Question about Sony KP-57WV600 57" Rear Projection HDTV-Ready Television
Red CRT tube has stopped working on Sony KP-57WV600
My TV is 6 years old, some repair techs want to charge me $500 to replace it, some have said Sony no longer supplies the CRT and I should buy a new TV...What to do?
Is there a source to purchase the CRT and replace it myself?
Should I spend the $500 and have a tech come to my home and perform the repair, or do I go shopping?
Thanks, Mike
    Novelist:
  • 123 Answers
Don`t even think of replacing it yourself, You don`t just change the tube which involves disharging the 40 000 volts from the tube, You also have to perform a convergence setup where the three beams have to be overlayed or superimposed on top of each other right across the screen. This is a very time consuming job and it`s not easy, I used to do this and you NEVER get it perfect. You have to know how to get into service mode. etc etc. What the engineer has said is quite right, the problem is it takes two men to dismantle and pick up the chassis from your home and take it to the workshop, It has to be worked on, new tube ordered and as I mentioned earlier, the mammoth task of setting up the convergence. When all this has been done, two men have to return the chassis and reinstall it into the cabinet. When you get it back, the other two tubes are the same age as the one that has already failed, who`s to say when one of the others will decide to pack in. It`s a shame, but I think I`d purchase a new set where you get 12 months guarantee or even longer nowadays with many more functions than your has now with better picture quality due to technological advances etc etc. Ian
Posted on Jul 23, 2009
  • 11,896 Answers
You can get the crt's at:
www.crtsolutions.com
www.sphere.bc.ca/test
RecycledGoods.com/crts.html
PartStore.com
Have a sony kp-57ws500, tubes are going bad. Should I fix or get new tv. How much are new tubes. Red is out now. How much is one?
This is one of a group of sets with bad tubes, many were replaced under warranty (it seems they actually put the wrong ones in thousands of these sets)
The tubes are no longer available from Sony and only available on a rebuild basis---figure over 350 per tube plus labor.
IF THE SET IS COMING ON RED, GREEN OR BLUE SCREEN, AND OR SHUTS OFF---THERE IS A WAY THAT REQUIRES NO PARTS TO TRY TO ADJUST IT.
Give me a better idea of what the set is or is not doing and I would be happy to advise you.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Sep 17, 2010 | Sony KP-57WS500 57" Rear Projection...
Sony KP-51WS500 projection tv. Screen is green with curved lines
The green picture tube has an internal short. Happened a lot with that model. The tubes are no longer availible. But a reputable company called Video Display will rebuild the tube completely. But the tube must be pulled and shipped to them. Most repair shops would charge around $400 to $500 for the complete job.
Jul 09, 2009 | Sony KP-57WS500 57" Rear Projection...
Sony kp-65w5500 rear projection TV red tube needs replacement
there is a company called Video Display Which sells rebuilt tubes
Jan 19, 2009 | Sony KP-57WS500 57" Rear Projection...
Sony kp-57wv600 tv turns on shows picture then blinks blue a few times and then shuts off....stnadby light blinks 7 times...whats the problem
Its either blue tube or bad componet on blue CRT board hertes how to know disconnect Blue CRT board connect to neck of blue tube turn set on see what happens if set come on and plays then this lets you know if it is a problem with tube/video ic on crt board. If set shuts back off different problem.
Dec 25, 2008 | Sony KP-57WV600 57" Rear Projection...
Red lines flashing red then blacksout
Their is only two possible things they are Bad Red picture tube or video ic on red CRT board more then likley its your Red Picture Tube.
Sep 21, 2008 | Sony KP-57WV600 57" Rear Projection...
Sony KP-57wv600 big screen
you will need to replace the Green CRT your model uses the sony # 873365201 CRT. The other site I work for just got a shipment of Sony and RCA CRTs(Tubes) in on friday. So you can get one at the following link these are brand new Tubes and they provide free shipping and free on line tech support with instant messageing in case you need help installing it. Heres the link.
http://servicemanuals.vstore.ca/
Jun 22, 2008 | Sony KP-51HW40 51" Rear Projection...
The Guns?
You will need a new CRT ( Blue Gun) they are fairly exspensive unless you can find one used. let me know if you need more assistance.
Jun 08, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony KP 57WV600
how many times does it blink?
Mar 26, 2008 | Sony KP-57WV600 57" Rear Projection...
Sony KP-57WV600 screen
I had the same problem except blue lines then all blue..I needed a blue crt tube..........so I'm assuming you will need a green crt tube
Jan 14, 2008 | Sony KP-57WV600 57" Rear Projection...
Blue to Black screen on Sony KP-57WV600
i too have 57wv600 and your problem is same as mine VOLTAGE withen tube is off ...this is common problem sony knows full well and will not tell us this voltage can be adjusted with a philips screwdriver i had blue lines then solid blue then shut off...7 blinking lights ...went to this site followed directions (too simple)and now i have perfect picture.serviceman said i needed new tube.b.s. ...so never change your tube it is not the prob!!!!!!!....go to www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html read post(comment) near bottom of page by paul t dated 12/26/2007 and instructions on how to remove our front panel is fully explained ...a screwdriver will fix your problem I guarantee it.....
Dec 28, 2007 | Sony KP-57WV600 57" Rear Projection...
Sony KP-57WV600 57" Rear Projection HDTV-Ready Television Logo
285 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
