Question about Sony FD Trinitron WEGA KV-36HS500 36" TV
My tv stays on favorite channel menu and I cant get it to change to video. The remote only powers on the unit and wont change anything or turn off. The menu on the tv wont help. Please help
  • chris rebik Jul 23, 2009
    Its a 32" sony wega falt screen crt
    President:
  • 1,284 Answers
Sounds like you have a stuck button on the front of the TV or a bad protection diode in the keypad matrix that will need to be looked at by a technician.
Posted on Jul 23, 2009
Remote will not change channels
If you are using the original remote, it has failed.
Sep 26, 2017 | Pioneer PDP-5080HD 50 in. Plasma HDTV
I have a Sony KV-27XBR55 TV, that wont display signal (Video nor sound) it only displays 0 0000 on the Channel input
It sounds like you are in the service menu---aside from the zeros what if anything else can be seen?
The set does have (all Sony sets do) a reset done only with the original Sony remote.
Dec 21, 2012 | Televison & Video
I lost the remote to my Toshiba cz27t31. I bought an RCA universal remote. The RCA manual says the tv should be set to channel 1. But I can't change the channel without the remote. So I am SOL! How...
  • You have to set the channel you want as a favorite first and you can do this from the TV. This is why the channels skip as you press up and down. Sometime or another those were someones favorite channels.
  1. Press "MENU" on the TV until "SET UP" appears on the screen.
  2. Now press ^ or v until "FAVORITE CH" appears in purple.
  3. Now press < or > to display the favorite channel FAVORITE CH menu.
  4. You will use < or > to got between "SET and "CLEAR."
  5. So now go to "SET" and press ^ or v until you get to channel 1.
  6. If you want to delete a channel first then select "CLEAR" and then add the channel you wish.
  • What your doing when you push the channel up and down on the TV buttons is going through the favorite channels. So make one of the favorite channels channel 1 and program your remote.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 20, 2011 | Toshiba CZ27T31 27" TV
CANT GET THE TV OFF AUX AND HAVE A CABLEONE REMOTE HOW CAN I CHANGE IT
I suspect you have a dish or direct tv hookup.If so press your menu button on the tv then select favorite channels.change the channel to your preset for your system.save the channel and it should bring the tv up.
Oct 16, 2010 | Zenith C13A05LG 13" TV
Ilo 32 in
Try the keys on the set I would think there is a menu key there on the set to help get you out of favorite channels. Universal remotes don't always work as thought should be and usually onthe the devices remote will access all functions. Is our remote dead or busted? Try opening it up look for bad solder on the circuit board clean the switch contacts on the the board it may just fix it
Sep 03, 2008 | iLO 3200 32 in. LCD Television
Channel keeps changing
It sounds like a stuck button or switch. What happens when you hit the channel DOWN, does it still keep scrolling down?
Is this with or without the remote?
Have you tried it with the remote and or the TV?
Let me know whether you are changing the channels with the remote or the buttons on the tv and I can try to give you a couple more suggestions.
Mac =)
Feb 12, 2008 | Televison & Video
Favorites Keep Coming On
Check to see if the lower buttons are stuck. You should feel a 'click' when you depress them. If one of them is stuck... you found the problem. Now you need to fix it. All you need to do is pull on the plastic button just a little to give some spring back to it. Or try a needle with a bit of a hook on it. Side it in the right side of the button and pull the button forward. Just be careful not to pull it to far. Just enough to correct to position.
Do you spray windex on the face of the tube??
Read this artical
http://www.fixyourowntv.com/wifekilledtv.html
Jan 17, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Video mode
I went to add/delete channels in my menu on my symphonic and it let me scroll through the channels, make sure you have them all set to add (by pushing the volume buttons to make them light blue instead of purple)....after adding all of your channels (or just the one if you use dish) just power the tv off while on a channel and then power back on and you should have tv.
Jan 12, 2008 | Symphonic ST419E TV
Only receive 2 channels.
Can you punch in the channel numbers directly to go to the channels, but just not tune to them with the Channel Up/Down buttons?
If so then try tapping the favorite button on the remote until the screen shows "favorite mode off". This mode likes to stay [or perhaps turn] on when you scan for channels, but scanning clears everything in the favorite list except for the channel you are on when you start the scan (so it seems), thus leaving only one or two channels showing up. (This happens whenever I re-scan for digitals.)
To pick out favorite channels, go into the channel menu in the tv menu and with "Favorite: Analog" or "Digital" highlighted near the top, hit OK on the remote to toggle favorite status.
Nov 28, 2007 | Mintek DTV-263 26 in. TV/DVD Combo
Cant change channels
Your in the video mode so you have to change the input. On the original remote, its the button left of the power button. A universal may not work for this. If you need the original remote, Its available at http://www.remotes.com Good Luck
Aug 18, 2006 | Sanyo DS31520 31" TV
Sony FD Trinitron WEGA KV-36HS500 36" TV Logo
130 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
