Question about Coleman Mach III Air Conditioner
Found leak I have a Coleman Mach Mod# 6759-707, which has a leak in a small canister in the line between the condenser and evaporator on the opposite side of the compressor line. What is this and where can I get one?
  • 614 Answers
Sounds like a drier. You can pickup one at a Autozone or any auto supply house. Russ
Posted on Jul 23, 2009
Clean the drain holes ?
Get a vacuum cleaner and **** any dirt from the end of the drain hose. If you can access under the evaporator from the side, clean the base tray as well.
Apr 22, 2012 | Coleman Mach III Air Conditioner
My coleman rv ac unit is dripping condensation inside the camper, what is causing that?
It is possible that the drain hole on condensate pan is plugged and causing water to over flow pan. Remove cover from unit and check drain line.Clean coils andpan as best you can and clear drain hole. Add a small amount of bleach to water in drain pan.This will kill any algea or bacteria that may be growing in condensate water and plugging the drain. Thank you
Jun 20, 2011 | Coleman Mach III Air Conditioner
Code says evaporator purge solenoid
Which code specifically? Do not assume you need a new solenoid. Our recommendation will depend on the specific code and some troubleshooting results. I usually recommend checking over all the EVAP vacuum lines and the gas cap too whenever there is a purge valve code. Check the vacuum lines at the cannister in the left rear bumper. I will paste info on the purge solenoid below.
P0440 Evaporative emission (EVAP) system - malfunction
Possible causes: Hose connection(s), intake leak, EVAP canister purge valve
P0441 Evaporative emission (EVAP) system - incorrect flow detected
P0442 Evaporative emission (EVAP) system - small leak detected
Possible causes: Hose connection(s), intake leak, EVAP canister, EVAP canister purge valve
P0443 Evaporative emission (EVAP) canister purge valve - circuit malfunction
Possible causes: Wiring, EVAP canister purge valve, ECM
P0444 Evaporative emission (EVAP) canister purge valve -open circuit
Possible causes: Wiring open circuit, EVAP canister purge valve, ECM
P0445 Evaporative emission (EVAP) canister purge valve -short circuit
Possible causes: Wiring short circuit, EVAP canister purge valve, ECM
P0450 Evaporative emission (EVAP) pressure sensor - circuit malfunction
Possible causes: Wiring, EVAP pressure sensor, ECM
P0455 Evaporative emission (EVAP) system - large leak detected
P0456 Evaporative emission system - very small leak detected
Possible causes: Mechanical fault, hose connection(s), EVAP pressure "sensor
P0457 Evaporative emission system - leak detected (fuel cap loose/off)
Possible causes: Mechanical fault, hose connection(s), EVAP pressure sensor
P0458 Evaporative emission system, purge control valve -circuit low
Possible causes: Wiring short to earth, EVAP valve
P0459 Evaporative emission system, purge control valve -circuit high
Possible causes: Wiring short to positive, EVAP valve
Evaporative Emission Purge Solenoid
Description & Operation
The duty cycle EVAP canister purge solenoid (DCP) regulates the rate of vapor flow from the EVAP canister to the intake manifold. The Powertrain Control Module (PCM) operates the solenoid.
During the cold start warm-up period and the hot start time delay, the PCM does not energize the solenoid. When de-energized, no vapors are purged. The PCM de-energizes the solenoid during open loop operation.
The engine enters closed loop operation after it reaches a specified temperature and the time delay ends. During closed loop operation, the PCM cycles (energizes and de-energizes) the solenoid 5 or 10 times per second, depending upon operating conditions. The PCM varies the vapor flow rate by changing solenoid pulse width. Pulse width is the amount of time that the solenoid is energized. The PCM adjusts solenoid pulse width based on engine operating condition.
Removal & Installation
The duty cycle evaporative (EVAP) canister purge solenoid is located in the engine compartment near the brake master cylinder.
  1. Disconnect electrical connector at solenoid.
  2. Disconnect vacuum lines at solenoid.
  3. Lift solenoid slot from mounting bracket for Removal & Installation.
To Install:
  1. Position solenoid slot to mounting bracket.
  2. Connect vacuum lines to solenoid. Be sure vacuum lines are firmly connected and not leaking or damaged. If leaking, a Diagnostic Trouble Code (DTC) may be set with certain emission packages.
  3. Connect electrical connector to solenoid.
Purge solenoid location:
EVAP cannister location:
Nov 05, 2010 | 2000 Jeep Grand Cherokee
Coleman Mach AC drops condensation when shut off
Your AC's drain port could be on the opposite corner from where the water is building up. Your vehicle absolutely has to be level, this pertains to the refridgerator also. Good luck, my friend, Dana
Sep 09, 2009 | Coleman Mach 15 Air Conditioner
Appears to be condensation leaking from the Carrier roof A/C in 2009 Pleasure Way Plateau RV. Leaks on back bed and floor. Thanks, Richard
there should be a pan under the evaporator coil in the roof mounted unit, the pan should have a hose on it to remove the water to a non objectionable place, you need to locate the drain and pressure it up to clear it, I would also remove the top covaer and check the cleanliness of the coil drain pan itself
Jul 18, 2009 | Coleman Mach 15 Air Conditioner
Should there be a condensation hose of some sort. I have a leak and can't find where water is coming from
These units do not have condensation "hoses", they have an evaporator pan than is located under the evaporator coil and catches the condensation and then lets it drip down onto the roof and then off the RV. If your AC is leaking into the inside, remove the inner shroud and feel up into the evaporator area for the pan. If it is full, then the drain holes are plugged. They are not easy to get to. Remove the upper shroud and then remove the front cover over the evaporator. At the base of this area is the pan, on each end is the drain hole. Clean them out and all should be fine.
Hope this helps,
Jeff
Rate me please!!
Jul 07, 2009 | Coleman Mach III Air Conditioner
Coleman tsr rv air conditioner leaks into rv when running
It probably has a clogged condensate drain. Take off the cover on top the RV and check hoses or tubes leaving unit for debris or lint. Often this water is used to help cool the condenser so look for leaves pine needles etc in the pan. There may be a cover you can remove on the evaporator section that will allow you to clean the collection pan and hose or trough. Is it possible the RV is far enough out of level that the condensate can't "run uphill"? Always power off while working on this unit unless you are electric savvy. Good luck!
Jun 28, 2009 | Coleman Mach 15 Air Conditioner
At a State park... AC freezing up
If the unit is low on freon, there should be visible signs of leaking somewhere in the upper unit. Are you running the system on Low Cool? This will often times cause the AC to freeze up because the condenser fan and the evaporator fan are on the same motor. If you run the system on low cool, you are not getting enough air movement over your condenser to effectively warm up the freon and thus causing the system to freeze. Turn it to high and adjust the thermostat if it is too cold, this should help.
Jeff
Jun 25, 2009 | Coleman Mach 15 Air Conditioner
Coleman mach air
Time for a spring cleanning,, especially the drainnage system, filter,, front cooling coils-and the drain line! thank you-very-much!
Aug 28, 2008 | Coleman Mach III Air Conditioner
How to charge coleman mach-3 a/c roof unit 134 or 22
If it needs a charge the leak has to be found and fixed. If the leak has been fixed and you have a service valve on the low side. It should have a vacuum pulled on the system to remove all air and non-condensable gases from the system. Then you can charge the system : 1. by weight according to the name plate. 2. charge by superheat (temperature leaving the evaporator + 16°F) When using the superheat method to charge the higher the Ambient temperature the lower the superheat difference will be.
May 01, 2008 | Heating & Cooling
Coleman Mach III Air Conditioner Logo
205 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
