My AC unit fan won't kick on. I hit the ''cool'' switch setting and the unit sounds like it is trying to run, then stops.
  • Bruce Hathcock May 11, 2010
    What kind of unit? and is it a wall mounted or a heat pump type? it makes a difference.
  • 614 Answers
Possible bad capacitor. You may need a service tech unless you have knowledge of AC wireing. Russ
Posted on Jul 23, 2009
Outside unit will only run for a short amount of time with A/C before the fan stops turning and starts humming, squealing/screeching and the top of the outside unit gets hot.
The bearings are bad in the motor and after the fan runs enough it eventually gets hot, making the bearing screech and the fan locks up. Need to replace motor again. See if it has a warranty. The reason it gets hot is because the fan is what removes the heat from the coil and if the fan isn't running there is nothing to cool it off so to speak.
Apr 19, 2016 | Heating & Cooling
Ac fan not running, but compressor runs on and off
switch/ fuse possible if it has one, if not one of the wire going to the motor was severed, or the start up capacitor of the motor if it also has one.
Jun 04, 2013 | Frigidaire FAX054P7A Wall/Window Air...
Fan wont run on auto
Make sure your tstat is programmed for electric, not gas. Or in the settings you want that the TSTAT CONTROLS THE FAN.
May 23, 2017 | Dometic Rooftop RV Air Conditioner
Honeywell Thermostat RTH6350 makes heat run in AC mode after AC runs
Well, if it wasn't doing that before then you more than likely know its in your wiring. Cools down then heats back up sounds like the auto change over is on, and the heat setting is higher than the cool setting?
Mar 02, 2017 | Heating & Cooling
Air conditioning works when car first starts up (Volvo s40) then stops cooling after a while (usually when I am stopped in traffic) -- then if I turn it off and back on after a few minutes it works again....
It sounds like your cooling fans are not working.Need to check the cooling fan fuses,and the cooling fan relays.There is also a high side switch mounted somewhere on the high side of the ac system that cuts the fans on,or kicks them up on high speed when the ac system gets to high on the high side of the system.This switch may also cut the compressor off.I would check the fuses and relays for these fans first,this is more likely the problem.Is the car running normal temperature? If not the fans may not be running at all.Have them checked.The fan or fans may be bad them selfs.If I can be any more help,let me know.>>roniecon@gmail.com
Aug 19, 2009 | 2005 Volvo S40
Goodman AC fan working but not cool air.
0204 built the second week of 2004 sound like you have a loose or burnt wire in the a-c and arcing when the unit comes on. turn the breaker off next time you fix an outlet
Aug 02, 2009 | Goodman CKL24AR24 Air Conditioner
AC roof unit stops cooling after rain
No, the units are sealed and the rain should not have affected the system at all. I would remove the outer cover of the unit and access the capacitors. Your start capacitor may be bad. You can visually inspect this and tell if there is a problem. Small black relay on top of capacitor often burns out, if so, replace capacitor and relay. If this looks fine, then we need to start at the thermostat and work our way forward.
Thanks,
Jeff
Jul 05, 2009 | Dometic Rooftop RV Air Conditioner
AC Kicking OFF Breaker
Sounds like you have a problem with your compressor. If the beaker trips the second the compressor tries to come on hen it is shorted. If it takes a couple of seconds, then your compressor is locked up.
seth
Jul 03, 2009 | Dometic Rooftop RV Air Conditioner
Frig stopped cooling. Bad condensor Fan Motor.
sounds like a bad thermostat,that tells unit when to kick on and off.
May 15, 2009 | Maytag Refrigerator Light Switch -...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
