Question about Garden
Tines won't turn all the time - Garden
  • 11,896 Answers
Cluch may be slipping or axle needs grease. Check chain or belt tension
Posted on Jul 23, 2009
Tines
Either clutch is bad or teeth are striped in bottom gear box. remove tines run engine and see if you can feel movment in lower gear box, if yes the gears are gone. If no remove engine to expose clutch.
May 20, 2013 | Ardisam Inc Earthquake Mini Cultivator
I have a Yard Machine rear tine tiller that has sat unused for 4 years. I replaced the engine and while in goes forward and backward, when I engage the tines they won't rotate and the engine bogs
Transmission/differential.
Perhaps the unit sat for 4 years because the tines would not turn and your replacement engine has not solved the real problem.
I'd say disassemble the chain case to discover what's locking the tine drive.
Apr 12, 2013 | Garden
Tines won't turn
Detatch the HEAD and rotate it and then install it. There is a good chance you have Jammed the Head and this should reduce the pressure and allow it to work.
Apr 03, 2013 | Ryobi GC720R TrimmerPlus Add-on Garden...
Tiller engine won't turn over after the till was on its side to clean tines
remove the spark plug and pull it to force any fuel and oil from the cylinder hold a rag over the top of the spark plug hole as fuel and oil will spray out check the oil level before running the engine again
Apr 30, 2012 | Troy Bilt Bronco 208cc 4Cycle Gas Powered...
Ryobi ry64400 tiller tines won't move engine runs fine
then you need to open the gear box and find out why if it has a forward and reverse the the shifting linkage it could be stuck in one gear and adding the other will lock it up as well
Apr 17, 2012 | Ryobi Cultivator
My mtd yard machine bogs down in the tilled /cultivated dirt. the belly support is only less than 2 inches to the bottom of the tires! when I till the next row the tires just turn freely and I have to...
Sounds like a depth adjustment or a leverage problem.
Check your manual to see if you are able to lower the tines to a deeper position.
There usually is also a handle adjustment to raise the handle to get more leverage. (Not all Models) By pulling back on the handle it forces the tines into the soil and raises the tires. This allows the tines to agitate and do the work while at the same time walking the machine forward. When you push up on the handle the rubber tires provide traction and forward movement and less digging on the tines.
Method: Possibly by allowing a little space between passes your wheels won't hang up in the previous dead furrow. You can then go back over the skipped spaces or cultivate from the other direction and a criss cross pattern.
Best wishes,
TF
Jun 02, 2011 | Mtd Garden Tiller (Mtd)
Own an older (1990's) American Yard Products model WER500 Weedeater rear tine rotortiller. The engine runs great but when I engage to til, the tines won't turn. The belt is fine and pulleys turn...
Yes, there are shear pins on the tines and on the wheels. Can you check to see if the belt actually moves when the pulleys turn?
May 13, 2011 | Garden
THE TINES WON`T TURN, THE MOTER WORKS THE TINES WON`T TURN
SOUNS LIKE SOME THING CAME LOOSE IN SIDE THE TRANS
Oct 01, 2009 | Craftsman Garden
Honda GX25 HG110 mini tiller, tines won't turn.
Mine did the same thing....two things to check: 1) air cleaner, make sure that it is clean 2). gas filter in the gas tank. Take a short piece of wire and fish the black line out. On the end is a small fuel filter. After I flushed mine fuel filter out it ran fine.
Mark
Apr 09, 2009 | Honda Garden
Garden Logo
56 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
