Question about Tektronix Phaser 740P Laser Printer
I have a Tektronic Color Laser Printer Model 740. I am getting an error message 33. I have replaced twice the transfer roller (new), cleaned and vacumed the the interior of the paper feed unit. I have replaced the second bias clutch and cleaned the sticky solenoid. I have removed the imaging unit, fuser unit and cleaned the interior of the unit. Help
  • 42 Answers
the paper jamming problem is generic to most printer models of this capability. one way to circumvent this is to use a multimedia-tray while printing.
the reason is probably the two springs that hold down a silver metal pressure roller in the feeding unit. The tension is uneven due to old springs and the paper pulls crooked. If you follow the paper path in the fedder mechanism, you will see the roller I am referring to. The springs are at either end of this bar.
If you are good mechanically, you can replace the springs yourself, although they are a ***** to get back on (some disassembly required).
try this for details on doing it.
cheers
Posted on Jul 23, 2009
How do fix error Color registration could not performed
Possible remedies for weak images.
-Loose connection between transfer roller and high voltage supply unit.
-Dust in the laser beam path
-Transfer belt not contacting PCU.
Check the transfer unit.
Defective PCU. Replace the PCU.
Defective transfer roller. Repair the transfer roller.
Defective fusing unit. Replace the fusing unit.
Defective engine board. Replace the engine board.
Feb 02, 2016 | Ricoh Aficio SP C410DN Laser Printer
Lexmark x502 printer shows tray 1 missing
hi...........
pls do the following :-
Tray Missing: Insert Tray Tray 1 and/or Tray 2 is missing. Insert the specified tray(s) into the printer. TR Belt Life: Replace Transfer Belt The transfer belt is exhausted. Install a new transfer belt. TR Kit Life: Replace PQ Kit The transfer roller and transfer belt cleaning roller are exhausted. Install a new transfer roller and a new transfer belt cleaning roller. TX Comm Error An outgoing fax transmission error has occurred. Resend the fax. Warming up Wait for the message to clear....
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jul 29, 2011 | Lexmark C532n Color Laser Printer
I've getting the "Replace transfer roller" message
  1. reset count in printer menu
  2. clean the optical sensor
Mar 15, 2011 | Dell 5100cn Laser Printer
SERVICE CALL 14 XFER ROLLER Have installed new transfer belt. Still had error message. Came here and read tips. Cleaned the sensor both in the printer and on the transfer belt; reinstalled. Still...
the transfer roller is a foam roller that transfers the toner onto the paper. It will be visible with toner removed, a little wider than a piece of paper, and about the thickness of a roll of quarters. I don't know how to physically remove it on your model, but transfer roller issues in general can be remedied by removing the transfer roller and wrapping it in packing tape until the tape comes off clean.
While you're in there, vacuum everything out for good measure; but never, ever use canned air on a laser printer.
Jan 03, 2010 | Minolta magicolor 2200 DeskLaser Printer
Replace Transfer Roller Error Message Will Not Reset After Replac
The transfer roller on this machine comes as an assembly consisting of a waste toner tank and a transfer roller. The message you are getting pops up when this tank is full, regardless of the transfer roller's useable life. There is a window on the back that when blocked by toner, cuts off an optical sensor to tell the machine that the waste toner is full. Just unclip the roller from the side, pop it out, and dump the toner out. Careful though, it's a messy job and you might want to wrap the assembly inside a trash bag while emptying it out.
Jul 01, 2009 | Dell 5100cn Laser Printer
RICOH CL7200 MAGENTA AND CYAN LINES ON COPIES
It sounds like the transfer belt needs to be replaced. They get scratched up and milky looking and the sensors can't see the color reg marks good enough. It could be other things also but the transfer is a good place to start.
Apr 01, 2009 | Ricoh Aficio CL7200 Laser Printer
Buying and replacing just the transfer roller on a Dell 5110cn
Maybe if you call you can order just the transfer roller. You could try removing it and cleaning the ends (to provide better electrical contact). You could also try wiping the roller itself with a lint free dry cloth - but do so at you own risk and never touch the roller with your fingers!
Dec 09, 2008 | Dell 5110cn Laser Printer
I am reciving error code e000064
error code e000064 indicates machine having problem with transfer roller , black roller found underneath drum unit. it may require replacing or needs cleaned being soiled . this area require technical experts as transfer roller operates on high voltage . hope this helps
Oct 01, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Phaser 7700 Accumulator Belt Replaced, upon startup there is an error
POSSIBILITIES
Problem:
1st BTR Contact Failure or 1st BTR Retract Failure Message is displayed after replacing the Accumulator Belt Cause:
A Phaser 7700 Accumulator Belt was installed in a Phaser 7750. The Phaser 7700 Accumulator Belt does not have retractable 1st Bias Transfer Rollers; so these errors will be reported if one is installed in a Phaser 7750 printer. Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Remove the Phaser 7700 Accumulator Belt and install a Phaser 7750 Accumulator Belt. TRY FIRST (Solutions without parts):
1. Check that all shipping restraits have been removed.
TROUBLESHOOTING TIPS AND HINTS:
1. Test the 1st BTR motor in diagnostics to verify proper operation. 2. Test the 1st BTR sensor in diagnostics, then run the 1st BTR motor test and recheck the 1st BTR sensor. Sensor state should alternate between L and H. The sensor is part of the accumulator belt.
PARTS:Parts are listed in the order of highest probability for repair.
NUMBER QTY DESCRIPTION
116177400 1 *KIT IBT - UNIT
REPAIR/INSPECT/PREVENT PROCEDURE:
1. Clean feed rollers, exit rollers and guides; replace if
necessary.
2. Clean feed rollers and exit rollers only when dust or
debris is visible.
3. Remove and clean all paper trays.
4. Clean the Laser Scanner Unit window.
5. Inspect the image density sensors; clean if necessary.
6. Inspect the accumulator belt home sensor; clean if
necessary.
7. Inspect the fuser assembly; clean if necessary.
8. Print the Error Log, diagnose and repair any problems as
indicated.
9. Print the Usage Profile, diagnose and repair any
problems as indicated.
10. Check version of all installed firmware; as
appropriate, install the latest version of firmware.
11. Check cleanliness of interior and exterior of printer,
including fans; if necessary, clean (dust or vacuum) these
areas.
Problem:
Jan 25, 2008 | Tektronix Phaser 860DP Thermal Printer
Xerox phaser 6250 NVRAM Failure
Cycle power, try cleaning the CTD (ADC) sensor and toner full sensor. This is what Xerox has to say about the NVRAM failure: On the front panel, press the key labeled i to view information about the error. Record the error code number. Turn off the printer. Reseat the fuser. Reseat the imaging unit. Reseat the toner cartridges. Turn on the printer. If the error continues to be displayed contact service. To be on the safe side you can follow the instructions here on the procedure to replace the transfer roler: http://office.support.xerox.com/SRVS/cgi-bin/webcgi.cgi Good luck
Mar 25, 2006 | Xerox Phaser 6250DP Laser Printer
Tektronix Phaser 740P Laser Printer Logo
164 people viewed this question
Top Tektronix Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Tektronix Office Equipment and Supply Expert? Answer questions, earn points and help others
