Projection...
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
